13637 posts / 0 new
Klayking
Klayking's picture
My FW3C with SST-20s has shipped, and hearing the reports of how good these SST-20s are, I’m quite hyped. Thankfully my D4V2 has just arrived to tide me over until then.
contactcr
Last seen: 1 hour 55 min ago
I believe mine will be here tomorrow. Look forward to measuring these sst20 with new lenses
JasonWW
JasonWW's picture
Last seen: 7 hours 13 min ago
Nev wrote:
JasonWW wrote:
A blob of solder could be the cause of a short if it touched both a positive point on the driver and a ground point at the same time. I doubt it would melt, though. They tend to blob up when heated like surface tension does a water droplet.
Mine melted the solder on the black wire & disconnected itself.
It’s rare there is enough current flowing through a wires soldered end for the solder to liquify. Once it does, tension in the wire can pull it loose. A scenario that can cause this is if a wire has a poor solder joint to a pad. The poor connection can create a lot of resistance which then heats up.
What exactly happened to your light?
Nev
I posted a video of it but can’t remember which thread I put it in ,
Well one led was discoloured & when on the light was bluish from that led , when on turbo I could smell burning almost instantly,so I took the bezel & lens off to make a video of it to show neal ,and while videoing it I could see smoke & within a few seconds it stoped working & when I inspected it afterwards I found the black – wire was not connected any more ,so I’m guessing it was the black wire was getting way to hot & was melting the insulation but instead of catching fire luckily it melted the solder & disconected itself & therefore shut down.
RapidLux
RapidLux's picture
Last seen: 8 min 44 sec ago
Nev wrote:
I posted a video of it but can’t remember which thread I put it in , Well one led was discoloured & when on the light was bluish from that led , when on turbo I could smell burning almost instantly,so I took the bezel & lens off to make a video of it to show neal ,and while videoing it I could see smoke & within a few seconds it stoped working & when I inspected it afterwards I found the black – wire was not connected any more ,so I’m guessing it was the black wire was getting way to hot & was melting the insulation but instead of catching fire luckily it melted the solder & disconected itself & therefore shut down.
Here is the video post http://budgetlightforum.com/comment/1506560#comment-1506560
contactcr
If it’s coming from the top the LED probably had solder or flux on the dome and it burned up. Without the bezel pressing down the optics and mcpcb the heat wont get to the body as well too.
As a rule of thumb when I get a new light I turn it on in moon and check for dirt. If any exists clean with alcohol.
Nev
Yes that’s it , thanks.
Nev
If it was just the wire to solder back on then I might have attempted to solder it back on , but because one led was duff makes it useless to me as I don’t posses the skills or tools to repair it.
contactcr
Sell it for parts to someone in UK if you get your replacement.
Klayking
Klayking's picture
I might be interested in an offer like that. I wouldn’t mind having a go at swapping the emitters for some 219Bs and reflashing the firmware if I had a spare FW3A host.
See if you can get yourself a replacement first though, because something is definitely not right with the product you received.
KawiBoy1428
KawiBoy1428's picture
Last seen: 7 hours 17 min ago
Copper…
Love
KB1428 “Live Life WOT
contactcr
With the lighting in this room the two others almost look like polished brass
Klayking
Klayking's picture
FW3Cs are arriving? Sweeet!
Emitters? SST-20s? Tint?
M4D M4X
M4D M4X's picture
Last seen: 8 hours 3 min ago
FW3T stonewashed interest list: http://budgetlightforum.com/node/67912
 all new deals are also posted here: deals.m4dm4x.com
if you do not find what you are looking for :
ask MARTIN@M4DM4X.COM - i will save you money!
contactcr
If the shelf is Titanium then you might as well just remove the FET altogether. Makes even less sense than the current version we have Smile
JasonWW
JasonWW's picture
KawiBoy1428 wrote:
Copper… Love
Are all 3 copper or just the middle one?
Firelight2
Firelight2's picture
Last seen: 56 min 32 sec ago
Just got my FW3C today.
Unfortunately, I did not order the SST-20 model. I hadn’t received my SST-20 aluminum FW3A at the time and didn’t realize the SST-20 were going to be so good. Had I known I would have definitely purchased the SST-20 version.
Preliminary impression:
  • HEAVY – 126g empty. 168g with cell inside. Compare to aluminum FW3A which comes in at 99g with cell inside. The extra weight makes it weight about the same as a D4 TI (those weigh 126g empty). I suspect this is a bit too heavy for EDC especially since the aluminum one feels so good in the pocket.
  • Looks beautiful in polished bare copper. However, this IS bare copper. I expect it will look tarnished and used within a few days. I thought about sealing it with something, but I didn’t have any metal sealer on hand and would probably have had to do so before touching the light.
  • Switch feels the same as first-run FW3A. It doesn’t have the slightly reduced travel distance of the second run.
  • Comes with shiny chrome clip. I think this clip looks better than the dark colored one. It matches the stainless steel button.
KawiBoy1428
JasonWW wrote:
KawiBoy1428 wrote:
Copper… Love
Aluminum Copper Aluminum It’s the Copper Glow cast upon the Polished Aluminum gives it a Brassy tint…they did a most excellent job polishing this Copper light…there was still a touch of rouge left behind in the knurl..you can see it on the sink top left…
contactcr
If it sounds too good to be true, it probably is. This is two different lights, 1x FW3C and 1x FW3A.
blind-eye
My SST-20 FW3A arrived. The tint is fantastic and makes what I thought was a good looking SST-20 I had in another light look green at low levels. The switch however sounds a little crunchy if you press down on it in the middle. Regarding the edges of the switch the edge of one side is smooth and silent (how I think its supposed to be compared to the middle?) while the other side has a crunchy sound and doesn’t always register a click. Pressing down in the middle of the switch always registered albeit not in a pleasant sounding/feeling way.
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 15 hours 28 min ago
!{width:100%}https://i.imgur.com/N4lk1Q4.jpg!
Are the curves across the beam or at different power levels?
contactcr
All the default stepped power levels using a GA cell.
timbo114
timbo114's picture
Last seen: 3 weeks 2 days ago
Firelight2 wrote:
* Looks beautiful in polished bare copper. However, this IS bare copper. I expect it will look tarnished and used within a few days. I thought about sealing it with something, but I didn’t have any metal sealer on hand and would probably have had to do so before touching the light.
Wear gloves, wipe it down with pure lemon juice, rinse in hot water, wipe down with iso alcohol.
Wipe down with hard automotive paste wax, let dry for a few hours.
Wear gloves to remove wax and buff to a new sealed shine.
Tally-ho
Tally-ho's picture
Last seen: 10 min 15 sec ago
Stonewashed Ti looks cheap and ugly and ruins a damn fine material (except for heat transfer though).
Leave this bad idea to cheap knives manufacturers.
raccoon city
raccoon city's picture
Last seen: 6 hours 1 min ago
StonewashedGate!
teacher
teacher's picture
Quote:
Stonewashed Ti looks cheap and ugly and ruins a damn fine material.
This is your personal preference/opinion, which is fine. But it does not necessarily reflect a general consensus. People like raw, polished, stonewashed, & bead/sand blasted Titanium.
Personally, I like stonewashed & bead/sand blasted. It beautifies it & adds character as far as I am concerned.
Big Smile … Many knife makers/manufacturers stonewash or bead/sand blast the Ti handles on their knives. CRK is a prime example, and his knives are not exactly cheap.
Lund1660
Last seen: 2 weeks 4 days ago
I just got my copper fw3c. Decided to change the 5a to sst-20. One of the legs of the new style optic is cut off shorter than the other The messed up thing is their is a small Phillip screw taking up the space for the missing portion of leg. Who’s the genius that came up with this idea?
Firelight2
That’s not how it’s supposed to work. Sounds like yours was installed wrong.
The Phillips screw is designed to sit in divot drilled partway through the underside of the star. It is NOT supposed to sit in one of the holes for the legs. All 3 legs on my copper FW3C are fully intact.
Lund1660
What does pillip screw do? What’s it purpose?
teacher
teacher's picture
It is to eliminate the possibility of the MCPCB turning & severing the wires when the bezel is tightened.
