It’s not back luck, it’s bad soldering that lumintop is doing. Mine had the pointy bit of the spring almost touching the trace. It was also an awful soldering job, with the spring way off center and only held on in one spot. I resoldered things to make it safer, after reading about the incident.
I suggest everybody check their spring soldering. Most are probably fine, but it’s random.
Indeed it is my opinion as I would not speak for other people I don’t know and would never pretend to tell them what to think about Ti stonewashed.
Bead blasted has a mat finish and makes Ti looks a bit darker grey.
E.g. : the Haiku bead blasted looks really nice :
[/quote]
I don’t mean bad luck in the sense of what happened when it fell. I mean bad luck in the sense of getting an item which was assembled badly — being the unlucky person who got a dud.
If this was happening frequently, that wouldn’t be luck… it’d be a broken manufacturing process. But there’s only one known case of this happening, and one (yours) which looks like it could have been a near miss. So unless more people run into the same issue, I’d consider it a “ask vendor to send new hardware” sort of issue instead of a “ask manufacturer to fix their process” sort of issue.
I very much like that finish :+1:
Who’s selling the FW3T? My google-foo appears to be failing me at 6pm…
FW3C SST-20 has arrived in the UK!
Initial impressions:
  • It’s heavy.
  • It’s pretty.
  • The new button is so much nicer than the old one. Lighter to press but with a more positive click. Much quieter and has less wobble in the action too, like a proper E-switch should.
  • The SST-20 emitters are the best I’ve seen yet. They’re rosy on maximum output, but unfortunately seem to still be the tiniest bit green on lower levels. Still, they’re not bad at all and I’ll definitely be happy using these. A big upgrade over all previous SST-20s I have used.
  • The new optic is okay. I bought a clear Carclo and I’m going to swap it out for some extra throw though.
  • It appears to be running a new-ish version of Andúril. It has the fancy two stage lockout moonlight mode, however when not locked it still comes on in moonlight as soon as you hold down the button. Shame it’s not totally up to date, but it’s newer than the version on the first run of FW3As.
  • I sent an email and a message to Neal about my choices regarding the optic dilemma, but it seems that neither got read as I was sent the light with the plastic optic immediately anyway. No worries, I can swap a new optic in myself, but I feel bad for the guy if he has been that snowed under that he can’t manage to read a message even with several weeks to do so.
TL;DR It’s good!
Edit:
Okay, I can’t use the Carclo that was included with my order because Neal hasn’t included the glass lens he promised! Now what?
Ask him to send the glass lens.
Also double-check your box. Mine had the glass lens inside the little bag with the o-rings inside the box.
One of mine was in the o ring bag and one was between the box and the outer sleeve, it just fell out when I was trying to get those damn things separated.
Also, side observation. One of mine had a clear “all in one” plastic optic and one was frosted. I guess they made a few versions to try out.
I’m with teacher on this one, I personally love stonewashed Ti. Not everything needs to be a perfect shiny material, some dings, scratches, marks, patina is what makes it unique. CRK along with Zero Tolerance, Spyderco and numerous others use stonewashed Ti on their knives and it looks amazing imo.
No one yet, there is a thread about the stonewashed version to gain interest.
Aha, so is mine! I didn’t even see it in there. Thanks for the tip!
I’m not sure if it’s just my imagination or not, but the beam looks a little bit more green when I’m running it with a Carclo + glass instead of just the plastic optic. Possible side effect of AR coating? I might keep running the plastic optic if this is the case.
  • I have a bead-blasted titanium Olight S1 and I do not like the finish. It feels like holding a stick of chalk. Similar to the rough finish of my white or blue anodized aluminum Emisar D4s.
  • I find these rough textures only feel good in the hands if I just rubbed them with moisturizer. But if my hands are dry, it feels unpleasant.
  • Bead blasted titanium also doesn’t look special. It looks very similar to grey anodized aluminum.
For titanium, I much prefer polished. It feels good in the hands, is durable, and looks classy.
The stock AR lens does make it more green. Look at the CIE chart I posted a page or so back. The UCL lens is probably similar to the plastic lens.
Ah yes, thanks for the great chart. That’s quite a difference.
As this light will probably spend most of its time being used around the house, I’ll keep the plastic optic installed. The flood is better than having extra throw in this case, and I would very much like to take the slight tint improvement this optic offers.
Yes, but you can probably eliminate the tint difference by polishing off the AR coating. That’s what I’ve been doing with all of mine, and it seems to help.
As quite a few different finishes were and are tested and are proposed : aluminum with different anodization colors, sand/bead blasted copper, polished copper, stonewashed titanium, could it be possible to have a version with machining marks like it was supposed to looks like :
Here I’m speaking for myself, I’m not very demanding concerning the material used, I will be happy with aluminum or copper or brass (preferably) or titanium+copper but could we have at least and at last THE version with machining marks, please ?
I would be eternally grateful for a brass with machining marks and SST-20 4000K, or aluminum with maching marks and clear anodization, i’m pretty sure they can make clear anodization right.
I don’t think they are going to do clear aluminum anodizing since they had trouble getting it to look uniform. However, perhaps they could do a limited run bare aluminum version with no anodizing?
Yes, bare AL would be an instant buy for me.
This thing is supposed to keep the Copper hard for a long time right?
Oh is that ring supposed to go on the flashlight…?
:smiley:
Well, there’s been at least one other report of the problem, plus a few other reports (in the same thread) of people saying the soldering job was really bad on their light.
I think Lumintop does have a manufacturing issue when it comes to soldering the tailcap. Maybe it’s just one bad person on the assembly line, or maybe the design prevents easy soldering. I know that I could only manage to solder two points down, but I admit my skill is crap.
Your linking to Goshdogit’s post? There is no mention of a problem there (maybe just poor soldering if the spring?).
Some other people also have poor solder joints on the spring. Up to 12A of current can flow through the spring. Lumintop should look into fixing this.
YES, But-
If left on beyond 4 hours … you may need to seek medical attention.
(Or pay a quick visit to the nearest ‘cell’ house :smiling_imp: )
