✌ FREEME - ASTROLUX MF01S 15000lm Flashlight Group Buy - ENDED
Exactly, it looks like a satin clear anodize to me and that uses the natural color of the aluminum underneath, just in a satin finish.
Thanks for confirming. I will purchase 3 pieces now haha. Black, silver, and blue.
The purple and blue aux looks pretty good but not with the green. I wish there’s a way to disable green.
There are many ways.
Just ordered gold, 5k
If the multi-color configuration is set in stone {Sigh! :cry: } how is it that the photos show the aux lights in different states? Like all-red? Or only blue and purple? Please don’t tell us it’s constantly rotating between colors! :person_facepalming:
If I understood the description correctly, aux lights are like voltage indicators. Green is only on with max voltage. Each color shuts off as voltage gets lower, until red aux comes on at low voltage.
The switch is still green. If you don’t like the green aux lights you probably won’t like the switch. I think the green aux will tie it all together nicely. I went with silver because I thought most colors would clash with the Green switch.
I looked at this picture a bit closer.
It seems green, blue and pink are on when the voltage is 4.2v-3.9v.
Blue and pink only are on from 3.9v-3.3v.
From 3.3v-2.9v all those colors turn off and only the red are on.
Below 2.9v they all turn off.
Unpopular opinion, I like the design of color changing with the voltage.
I don’t think anyone minds the color change in relation to voltage, it’s just the color palette. Green kind of clashes.
Sent. [quote=rizky_p] ordered, 4000k Sand color. Thanks Freeme! can i have the code for the silicon diffuser freeme? [/quote]
According to this Chinese review, the 95cri 4000k version does only 10k lumens. That 66% of 15.3k which is what the 6500k does. Toykeepers 4000k did 13.9k so it seems a bit strange. Maybe his device used for measuring is more sensetive to blue light which makes the 4000k look worse. Dunno… I guess we’ll have to wait for more reviews to confirm this.
Was just looking at the graphs for the 5000k version on page 3. Am I reading this correctly?
Ra=89.9 at 14,298lm on high
But then falls to Ra=68.7 at 34lm on low
Look at the R9. Drops from 86 to 0. I don’t think this is normal.
Good catch. Same on the next graph, medium mode ~6000lm. R9=0 still
At the full output, 10,059 lumens, it measures CCT of 4339K and a calculated DUV of –0.0053. If that is true, this would be more like a FA1 tint bin. Super rosy and the 4300K color temp. It would be near identical to the 219B 4500K 9080!
At 23.7 lumens, it measures CCT of 4051K and a calculated DUV of 0.0012
At 4,009 lumens, it measures CCT of 4136K and a calculated DUV of –0.002
Given these values, it seems like Mateminco is really using the FA3 tint bin in this light instead of the FD2 since FD2 is below 4000K and FA3 is above 4000K. Since they are supposed to have only 1,000 of these emitters, they should only be able to make about 50 before they have to switch to the FD2 tint bin, which is also not a bad tint per my test with the FW3A.
@SKV89:
I cannot see your pics.
Not sure why. I found the pics here 【图片】回复:MT18S昨天到手的一个老的氧化外壳筒子,既然到了我就做个到【手电吧】_百度贴吧
I”m interesed MF01S + diffuser.
Clearly hotlinking images from that site isn't gelling with BLF.
I see three of these:
If you want everyone on BLF to see the images that you post, don't hotlink from that site.
