They’re not on pins with PWM functions, so it doesn’t have a simple way to adjust the brightness. Even if it did though, that would use more power than just leaving them on high mode all the time. It’d require keeping the MCU awake to generate the PWM waveform, and even at a slow speed that increases the power usage significantly.
However, if you really want fancy RGBA color patterns, I have that working nicely on my lightsaber… and it lets the user configure whatever patterns they want, by building them out of basic waveforms in color space.
Having initially thought that the auxillaries are too bright, I have found them now helpful for bathroom trips at night. I have them set on bright red in lockout mode. I then have a choice between red or momentary moon mode. In the morning, 5 clicks to unlock and turn the auxillaries to off, which is my usual auxillary preference for when the light is unlocked. However,for fun, when showing off my light, I then switch it to bright rainbow.
Received mine today and I love it. I can confirm that the secondary LEDs are brighter and they are more useful than on the D4S.
Best colors are RED, BLUE and GREEN because other colors are obviously only a mix of the 3 primary colors.
I hope not , why change something when it’s almost perfect, if there is a new version then I hope Hank will give the option of keeping ramping V2 instead of forcing anduril on us (me).
I dream about D4S with Osram KW C*LPM1.TG and Andruil - for a price significantly lower than a modded light.
21700 and Attiny1634 with programming pads would be nice as well but not particularly important…
Actually I dream about BLF light that would compete in that niche.
And I have a few ideas how to improve over Emisar.
I initially thought that the bright mode for the auxillaries was too bright, until I found them bright enough to help light my way to the bathroom, at night. I set lockout with bright red auxillaries so at night I can switch between Red or momentary moon. When I unlock in the morning, my auxillaries are usually in dim voltage mode.
I am sorry if I wasn’t clear. During the day when I unlock my light, I have the auxillaries set to monitor/report the state of the cell as to its charge. When I do so, I have the auxillaries in dim mode. (When the flashlight is mostly charged they are blue.)They are easy enough to see unless in bright sunlight, but then,why would you be looking at your flashlight?
