Does the use of glow discs, glow powders or tapes in the emitter/lens cavity affect the beam tint of the actual light? Also, do tritium tubes in the optics affect the beam tint?
I doubt that the minimal emission of the trits and/or glow gaskets would make a significant difference to the powerful output of the LED emitters unless they were used in a lower power mode. Technically they would add color to the light but I’ve never noticed any difference. I guess it’s similar to adding a teaspoon of sugar to a gallon of water.
Can you source some 2700K and 3000K 219B? I bought some 3000K 219B 9080 from LEDRISE.eu and they tested true 9080 but with a greenish duv of 0.0028 even on high output and measures about 3400K. I would love to try some rosy WW 219B.
Thanks azhu for your post. It is appreciated and I would expect this to be the case but I do not know. I am looking for someone that might have more definitive trials or tests with green or any other color. I do not have any HCRI SST-20 containing lights which would seem to me to be a good before/after scenario at low levels especially since the new one’s Neal has sourced appear upon first report to have no green even at low levels. I have trit containing light but they are all in the sides and tail. The nice thing about the new lights with auxiliary lights is that they are programmed to turn off when the main LED’s are powered on. I have 6 of these type lighrts and love them and they are a non issue as far as tint change. And, yes, I have lots and lots of 219B lights and love that tint. Nichia just doesn’t make them anymore (they would, but need a minimum 3,000 reel order) (Yes I contacted them, just ask TK) so the search goes on for an equal or better tint producing emitter and how they are affected by the glow product options that are being put in the lens area.
Thank you — good to know. I always keep a tube of Goop shoe-goo around for various long term repairs that can be reversed. I’d gotten into the habit of manual lock-out (just a slight twist to the head), but if the perimeter ring works well to reduce accidental activation, that saves one less thing on the mind when dealing with a pocketed FW3A. :+1:
I think if there are no other objects in your pocket , you will not get accidental activations. At least that has been my experience so far. You could stack the washers for added protection but it might not look as nice. With one , it looks like it came that way.
There might be a slight difference the meter was set to auto and it showed 129x10 but since I took the measurement that way originally I did the same this time.
GITD: trimmed tape band along inside wall just below Carclo optic, and band along groove in tail cap Optic: 10507 (in addition to others , beams) Grip: trimmed bicycle inner tube, reversed. Also, o-ring attached, aligned to base of tail cap.
Still have a plan to install trits, but waiting to see how the tail cap aftermarket offerings pan out. I’m completely satisfied with the XP-L 3D emitters and feel no need to change. I was tempted to attach a metal washer to the tail cap as done by another member here to help minimize accidental activation, but, I’m finding the slight twist of the head to be very effective and not really a bother. The grip enhancements are excellent. The inner tube has completely stabilized the grip, no slippage. And the o-ring adds a little extra tactile grip when picking up. It extends about 1mm beyond the tail cap radius — just enough to be useful without being obtrusive.
/\ — photo edit caused tint skew in last image — actual tint is neutral not cool
