Seems a piece of kapton tape over that trace would have been cheap insurance. I may desolder my spring and do just that when mine comes in. I like my lights to be as bulletproof as possible. My Olight S1 has been through a lot and refuses to stop working.
Is the head of this light easily replaceable?
Like, if I want a different led, can I just swap the head content, or do I need to unglue and solder stuff?
Mine had the sharp end of the spring right over the trace. Almost touching.
The solder job on mine was really bad, too. Just one contact point, and the spring was way off center.
I desoldered it, and did an equally sh*tty solder job putting it back together. But, at least it’s centered, the sharp end is 180 degrees away from the trace, and there’s two contact points (couldn’t get the third for some reason). I also added some more solder so the spring sits up higher. There’s a good millimeter of space between the spring and the board.
I hope I did that correctly. Anyway, the light works fine, and the spring seems solidly in place.
My favorite combo for weight vs ability to handle heat - Aluminum outside and copper inside. I’ll do a copper light very infrequently. I NEVER do brass, bronze or stainless steel. Titanium is rare for me, but has been purchased a few times.
It does not have a pill if that is what you are asking. If you want different emitters you will have to take the MCPCB out & either reflow new ones or install another MCPCB with different emitters.
As far as the head being “easily replaceable” …. yeah, you can just screw one off and screw another one on.
Just an update for this thread. I tested to see what happens if the spring shorts to that trace in the tail cap. Nothing big happened. All is fine, so there’s no worry about that specific scenario. Details are HERE and a couple posts below that.
Something else caused the malfunction is DBSAR’S light when it fell.
A blob of solder could be the cause of a short if it touched both a positive point on the driver and a ground point at the same time. I doubt it would melt, though. They tend to blob up when heated like surface tension does a water droplet.
There was a small blob of solder on the oval trace on my switch board. I took it away with a pincer, it loosened very easily. A little bit bigger blob there could possibly touch the batteries negative pole.
I received my SST-20 light yesterday (which was a nice surprise because the tracking never worked no matter which tracking site I used). I am glad that I got one because the tint is great. Like others mentioned, I don’t see a green tint at all, no matter what level it is on. It’s as warm as I’d like and the colors really pop. Well done.
Mine had no issues. No loose retaining ring, tight tail cap, worked right out of the box with a GA cell I have.
There are a few differences though that some others have mentioned. Brass (?) retaining ring, shiny silver clip, shorter and lighter travel in the switch button and the anodizing is slightly more blue than the HI one I got a while ago. Nothing to be concerned about, except for the switch which seem to be easier to turn on. I’ll keep it locked out or in an Astrolux holster I’ve got. It’s low-profile and a lot less bulky than the Convoy ones I have.
I chose to have Neal send me the light with the new optic and the lens. I swapped the optic for a floody one I’ve got (can’t remember the number but it’s more frosted than the one I received on my HI FW3A). It looks great and I’ll get a lot of use out of it around the house and at work.
I must say that I thought the new optic was going to be junk but it really isn’t. The beam looks good and the material is better than what I envisioned. I thought it was going to be some lousy milk-carton soft plastic, but it’s actually pretty nice. I can see why they went their own way if Lumintop couldn’t find the original optics in sufficient numbers or having to wait for them and keep customers waiting.
Overall, I am very glad I’ve got my two different models. Each will be used a lot. I doubt I’ll get another. No need for alternative materials for me and the colors are cool but not necessary, although I really did like that olive/sand one…
My FW3C with SST-20s has shipped, and hearing the reports of how good these SST-20s are, I’m quite hyped. Thankfully my D4V2 has just arrived to tide me over until then.
It’s rare there is enough current flowing through a wires soldered end for the solder to liquify. Once it does, tension in the wire can pull it loose. A scenario that can cause this is if a wire has a poor solder joint to a pad. The poor connection can create a lot of resistance which then heats up.
