Can it be that shipping costs have extremely increased lately? EUR 4,13 for standard shipping of two Golisi S43 batteries? Where applicable, priority direct mail (air transit) is still cheaper than standard shipping with 4-5 Euro, i.e. $ 5-6. :O
Thanks.
This would be a good time to grab a Rofis R1 or R2, though I’m hesitant to order anything else from banggood, since they still haven’t shipped my Lumintop EDC05C that I ordered 5-24-19, even though people who ordered a month later already have their lights.
This is the only real problem I have with the FT04 so far. "Only" 2 amps is not a big deal to me, but.. Leave charging completely out, or use a 'normal' connector. My true feelings about being saddled with special type of charger for an otherwise drool worthy light are most likely against the BLF TOS... :FACEPALM:
New deals: Niwalker MM6S 18650+21700 & BK-LB11SV2 & BK-LR7SV1 & MF5SV1 Mini
I cannot post the prices (search engines) so just try my codes to get the LOWEST prices for those Flashlights! ;)
OR get them prices in my deals list!
please follow the links below to the shop for detailed description
Niwalker Vostro BK-LB11SV2 Long Throw Search Light 2650 Lumens, 1900 meters throw distance, double switch design
(Choose the main switch is on the left or right, base on your operation habits, pls remark when you placing order!)
Features:
● One of the most powerful long throw search lights on the market.
● Maximum output up to 2650 lumens and an ultra-long beam distance of 1900 meters.
● Highly efficient constant current design offers maximum output and runtime
● Magnetic ring control switch allows you to select desired output easily
● Advanced thermal protection circuit prevents overheating
● Unique smooth reflector design provides great throw beam distance and beam pattern
● Aircraft grade aluminum, mil-spec hard anodized for maximum wear
● Toughened ultra-clear tempered glass lens with anti-reflective coating
● Large cooper heat sink pad for superior thermal conductivity
● LED indicator turns red(below 12V) to alert user to switch lower output mode and recharge batteries in time.
● Front red/green LED for easy following.
Features:
Highly efficient constant current design offers maximum output and runtime,Maximum output up to 10000 ANSI lumen.Waterproof & Shockproof- The LED tactical flashlight made of Aircraft Grade Aluminum, with a camera screw hole in the rear of the flashlight; delicate protection, IPX7 waterproof design,1.5 meters shock proof.Smart triple Multi-function clicky side switches.Advanced thermal protection circuit prevents overheating Unique smooth reflector design provides great throw beam distance and beam pattern,intense beam up to 850 metersToughened ultra-clear tempered glass lens with anti-reflective coating.Large cooper heat sink pad for superior thermal conductivity.LED indicator turns red(below 12V) to alert user to switch lower output mode and recharge batteries in time.
