The bezel was made to ideally accept a Convoy S21a reflector. Currently I’m using the same S2+ SMO, which is too small and looks silly. Also, I ran out of time machining the part and didn’t get a chamfer on the outer edge. I made this of 7075 in hopes that it’ll stand up to drops better than 6061. Lastly, I’m going to dip the new part in an NaOH bath to try and match the surface finish of the rest of the light that was stripped.
If anyone has any suggestions to reflectors or single optics in the 22-23mm range and very shallow (10-12mm) let me know please. I’m hoping Simon makes available the S21a reflectors like he does with most models but as of yet haven’t heard back
Call me crazy but I actually like it a bit longer. Maybe it’s just because I have larger hands, but it feels a lot better now and that 5-6mm extra is unnoticeable in my pocket.
Diameter however is another story. You notice every millimeter there. I like the girth of the FW3A in hand (seems just right), but in the pocket it could stand to loose a mm or two.
Single TIR optic is still going to be longer than the stock triple TIR. Unless you use a very tiny single-TIR optic that only uses a fraction of the width of the light.
One advantage of the Carclo triple TIR is that it’s really shallow. Just 7mm. You’re not going to find any single-TIR optics that are 20mm wide and only 7mm deep.
There’s also a repo branch there for instant off as a compile time option, but I found that it breaks some ramping features. If you want I can post my changes to the code to make it work better.
Of course, you’d also need a USBasp, SOIC clip, and soldering iron to flash your driver.
I bought these to use around the Emisar D4 switch to recess it. They fit perfectly around the chrome ring and bring the top of the switch flush with the plain of the washer. Turns out , they also look good on the FW3A . I think they will prevent accidental activation well. Sorry, no pictures.
I’m looking to add some Aux Lights to my FW3A. I know I’ll need to flash Andruil with them turned on (which I’m in the process of learning). Would it be possible to use this and add some 0805 leds along with the appropriate resistor to control their output?
I have 351D 4000k 90CRI and copper noctigon in the drawer.
Is it worth swapping if I have hi 7a currently and not happy about colour rendering.
What do you think? Maybe you could suggest other high cri led’s to put in?
Mike
