Way to go Blue, I admire the spirit!
"The more they overthink the plumbing, the easier it is to stop up the drain."
Captain of Engineering Montgomery Scott (Scotty), USS Excelsior, Star Trek III: The Search for Spock
Guess I'm an outlier here.
I'm a hands-on, button-pushin' guy. The more automation, the more things can go wrong. I'd prefer a minimum of automation, only what's necessary for safe operation. Otherwise, this looks like an outstanding device that could appeal to advanced muggles outside the flashlight community.
slmjim
I will buy one when available
Thanks Blue for your generous act.
I am exited by the ambitiousness of your mission statement, BlueSwordM, as well as your intitial list of features. It’s in the true spirit of BLF. Stick to your guns!
It’s confusing to me that some BLF’ers who agonize over every detail of flashlight hardware and firmware seem content with a simple Nitecore or LitoKala charger. If that suits your needs, hey, that’s great, but why would we want a BLF charger to emulate that? It would be like a BLF 2AA Maglite.
Yeah, I hear you. The SkyRC MC3000 did not not start out as a CPF project, but it kind of turned out that way. The thread has 5200 posts, of which 200 or so are by HKJ. And a lot of development work was put in by a member who shall go nameless. And the result is the benchmark for a universal analyzing charger for cylindrical cells, with enough of a market, apparently, to keep it in production.
I am definitely 1000% IN to purchase a BLF custom designed charger!
Simply awesome idea, thank you BlueSwordM .
Sign me up please i`ll be more than happy to purchase some.
I’ll keep my eye on this. I’m interested, although not convinced I NEED another charger…
@azj, that’s why I’ll convince you.
@CLB, thanks for the support. I saw that thread at CPF. Not as long as the Q8 and FW3A threads, but still very long.
There’s actually another good reason for why I want to make this charger, and it is this website:
I’ve learned so much stuff over the years, did a paper on a specific lithium-ion cell subject(low-voltage recovery), and managed to meet amazing people.
It’s the reason I’m on BLF now.
So, to thank BLF and SecondLifeStorage, I want to make the charger to rule them all.
Great to see 10180 support.
Can it still have a “dark mode” with a color LCD screen?
Make it meet UL rather than Chinese flammability test.
china - Google Search%22Glowing%2Fhot-wire+based+test%22
The UL test using contact with an open flame
https://www.google.com/search?q=underwriters+lab+flammability+electronics+test&client=firefox-b-1-d&channel=tus&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjKiJa7oa7jAhVKj54KHeDRA2sQ_AUIEigD&biw=1267&bih=762
is more likely to reveal a problem than the glowing-hot-wire test, I’d think.
Yeah, that’s not enough.
We need to use graphite electrodes that can reach 2000C.
600-1000C is not enough.
Excellent Idea and I am totally interested.
Agree with your bare minimum requirements. Want to reiterate them and also have a few questions:
1. Adjustable charging current (0,1A-3,0A) in 0,1A steps. - Could this be done using Constant Current (without PWM on low end) from .1-3A? (Upgrade from OPUS)
2. Support for multiple chemistries. - Perfect
3. Temperature monitoring (45C max below 2A, 60C max below 3A). - Temp sensor to monitor cell temp (approximate) or internal board temps?
4. 4 cell channels - Perfect
5. Active cooling if temperature exceeds 45C, and if all channels are active above 2,5A. - Temp at cells or board location? If for cells, maybe active cooling can turn on lower, say 35C? Variable speed fan please, or connector for us to plug our own in.
8. Nickel coated phosphor bronze/brass rails. - Perfect
9. Internal resistance measurement. - Perfect
11. Adjustable max voltage for lithium ion charging: 3,90V-4,20V in 0,1V steps. - Perfect
12. Storage charge mode: 3,6V. - Could this also be adjustable (from say 3.2-3.7V) or would discharge mode have adjustable termination voltages?
15. 100-200-350-500mA-750mA discharging functionality. - Adjustable termination voltages possible? Say 2.X-3.7V?
1. Most chargers use individual buck converters, unlike the OPUS, so it shouldn’t be a problem.
2. Great.
3. Temp sensors right beside the terminals. At max power(charging 4x30Qs at 12A total), the C4-12 doesn’t get too hot. It’s the cells getting hot, so monitoring cell temps is more important than the electronics’ temps.
4. Great.
5. Same thing as number 3.
8. Would be very nice, and would make inaccurate internal resistance measurement a thing of the past, most of the time anyway.
9. Great.
11. Great.
12. Storage charge mode would just charge/discharge the cell down to 3,6V. I would really like a it down to 3,4-3,5V, but 3,6V is a happy medium.
15. Yes, from 2,6V-3,3V. 3,7V is rather high. What would you want to do with it?
Tip o’ the hat to BlueSwordM! May your knowledge in this area and interest in BLF see you through to the end of this customization project.
As to those who will point out the possible/probable length of time for the project to end in product fruition, either help or wait patiently. Input is easy; Output is hard.
For me, the mere vibrant, constant, and constructive discussion in this thread and constancy of BluSwordM’s leadership will put my acquisition of any more “shelf” chargers on hold (perhaps for many months) pending the outcome of a final product.
If it really were to be designed and built, I know the focus will be on big and long cells. But, if the low charge rate is really going to be 100mah… please make sure it will at least fit 10440 cells without spacers.
I for one, think this community could design a charger to put most chargers to shame and would love to see it happen!
Thanks Blue!
3. Totally agree that monitoring the cell temps is most important. Very happy this charger will attempt it.
15. It would be nice to select discharge cutoff from our storage voltage of around ~3.6V all the way down to 2.6V.
Sometimes I know I’ll need a light for only a few hours and I have a mostly charged cell. 3.7V seems to be the sweet spot since it will end up around 3.5-6V after use. Then it’s ready for storage.
If its easy enough to accomplish in software, I guess its good to have a wider selection range but don’t think its a deal breaker.
Very happy to see such a large response to this thread so far. Seems others also feel there is a void in chargers still.
Let us know how we can help make this a reality.
I’d buy one for sure
this could force me to spend more money! why do i read these things
And we want it by Christmas.
