All of mine are using a thinner mcpcb than factory with a plastic centering ring and tighten down on the centering ring mcpcb fine and have no fitment problem at all.
Maybe the thinner mcpcb is the key to these working correctly.
I preferred the KD 23424 also, they look identical but the beam seems better with the 23424. Good to hear they look good with a sw45k.
both KD reflectors produce better beams than the setup w the stock reflector
but the KD reflectors dont let the bezel close down as far, the O ring is exposed, without using any centering ring:
if I add a thin round centering ring then the gap at the O ring gets bigger
when my RRT-01 was modded to sw45, I dont know what mcpcb thickness was used
The beam has at least 3 obvious rings in the spill. Maybe because the LED sits lower than stock.
I much prefer the beam from the KD reflectors,
thanks for doing all the legwork to find them, and then sharing the info…
Many thanks to jon and modderator for all the info you put here. Much apreciated!
I have ordered bunch of reflectors and due to work i was not home for last few months but your info will help me solve the mess i have created at my tiny “shop”.
EDIT: i still need to post my homemade triple conversion… hopefully in August when i reach my doorstep
isn’t clemence at Virence making these ?.
wouldn’t mind a custom built one HCRI Optisolis
Spoke to clemence and shared some thoughts about it. He is trying to finish some protos of his MCPCB for RRT. But he’s busy as hell so it will take some time plus suplier messed up delivery of some boards if i understood him correctly…
But lack of time is the main reason
Is there any feasible way to trim down the Kai Domain reflector just enough so that it fits properly in an original RRT-01?
I think grinding/sanding the trim on top of the reflector could allow reflector to drop a bit onto the MCPCB
fwiw, my single sw45 Original RRT-01 is using a NOTstock board plus liquid tape.
I actually have not tried the KD reflectors in an UNmodified stock RRT-01.
It is also possible that the exposed Oring in my modded RRT-01 is caused by the height of the mcpcb, instead of being caused, as I suggested, by the lip around the KD reflector.
someone else needs to provide a photo of their reflector mod, and whether their O ring is exposed.
meanwhile, here is a red GID mod to a triple sw35 modded Jetbeam Eye10 from pinkpanda:
GID inserts are available from CRX:
imo the red is a waste of time, it is super dim, and only lasts a few seconds after being charged by light.
does an AA adapter from sunwayman fit the Original RRT-01?
also just to consolidate
18650 tube options for the Original RRT-01:
This pic just never seemed right to me some how.
So I looked at mine with the KD reflector and shaved LH351D installed.
Mine covers the o-ring completely and the space that’s left is visible and that’s were you have your o-ring installed.
This is with the bezel unscrewed to show where the o-ring goes.
I think you got your o-ring installed in the wrong place jon_slider. Might explain why your having problems with the KD reflector swap and exposed o-ring.
Completely factory RRT-01 in the front, KD swap reflector in the back.
thank you Sir!
I agree, that is not where the O ring belongs
I need a tighter O ring, that is not being pushed by the bottom of the bezel
when that light gets back from passaround
on left is a stock Eye10 mcpcb and LED w a kaidomain reflector swap, on right I confirm an RRT-01 with Oring under the bezel
and the height difference of the kaidomain reflector
That .5mm saved by the smaller 1.5mm thick copper mcpcb would come in very handy in helping with that difference.
I checked last night 5 different jetbeam original mcpcb’s, some copper, some aluminum. All of mine measured right at 2.04mm in thickness measured with accurate Mitutoyo calipers. The 12mm copper mcpcb’s I recommended measured 1.5mm in thickness.
thanks for the refence shot w stock thickness mcpcb
and that makes sense,
the thinner mcpcb will narrow the gap
Apparently there were some changes to the threads, I have an old RRT-01 and I have two Astrolux S41S and one S41 and none of the battery tubes fits the thread of the RRT-01, unfortunately
I tried the V10R ti extender with no luck. I have the V11R aluminum extender but I just don’t know where it is at the moment. :person_facepalming:
I think both extenders have the same threads though.
If your talking about the AP-05 AA extender, I have checked and it does not fit
[I tried the V10R ti extender with no luck.
thank you both
I disassembled my last factory older RRT-01 today. While I was there, I measured the bottom shelf where the mcpcb sits.
The shelf measured 15.10mm in diameter. A 16mm mcpcb can be used if filed down to 15mm. If doing the KD reflector swap a mcpcb of 1.5mm thickness would be better to allow the bezel to screw down to almost factory position. A 14mm mcpcb in 1.5mm thickness would work best if you can source one.
This info is for the older original RRT-01 not the new model.
You can find the 16mm x1.5mm mcpcb’s here.
I was not expecting the old RRT-01 to have a smaller shelf than the TC-R1, but there you have it… Thanks for the information moderator007.
After I get the supplies from KD to mod the TC-R1 to Nichia 219b, I am going to look for a 2016 RRT-01…
