Iffn you want it…justify it is EZ.
Yes I am sure its software, but also rendering pictures or videos its slow compared to modern 8 Core Desktop PCs and the fans get noisy
Its not funny to put my Ipad on desktop to watch fluid youtube vids, with a 1500$ laptop
Nice build Lexel. Those Noctua fans work like a charm. I’ve got a few of the 140mm industrial 3000RPM fans in my build and they move some serious air (although a bit loud at full speed). Are you planning to OC the 9900k? Those chips like to run on the hot side, but take pretty well to undervolting.
You’ll have to show us some photos of the completed build!
Yes the Industrial move 2 times the air with very serious static pressure of 7mm H2O, but you trade off with almost 4 times more sound level
For relative silent PC 1500 rpm is enough for 140mm or 2000 120mm
I got 3 big fans pushing air in the case with 300m3 per hour on paper , likely 120-150 in the PC, 1 out, I could even remove the top and mount 2 140mm with an AIO but that would likely increase total noise
Is that like a roomba that lives inside the litter box
IMO, with the new Ryzen 3rd Gen CPUs, I wouldn’t buy the 9900k anymore.
I’d either get the 3800X or 3900X.
i just want to say, AMD has just released their latest 3rd Gen Zen CPU, and it crushes Intel into dust.
but as long as your are pleased with your machine, It’s fine
For certain applications I'm interested in, Intel CPU's work best.
Even if they aren't the best bang for the buck, in the future I will stick with Intel.
I know and still the single core speed the AMD is not better
Multicore the 12 core is better, the 16 core will be far better but on gaming no game supports yet that many cores, price vise the 12 core wont be cheaper
Also pushing the 12 core to the performance in the crushing Intel reviews you need a serious water cooling and pump 50% more power in the CPU overclocked
But I need a stable system I trust not half finished bios on new AMD mainboard with issues
My last AMD was a 500MHz one and it cooked itself because one spring of the CPU cooler broke, that were those CPUs with same mounting like RAM modules
Finally Intels new 7nm 12/16 core will again let AMD look bad, but who knows when they release it, probably not this year
By crushed, he meant that AMD has better single threaded performance/clock.
With better thermals, lower power consumption, and better per thread performance by staying in the same power range, I think AMD took the lead.
However, you still have a great system overall.
Very nice build. I like the 9900k but I early adopted Ryzen upon release and have had zero problems for the past 2 years. I will stick with Ryzen for my next build but there is nothing wrong with the intel since it meshes so nice with nvidia. I’ll probably go all red and navi just to stick it to the man.
Solid setup. I am sure you will enjoy it.
By the way, what games do you usually spend your time on ?
Congrats for your new PC.
However… I wonder why your old machine suffers from lag in YT videos. I have many pc´s much much older that your old one and none of them have any lag in YT videos. Maybe because I dont see the videos in HD, just 360 resolution
If I hadn’t the issues with my old Laptop I would have gotten a 3900X in 4-6 months, maybe even 3950X
In most cases those 4 or 8 more cores are not used, and I am not planning to do heavily rendering of Videos or 3D stuff so 8 Cores 16 Threads is enough
even the 9900K gives me about 2.5 times more speed than the old 4 Core had, the graphics card almost 3 times more
I have ordered this system almost 2 weeks ago
I had to spent now 2.5 hours drive to the PC shop, because they messed up and put all the extra parts, software etc. to another customers PC (which was luckily not already shipped), so I could exchange everything in my box without waiting 2 times for shipping forth and back
Sure AMDs 7nm process gives them a big advantage in the next 18-24 months
till Intel get also 7nm CPUs, they may even skip 10nm at all which they planned to get 2016 running
also many programs support heavily GPU rendering which is a lot more efficient than CPU, so I won’t miss those 4 cores I could have got later
for all of them around 100€, they have the latest aerodynamic optimization and have 6 years guarantee
I made some slight changes, added SATA data cables for HDDs on the cable management side
The worker tested the PC after he had the right spacer for it, I told him the front Fans are too loud not throttling down, he showed me where to do in Bios the fan control, but at home I see those fans are recognized as AIO pump and you cant configure it to fan
Congrats on the new PC, always satisfying to make those big jumps in CPU generations.
Bought one last year to replace my 2012 one, and probably not going to change before DDR5 is here, even if i really want to reward AMD now for bringing competition back to the CPU and GPU market.
I built my PC with a similar case and high quality fans. I really like them but they do need setting up in bios to really take advantage of them being quiet and make use of 4 pin/PWM.
http://www.phanteks.com/PH-F140XP.html
The air filters and sound dampening of this case are really good
yes the ROG Bios are nice, you can even set the fan to the lowest RPM which is around 300 up to 50°C core temperature
on paper, I have 280m³/h at 1500rpm pushing into the case, I know with filter fan grill etc it will be half that value, you can hear them at full speed, but at lowest PWM they are almost not to hear if its not dead quiet in your room and you are pretty close
Maybe it’s a bit overkill, but I decided against an AIO for the CPU, they tend to fail a lot compared to good fans
and finally I have now 4 fans around the CPU
two 120mm 1200 RPM PWM Noctua
- one as back case fan
- the other is mounted 90° to that case fan venting through the top, also gives a nice flow above the top CPU voltage cooling block
CPU cooler was from the shop that build the PC a BeQuiet! Dark Rock 4 which is one of the biggest you can fit in the case
it has the 135mm stock Be quiet! fan, but I do not like that it is quite far away from the cooler having two 2mm thick rubber straps on the fins
- I added a 2000rpm Noctua which has a quite high static pressure
too bad I can only mount it on the pull side, but this will get in hot weather like last weeks enough, and due to drastically new design with less air gap around the blades and spiral form its quieter than the 140mm at 1500rpm, and still
The total system price is definitely not cheap
1694€ for the PC, its build by a company and I have 3 years guarantee on it, I could have saved a bit buying all the components but there is always a risk you end up in a support trap if something fails
- CPU and graphics card alone cost a bit over 1,000€
- 72€ 2. 16GB RAM module
- 134€ Samsung 970 pro M.2 PCIE with NVME
- 1TB Samsung Evo 860 from my old Laptop
- 93€ 4TB Seagate Barracuda for internal Backup, I got also a 4-year external 4TB but I want fast drive inside for easy backup, and an older drive is more risky to fail
- 40.99€ 2 140mm Case fans
- 27€ the 2 120mm 1300rpm Noctua Redux, I simply transplanted the rubber edges from the 120mm CPU fan
- 28€ CPU fan I used the included rubber band that goes all around the frame
- 6€ some more pull through rubber mounts as the normal ones are hard to mount in the back side
so bottom line I get a bit over 2,000€ for that PC, so its not cheap but very solid, quiet and powerful
