I love stonewashed titanium. And I would buy one for sure if the head would be copper. Otherwise I’m only interested.
I am interested in 1 FW3T stonewashed
Possible interest. I personally like bead blasted titanium, what’s the difference between stonewashed and bead blasted finishes?
I want 1 FW3T stonewashed 100%! ( SST20 4000k) …
Yes, why ? I always thought the coolest running led was the XP-L…
In for 1, 100%!
I want 1 or maybe 2 FW3T stonewashed 100%
I am interested in one. I don’t have a titanium light.
Will buy one light 100% - SST20 4000K
Thanks!
I “may” be interested in one… but not sure. Maybe if I know the exact final prize
I am interested in 1 FW3T stonewashed SST20 OSRAM
Neal had written about the SST20 - maybe a missunderstanding
they will test the full Ti of course and maybe dactivate the FET if needed too
I am interested in a FW3T stonewashed (SST20).
That should be great option for modders, 219B for example
The SST-20 5000k/6500k is the most efficient in a light like the FW3A.
Actually I think XPL HI is the most efficient (in terms of lumens per watt). It produces more lumens and less heat than even the cool white SST-20.
The cool white SST-20 is throwier though. In terms of lux per watt it might be more efficient.
No, it’s actually more efficient.
See the title, it is another test. do I really need to explain this everytime? I abuse an LED and see what it does, same as all the rest of my victims subjects. Thanks to CRX for donation. Well, you have seen the XP-L HD test, so here is the HI. It tracks exactly the same as expected, just less output from the lower bin. I could have kept pushing it harder but I saw no reason to blow it. The numbers could be a tad low in the high end as my heatsink fan is messed up and I had to rig something …
I got this emitter from Kaidomain on a 20 mm MCPCB. [image] Mounted on a CPU heatsink with a nice splash of thermal paste and over the top 16 AWG wires. Purchase link: http://kaidomain.com/Luminus-SST-20-L2-BA-White-6500K-LED-Emitter Data sheet. Exact order and bin code: SST-20-WCS-A120-L2651 VK BA Where SST-20=self explanatory W=white LED C=cool white S=CRI 70 A=solder pad configuration (3.25 x 3.25 mm) 120=viewing angle, 120° L2=flux bin rated at 85°C, 530-560 lm at 1500 mA VK=fo…
Up until 5A, the SST-20 is more efficient than the XP-L HI.
Is it possible to buy a non stonewashed FW3Ti?
Interested in one with HiCRI Samsung LH351D
