Congrats on the new PC, always satisfying to make those big jumps in CPU generations.
Bought one last year to replace my 2012 one, and probably not going to change before DDR5 is here, even if i really want to reward AMD now for bringing competition back to the CPU and GPU market.
I built my PC with a similar case and high quality fans. I really like them but they do need setting up in bios to really take advantage of them being quiet and make use of 4 pin/PWM.
yes the ROG Bios are nice, you can even set the fan to the lowest RPM which is around 300 up to 50°C core temperature
on paper, I have 280m³/h at 1500rpm pushing into the case, I know with filter fan grill etc it will be half that value, you can hear them at full speed, but at lowest PWM they are almost not to hear if its not dead quiet in your room and you are pretty close
Maybe it’s a bit overkill, but I decided against an AIO for the CPU, they tend to fail a lot compared to good fans
and finally I have now 4 fans around the CPU
two 120mm 1200 RPM PWM Noctua
- one as back case fan
the other is mounted 90° to that case fan venting through the top, also gives a nice flow above the top CPU voltage cooling block
CPU cooler was from the shop that build the PC a BeQuiet! Dark Rock 4 which is one of the biggest you can fit in the case
it has the 135mm stock Be quiet! fan, but I do not like that it is quite far away from the cooler having two 2mm thick rubber straps on the fins
- I added a 2000rpm Noctua which has a quite high static pressure
too bad I can only mount it on the pull side, but this will get in hot weather like last weeks enough, and due to drastically new design with less air gap around the blades and spiral form its quieter than the 140mm at 1500rpm, and still
1694€ for the PC, its build by a company and I have 3 years guarantee on it, I could have saved a bit buying all the components but there is always a risk you end up in a support trap if something fails
- CPU and graphics card alone cost a bit over 1,000€
- 72€ 2. 16GB RAM module
- 134€ Samsung 970 pro M.2 PCIE with NVME
- 1TB Samsung Evo 860 from my old Laptop
- 93€ 4TB Seagate Barracuda for internal Backup, I got also a 4-year external 4TB but I want fast drive inside for easy backup, and an older drive is more risky to fail
- 40.99€ 2 140mm Case fans
- 27€ the 2 120mm 1300rpm Noctua Redux, I simply transplanted the rubber edges from the 120mm CPU fan
- 28€ CPU fan I used the included rubber band that goes all around the frame
6€ some more pull through rubber mounts as the normal ones are hard to mount in the back side
so bottom line I get a bit over 2,000€ for that PC, so its not cheap but very solid, quiet and powerful
I still think you got an excellent price. It has been a while since I’ve priced anything. But in the past, I’ve seen online custom build shops charge more than that for a much lesser machine built.
Something is seriously messed up then. I have a 7-year-old Lenovo laptop with i5 CPU which cost around $800 back then, and it still plays youtube videos just fine under Windows 7.
Regarding the premature demise of the $1500 4 year old laptop, I don’t think it’s a software issue, it seems more like a cooling issue where the system can’t dump enough heat and downclocks itself , suggesting part of the cooling system has failed . If you open it up, blow out the dust, check that the fans work, then refresh the TIM, thermal pads, and consider copper shims where appropriate it should perform more like it did previously if not better. It could easily be something as simple as fluff blocking an intake so maybe with a bit of work this system could be restored to functional use.
As for Windows 10 support, that should also be good on a reasonably high end laptop made in the last 4 years - my partners Lenovo is much older yet has Windows 10 drivers - *nix support should be fairly good as well. If you can’t find drivers for that specific model, a good tip is to look for enterprise grade systems built around the same time as they are often contractually required to support those for much longer than consumer systems, and they often use compatible drivers.
I blow out every year the coolers with compressed air of my laptops, I did it like a month ago when problems started, but it didn’t help, the fans run and move a decent amount of air and heat
I will put the original saved OS backup over the SDD when I am finished with moving, and then will do stress test with Prime95 and GPU benchmark to see if it is still bad
I had also in the past 4 years on my Laptops
- 2 times the graphics card replaced under guarantee (DELL and XMG)
I gave my 2. last Laptop 2000$ to my dad when it was also about 3 years old, but it simply died by main board failure when he had it less than a year, I sold the SSD, CPU and Ram for like 250 bucks, graphics card was a fast NVIDIA but integrated in the main board
This is mainly the reason I am going back to desktop PC, you can replace dead components
-single core IPC of new Ryzen is acceptable now, not too far from intel, i doubt that you will notice this difference in daily using
in gaming, some latest benchmarks (with latest BIOS. it’s new CPU, so BIOS must be updated to optimize them obviously), show that Ryzen is equal or better than intel
-and to crush Intel CPU, you dont need custom Water Cooling, actually you can use stock fan, it’s much better than the intel one
I definitely plan to go noctua air cooler for my next build.
Currently I have a large Cryorig air cooler for my i5 6600k and I’m a big fan. I don’t trust most AIOs long-term just in the rare event they go bad.
I have never been able to get atmel studio 7 to run on ANY device. Not my win10 pc or win7. Studio 6 will run on windows 7, or a windows 7 pc upgraded to windows 10 but I’ve never had it working on a windows 10 fresh install.
