edit: Got what I needed! Thanks for the replies.
I sent you a message for the SP36. Not a bad idea for emergencies since you can store 3x 18650s and use a modern usb c charger.
You should be able to get the Catapult V6 from Thrunite with 20% off right from their Web site. It is delivered from Amazon. 20% is the discount code. To get a deal on the SP36 you can contact Sofirn via the Ali store. Illumn is also having a sale that ends tonight which you can get the V6 for 25% off I believe.
Oh nice! Thanks for the heads up.
Keep me in mind ONLY if OP passes on the SP36…I may be interested, depending on details
I need to edit this post. I ended up purchasing one from another forum member that was more local to me. Jump on it!
