Astrolux S43 - New model (On Sale)
249 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 23 min 56 sec ago
shirnask wrote:
Jason, I have both the S43 and the S43S, both have a solid contact in the head and dual springs in the tail – see below
Neat, it looks like they changed production at some point.
Click this to go to signature links.
JasonWW
JasonWW's picture
BabyDoc wrote:
Why do my undented cells only work correctly when I find the sweet spot for tightening. Only if I tighten fully the light misbehaves. If I back off from fully tight, I can get it sometimes to work correctly.
Therefore, I am not following you when you say that the head and tail cap can’t be tighted down all the way. That might be true if the cell was way too long. But my cell can’t be way too long if just a small dent fixes things. Furthermore, as I just said, because it will work sometimes with an undented cell when head and tail are NOT tight.
So could my undented cell, sandwiched between the solid head contact and fully compressed spring in the tail, be placing undue pressure on the boards controlling the light when head and tail are fully tight? Otherwise, how would you explain that loosening the head or tail might get it to work correctly?
That is bizarre and doesn’t really make sense. Maybe someone has a theory?
vresto
vresto's picture
Last seen: 3 min ago
question-i want to change the nichias with quad xpl neutral…anyone tried it already? where in Europe we can buy in this size quad mcpbs with leds? ME is too far and too expensive,thanks.
EDC- Jetbeam E40R,Emisar D4V2 XPLHI
Headlamp-Thrunite th30
Texas_Ace
Texas_Ace's picture
Last seen: 2 hours 6 min ago
You can swap the LED’s on the mcpcb and it will work just fine.
If you want to order an mcpcb with the LED’s already installed that could be a problem. The mcpcb is custom as far as I know.
vresto
vresto's picture
okok…i would do it…but i check the fasttech…..where they are available.is this size ok?will it fit on the star and under the optic?
https://www.fasttech.com/products/1609/10009336/3594907-cree-xp-l-hi-v2-...
Texas_Ace
Texas_Ace's picture
That would be VERY hard to make work in this light. The stock mcpcb is all one piece with 4 LED’s mounted on it.
It would be far simpler to just reflow new LED’s onto it.
vresto
vresto's picture
okok….iam looking for them on fasttech…dont see them?
just leds…
Texas_Ace
Texas_Ace's picture
Yeah, I don’t think anyone sells the complete mcpcb as it is custom only for the S43.
vresto
vresto's picture
yes…but solo leds without board…nw
Texas_Ace
Texas_Ace's picture
vresto
vresto's picture
study study.but not succesfull…how to got simply to the menu and get modes instead ramping please?
what do you recommend? turbo timer or turbo til death..?
JasonWW
JasonWW's picture
Are you asking how to go into the menu and switch to mode sets?
First you have to hold down the button for 8 seconds. I recommend you ramp down when doing this.
You will see 2 fast and one slow blink. Release the button when when it first blinks. Then do 1 click after you see the 2 fast 1 slow. This means you’ll be clicking one time about a second after you release the button.
Then you can let it cycle through the rest of the menu. Once it stops blinking it is ready to use.
I don’t use the Turbo Timer, I set it using the temperature.
varbos
Last seen: 7 hours 16 min ago
So I guess a S44 will be revealed soon. What features would people like in the S44 ?
Personally I would like:
- Better optics
- Better driver efficiency
- Better charging efficiency
- Better thermal throttling
- Flat bezel (not the crenulated type)
- Get rid of spike (helps to make it a little bit shorter)
I guess that aux LEDs are ‘all the rage’ lately so maybe it will feature these. Personally I don’t need them, they are groovy but not important.
I think it will be hard to beat Emisar D4v2
shirnask
shirnask's picture
Last seen: 4 hours 48 min ago
Something to use the spikey tail caps for:
xevious
xevious's picture
Last seen: 16 hours 20 min ago
Interesting. Did you craft your own or is this a screw-in magnetic stud you can buy somewhere?
shirnask
shirnask's picture
I used 2 N50 8mmX3mm Neodymium Magnets which fit nicely in the hole for the spike (which I will never use anyway) and just glued them in. works well enough to be useful to me.
BabyDoc
BabyDoc's picture
Last seen: 22 hours 23 min ago
Could you supply us with a source for these magnets?
I like your idea.
shirnask
shirnask's picture
I have had these for a while and I am not sure where these came from. I have used several sizes for different projects around the house. I did a quick search and found these.
Banggood
Amazon
JasonWW
JasonWW's picture
varbos wrote:
So I guess a S44 will be revealed soon. What features would people like in the S44?
Really? I’ve heard nothing.
- Better optics
Here are my thoughts.
Optics that are not blocked and rob you of lumens would be a nice upgrade.
I don’t care about driver efficiency.
What is wrong with charger efficiency? You want a higher charge rate?
Thermal throttling seems fine once adjusted. You can’t expect the factory to adjust each light by hand.
I don’t care about bezel shape.
Loosing the spike is a good idea. Maybe mount a removable magnet inside tail cap like a lot of other lights.
I don’t care about aux leds.
Texas_Ace
Texas_Ace's picture
The driver efficiency is actually just as good as the D4 that people compare it to, they use the same design and components. The efficiency loss is the optics not the driver.
The charge rate can be adjusted with a resistor change, I had it setup to charge at 1A at first but since it was designed for 18350 cells it was worried that might be too fast for the small cells so it was dropped down to 500ma last min.
Thermal performance is about as good as you can expect for such a small light honestly. If the exact step down temp is the issue, the default could be raised in firmware I suppose but otherwise it is a simple matter of calibrating your light to your own personal preferences.
varbos
I did not say I heard anything either, just that I guess. They have done a new one annually.
S41: 2016
S42: 2017
S43: 2018
S44: ????
According to maukka’s review 25% of energy is wasted.
With each year that goes by we expect better from our products, even ones which are ‘fine’.
I do not expect the factory to adjust each light by hand, however surely there are areas for improvement. Look at Emisar D4 for an example of this in practice. Many thought the thermal throttling was ‘fine’ and yet it improved several times. I am thankful Hank and TK did not say v1.0 was fine and call it a day.
xevious
xevious's picture
Thanks. I don’t have my S43 with me right now, so I can’t measure it. Is the 8mm x 3mm where the magnet fits in that “dish” area around the screw hole and the 3mm height is flush to the rest of the tail cap? Also, what kind of glue did you use? I expect Super Glue wouldn’t be a good choice due to lateral vulnerability.
aginthelaw
aginthelaw's picture
Last seen: 9 hours 25 min ago
For a minute there I thought he drove the spike Into the filing cabinet
never fear shadows…it means a light shines nearby
shirnask
shirnask's picture
Superglue works fine. I have done 3 with superglue and one with epoxy – all have been in use for 8 months or more without issue.
2 – 8mmX3mm
4 – 8mmX2mm
Not as much volume for the adhesive this way
which ever you use just load up magnets and adhesive – cover with a bit of wax paper and set some kind of ferrous metal on top to get the magnets to sit flush with the top of the cap
Raymond Russell
Last seen: 7 months 2 weeks ago
Texas_Ace wrote:
Out of curiosity, if the battery tube on the S43 was changed, would that be the only cosmetic issue most of you have with the light? I think it might be too late for the S43 to be changed but figure I could give it one last try. The tailcap striker is already removable, makes the tailcap a bit taller then needed but that is about it. The bezel is the only other real complaint I see here how big of a deal is it? it is not that aggressive and is not that bad. I got permission to post the prototype light I got, these are pictures from Mateminco, the ano looks a lot better on mine in real life then the picture look. I think it is pretty good looking in the real world, the picture do not do it justice. if I have time I might try to get one of mine. !{width:50%}http://pballandmore.com/images/2018/S43-1.jpg!:http://pballandmore.com/i... !{width:50%}http://pballandmore.com/images/2018/S43-2.jpg!:http://pballandmore.com/i... !{width:50%}http://pballandmore.com/images/2018/S43-3.jpg!:http://pballandmore.com/i... !{width:50%}http://pballandmore.com/images/2018/S43-4.jpg!:http://pballandmore.com/i... !{width:50%}http://pballandmore.com/images/2018/S43-5.jpg!:http://pballandmore.com/i... Thanks for information
BabyDoc
BabyDoc's picture
Raymond Russell wrote:
Texas_Ace wrote:
Out of curiosity, if the battery tube on the S43 was changed, would that be the only cosmetic issue most of you have with the light? I think it might be too late for the S43 to be changed but figure I could give it one last try. The tailcap striker is already removable, makes the tailcap a bit taller then needed but that is about it. The bezel is the only other real complaint I see here how big of a deal is it? it is not that aggressive and is not that bad. I got permission to post the prototype light I got, these are pictures from Mateminco, the ano looks a lot better on mine in real life then the picture look. I think it is pretty good looking in the real world, the picture do not do it justice. if I have time I might try to get one of mine. Thanks for information
Are these pictures of a S44 prototype? If so they aren’t accessible to me. I never understood the complaints about the smooth battery tube, especially when people don’t complain about the same issue with the FW3A/C. As far as the Tailcap goes, I think the spike there is rather silly, especially with the S43S that comes with the 18350 tube. That small tube,with the crenulated bezel makes this light look like a little tactical wannabe. Does anyone really use the spike on this light? It’s then too sharp to keep in a pocket.
JasonWW
JasonWW's picture
No, it’s post 43 of this thread from about 10 months ago.
It shows the battery tube for the Mateminco version of the S43 called the S03.
skinny_tie
skinny_tie's picture
Last seen: 1 day 8 hours ago
Texas_Ace wrote:
joechina wrote:
If you wait a bit, I am sure someone will make an Andúril version.
If it is popular I am sure someone will at some point as well.
Has anyone managed to flash their S43 with Andúril yet?
varbos
This is how my S43S from BG came:
https://i.imgur.com/nLSMWd0.jpg
https://i.imgur.com/EM0Yq3V.jpg
There’s a blob of solder joining one pad to the outer ring of the driver board. And the other pad does not have any solder at all.
Here is how it is supposed to look:
https://i.imgur.com/t0fMppC.jpg
Can anybody explain what I am seeing? Bad workmanship? A returned light which had to be repaired?
It seems to work okay..
JasonWW
JasonWW's picture
Weird, IDK.
