Customer Review for Hot recommend RD tech (ruideng) products of DPS5020, DPS5015,DPS5005, UM25C ,UM34C ,TC66C UM24C at34,DPH5005
Hi friend
thank you for your message and your support
I don’t know the detail, most sale promotion have time limit, when the time is end, you can’t get the discount, please tell me which products you need, I can offer you discount
thank you for your support
I will prepare some post to release some coupons, hope more BLF buyer can get coupons
Hi my dear BLF friend
Thank you for your long time support in BLF , I saw many many people like our products and also need better price , so in order to appreciate BLF friends help and stratify some friends wish, I decide to release coupons for some hot sale products, and each week will update new coupons, hope you can find some big surprise
today I want to sent you 2 kind of coupon:
coupon 1: $1 for USB tester
https://www.aliexpress.com/store/selected-sale-items/923042.html?es=0zoEZ8%2F9sMY50ioS945Jw%2FXeHNPzDCIi
coupon 2: $2 for power supply
https://rdtech.aliexpress.com/store/selected-sale-items/923042.html?spm=5261.10636610.0.0.4dd23e5f4CSDtD&es=0zoEZ8%2F9sMY50ioS945Jw2fs1veYAONW
you can use them to buy USB tester and power supply in our shop:
https://rdtech.aliexpress.com/store/923042
coupon topic:
new share
Product name: RD DPH5005 Buck-boost converter Constant Voltage current Programmable digital control Power Supply color LCD voltmeter 50V 5A
Product link: 43.0€ 23% OFF|RD DPH5005 Buck boost converter Konstante Spannung strom Programmierbare digital control Netzteil farbe LCD multimeter 50V 5A|lcd digital voltmeter|voltmeter 50vvoltmeter lcd - AliExpress
[This power supply is the best of available modular units. Packed in a box of foam. The module itself is additionally in a package of foam polyethylene. All the components of the seller carefully packed in separate bags of puffy film. The assembly of the unit is simple and understandable. The board is made of quality components, the components are soldered smoothly and do not cause complaints, the flux is well washed. Also there is a bluetooth adapter, to connect to a computer. The unit has an active cooling system of the radiator, which turns on at a current of 10 amps. The accuracy of the voltmeter readings is very high, the error is only about 0,02 volts. Very satisfied with the product, i recommend to buy. The seller very quickly sent the goods and deserved 5 stars.]
coupon topic:
new share
Product name:RD UM24 UM24C APP USB 2.0 LCD Display Voltmeter ammeter battery charge voltage current meter multimeter cable measure Tester
Product link:
[I recommend the seller in 100% very fast shipping, reliably packed, very good contact with the seller, the highest quality goods as shown in the pictures. My rating is 5+ thanks to the seller. ]
coupon topic:
new share
Product name:RD UM25 UM25C for APP USB 2.0 Type-C LCD Voltmeter ammeter voltage current meter battery charge cable resistance usb Tester
Product link:17.99€ 35% OFF|RD UM25 UM25C für APP USB 2,0 Typ C LCD Voltmeter amperemeter spannung strom meter batterie ladung usb Tester|charging measure|voltmeter ammetervoltage current meter - AliExpress
【Super fast delivery to kazan, in just 8 days!!! The foam box came whole and did not suffer, everything is packed perfectly. The device and load work, checked charging and wires. The seller is sociable. A little upset the fact that the tester storage box has several dents, although it was packed in the factory film. On the performance of the device this did not affect, so i put 5 stars.】
RD Official Store - Amazing products with exclusive discounts on AliExpress
coupon topic:
new share
Product name:RD UM34 UM34C for APP USB 3.0 Type-C DC Voltmeter ammeter voltage current meter battery charge measure cable resistance Tester
Product link:https://www.aliexpress.com/item/32880908871.html
[’S Days to Germany, looks great and works well. I recommend]
It is a new week, and there is a discount for UM24/UM34/HD35/DPS5005/
UM24(39%):https://www.aliexpress.com/item/32845522857.html
UM34(28%):https://www.aliexpress.com/item/32880908871.html
HD25/HD35(28%):https://www.aliexpress.com/item/32917594486.html
DPS5005(24%):https://www.aliexpress.com/item/1000004290003.html
and here is a coupon($2) for UM24/UM25/TC66:
https://rdtech.aliexpress.com/store/selected-sale-items/923042.html?spm=5261.10636610.0.0.7e013e5ffhSAFH&es=0zoEZ8%2F9sMavJ3MHW8bCx2p1b5wMjgwi
new share:
RD TC66/TC66C Type-C voltmeter ammeter 2 way multimeter
[This tester i received on free for my first satisfied delivery reactive days 12 to ufa everything works fine. When delivered, the packaging was damaged but the tester itself did not suffer a reliable packaging. Sold well done 5 + to him.]
https://www.aliexpress.com/item/32968303350.html
https://rdtech.ru.aliexpress.com/store/selected-sale-items/923042.html?spm=5261.10636610.0.0.7e013e5ffhSAFH&es=0zoEZ8%2F9sMavJ3MHW8bCx2p1b5wMjgwi
new share
RD AT35 5 digits voltmeter ammeter multimeter
[Fast shipping. Shipping 16 days. Track tracked. Packaging is reliable. The product is quality and corresponds to the description! I ’ve known this store for a long time. All products purchased from this seller work without fail! And this time everything is wonderful! Thank you very much to the seller! Product and seller recommend!]
https://www.aliexpress.com/item/33022448123.html
New Share
RD AT34 USB 3.0 voltmeter ammeter multimeter
[Excellent tester, the description corresponds, the device is packed reliably, although in football play. everything works. delivery to rostov on don 14 days. the seller thanks and good luck in business! i recommend of course) ]
https://www.aliexpress.com/item/32897200670.html
NEW SHARE
RD HD35 Trigger QC2.0 QC3.0 Electronic USB Load
[excellent. super fast shipping. it works great. thank you]
and there will be a discount next week, please wait 2 more day
new share
RD DPS5015 DC Step-down Power Supply
[Order received, everything is fine, came quickly and securely packed. The module works as expected. Excellent product, reliable supplier. Thank you.]
https://www.aliexpress.com/item/32702714880.html
new share
RD DPS5005 DC Step-down Power Supply
[Good set, a little soldering. It is a pity that there was no connector for connecting the cooler, i had to cut off the wire. Complete wires are enough to collect all together. The first inclusion was smoke test.]
dont forget this is the second day of big discount
here is the article of the big discount:
NEW SHARE
RD 100v/20A 7in1 OLED Multifunction Tester
[ It’s a good thing superski packed. For what thanks to the seller.Everything works. Error not more than 5%]
https://www.aliexpress.com/item/32788030454.html
it has 29% discount OFF now, you can have a look
view more discount in this link:
https://budgetlightforum.com/t/-/57557
NEW SHARE
RD 33v10A 7in1 OLED Multifunction Tester
[Delivery to the motherland of lenin 14 days. Packaging worthy (foam, pupyrka, scotch). Starts working from about 3,7 v. Measures, for its cost, exactly. Of the minuses: small numbers on the display. In my opinion, you can add switching screens with each parameter built-in button on the ring, but with a large font. The work of the seller and the goods was satisfied]
https://www.aliexpress.com/item/32570250500.html
NEW SHARE
RD UM25 UM25C Type-C voltmeter ammeter
[Great tester! Fast shipping. Packing is very durable. The seller is well done! I recommend.]
https://www.aliexpress.com/item/32855845265.html
RD Tech, I don’t think you need to put up reviews of your products anymore.
We already know they are very good.
I am so sorry, but we post this review is for posting our review, only on this post, we did not put that at other place ,
this is a special post
NEW SHARE
RD UM34C USB 3.0 voltmeter ammeter
[The tester is good, the program on the phone is cool, underworked. Load is also good, soldering quality]
and three peoducts are on higher discount:
product picture product name price
RD TC66/TC66C Type-C PD trigger USB-C Voltmeter ammeter
29% OFF
US $17.30 - 21.74
RD DPS5015 communication Constant Voltage current DC Step-down Power Supply
25% OFF
US $34.63 - 59.00
29% OFF
US $14.19 - 27.51
