Banggood states the reflector is 60mm in diameter and the head is 65mm in diameter overall. Same as the FT03. No ramping like the FT03 its a hard sell to step backwards and charge more. WTF Astrolux.
Since when is an sst40 outputting 3000 lumens?
Wasn’t the FT04 announced back in 2018 way before the FT03?
FT04 =! MF04 ;)
has anyone tested a P2 bin yet?
I only found N bin numbers from last year
Interesting - lots of the new Astroluxes have a very Haikelite aesthetic to them… would be curious to see how this stacks up against the FT03 as the reflector sizes are the same per everydaysurvivalgear’s post
I’m excited for the P2 bin SST-40. The dedomed version was used in the Maxtoch Archer M1 that was same size as the D1S and GT Mini but out throws them. Will this be dedomed?
Also why did HL decide to use a proprietary charger instead of USB. That is a deal breaker for me.
interested
Does the P2 Bin really delivers 3000 lm? WOW! Would love to see confirmation.
No, not really.
The absolute highest you can get from it in a light is around 2500-2800 lumens:
The lack of a e s t h e t i c s makes me skip this deal. Haikelite needs to work this part out, their designs are imho not very appealing. Like the recent model with blue bezel and that bling blang golden switch
Feel the same way. Everything after the SC26 is just meh to me.
I would be skeptical of those measurements because we have no idea how his pvc tube was calibrated. This is an important bit of info.
It looks like the charger that the Convoy BD series lights use. A plus is that it’s waterproof, a minus is it’s easy to loose the adaptor. Kind of an odd choice.
I mean, bare LED output could reach 3000 lumens,
The P2 SST-40 has on average 13% higher luminosity.
And looking at koef’s test:
With a 13% improvement, 3000 lumen output from a bare LED would be possible, and at 90% efficiency optical efficiency, 2700 lumens on turn on would be possible.
No flashlight is 90% efficient. I use 75% as a general average. I also don’t count the lumens you see for a split second on the meter right at turn on. Doing so just confuses people. I try to give more of an ANSI FL1 type reading. (Certain lights don’t last 30 seconds, so I might do a 15-20 second measurement) I think the FL1 specs are a more fair and realistic measurement that people can relate to.
I try for years now to convince the manufacturers to use "peak power" and "continuous power"
interested, please send me a PM
I’m confident if you measure OTF, at 30 seconds, and with an honest calibration, this light does not get past 2500 lumen.
then its wrong to make people believe it does 3000 lumens, why not put and use honest lumens instead? this is better…
my thought exactly. SC26 is my last Haikelite until something interesting that is.
