My wife runs around the house slightly unscrewing all of my tail caps. 2 years ago today(not joking) my zebralight(sc600w iv plus) caught my cotton shorts pocket on fire.
I’m more worried about her finding out that my new light caught the bed sheets on fire
Kawi: I use my flashlight a lot and in hard to reach places. I use it a few hours a day. I’m also clumsy and drop it off my lap at least twice a week. But my hands are getting destroyed from doing repairs on small devices
I believe that Japanese/Chinese hands are smaller, better able to reach inside their miniature engineered wonders.
One reason I had my sinus surgery by a Japanese doctor and my proctologist is Dr No.
This is very concerning. I just checked my spring. The end of the spring is about the 2 o’clock position from the FW3A stamp. The largest gap is about 11 o’clock. I can just barely get a sheet of paper thru the spring at the trace. All three solder pads appear soldered ok. I’ve never soldered before. Do you think it is OK? I have had zilch problems with the light. I have never dropped it though. I do use FT batteries.
Seems a piece of kapton tape over that trace would have been cheap insurance. I may desolder my spring and do just that when mine comes in. I like my lights to be as bulletproof as possible. My Olight S1 has been through a lot and refuses to stop working.
Is the head of this light easily replaceable?
Like, if I want a different led, can I just swap the head content, or do I need to unglue and solder stuff?
Mine had the sharp end of the spring right over the trace. Almost touching.
The solder job on mine was really bad, too. Just one contact point, and the spring was way off center.
I desoldered it, and did an equally sh*tty solder job putting it back together. But, at least it’s centered, the sharp end is 180 degrees away from the trace, and there’s two contact points (couldn’t get the third for some reason). I also added some more solder so the spring sits up higher. There’s a good millimeter of space between the spring and the board.
I hope I did that correctly. Anyway, the light works fine, and the spring seems solidly in place.
My favorite combo for weight vs ability to handle heat - Aluminum outside and copper inside. I’ll do a copper light very infrequently. I NEVER do brass, bronze or stainless steel. Titanium is rare for me, but has been purchased a few times.
It does not have a pill if that is what you are asking. If you want different emitters you will have to take the MCPCB out & either reflow new ones or install another MCPCB with different emitters.
As far as the head being “easily replaceable” …. yeah, you can just screw one off and screw another one on.
Just an update for this thread. I tested to see what happens if the spring shorts to that trace in the tail cap. Nothing big happened. All is fine, so there’s no worry about that specific scenario. Details are HERE and a couple posts below that.
Something else caused the malfunction is DBSAR’S light when it fell.
A blob of solder could be the cause of a short if it touched both a positive point on the driver and a ground point at the same time. I doubt it would melt, though. They tend to blob up when heated like surface tension does a water droplet.
