I’m excited for the P2 bin SST-40. The dedomed version was used in the Maxtoch Archer M1 that was same size as the D1S and GT Mini but out throws them. Will this be dedomed?
The lack of a e s t h e t i c s makes me skip this deal. Haikelite needs to work this part out, their designs are imho not very appealing. Like the recent model with blue bezel and that bling blang golden switch
It looks like the charger that the Convoy BD series lights use. A plus is that it’s waterproof, a minus is it’s easy to loose the adaptor. Kind of an odd choice.
The P2 SST-40 has on average 13% higher luminosity.
And looking at koef’s test:
With a 13% improvement, 3000 lumen output from a bare LED would be possible, and at 90% efficiency optical efficiency, 2700 lumens on turn on would be possible.
No flashlight is 90% efficient. I use 75% as a general average. I also don’t count the lumens you see for a split second on the meter right at turn on. Doing so just confuses people. I try to give more of an ANSI FL1 type reading. (Certain lights don’t last 30 seconds, so I might do a 15-20 second measurement) I think the FL1 specs are a more fair and realistic measurement that people can relate to.
