BlueSwordM, you might want to think about moving this thread to the BLF Special Edition Products subforum.
I think it belongs there, and more people will pay attention to it if it's in that awesome subforum.
I would love to have a charger that I can set for max voltage of 4 volts
Yup, Nitecore SC4, and also add
(3.6v to 4.35v in 0.05v increments, since that would cover storage voltage ranges, and other li-ion chems as well. It already handles 3.6v, 4.2v, and 4.35v, so should be an easy upgrade)
Done!
The complete list of features proposed sounds great, but I’m really concerned it would never get built, or never meet the price target. And, it might be a nightmare to coordinate, like the FW3A 2-year project, with people eventually dropping out of the development team.
I’d be in for this, no ’bells & whistles’; just a solid charger.
Nice work Blue….
I am a little confused by this,
I am no expert but AAA sized cells need less than 1 amp for charging?
That is 0.1A - 3.0A in 0.1A steps
0.1A = 1/10A ……
That’s a tenth of an amp. In some countries written as 0.1 while in others as 0,1.
And that was already updated, the range is said to start at mere 50 mA to work better with 10180 cells.
That is awesome!
This sounds like a SkyRC MC3000, without the bluetooth and PC interface. Which is great, because I have no need for the buggy bluetooth stuff or awkward PC connectivity.
So, the obvious solution is to ask SkyRC to see if they will produce it for $39 (or $49 with the USB stuff, which I don’t need). Has BlueSword asked SkyRC, and if so, have they responded?
If they come back with nothing but laughter, maybe a Plan B is needed. Or, increase the price.
I can’t speak for anyone else, but for me, the difference boils down to two things — usage and availability.
Usage:
Availability:
I mean, with flashlights, first I tried not making it… but that didn’t work. So I fell back to Plan B. But with chargers, when I tried Plan A (not making it), the result was agreeable. So no need for Plan B; the market already met and exceeded my battery-charging needs.
I’ve been googling around for this and haven’t been able to find it. Link? It sounds very interesting.
@Parametrek, I will not link it yet. It’s been in translation from French to English for a while, and I’m debating whether I should release it or not.
It was more of a side-project when I was doing my main project at school(motor oil recovery methods with various solvents, distillation, electrolytic restoration, etc), so maybe I should release it one day.
One thing is for sure: I’m going to release it when I want it.
To quote myself when I wasn’t as good in science English:
My current hypothesis is that the the lithium concentration inside of the LiCo2 anode is higher than usual, and leads to a phenomenon called passivation layering, along with the lower purity of the cobalt compound, caused the problems we encountered in these cells. It’s still not certain, but I could come to a conclusion in a few weeks.
Basically, this usually happens in lithium primaries due to their very high concentration of elemental lithium, forming a passvation layer as the battery isn’t used. This isn’t really bad for them, as they aren’t rechargeable, meaning it isn’t a problem. In fact, it lowers their self discharge rate significantly.
I came to that statement, because I noticed that with my Sanyo cells from that time, their self discharge rate is very low, even for a lithium ion battery. Even my best new cells didn’t have that low of a self discharge rate. So, I did some more research, and apparently, that behaviour is quite bad for lithium ion batteries on the first cycles, as by clearing that passivation layer, the internal resistance is quite high in the beginning, resulting in much more heat than usual if a battery was stored for a while. With the lower purity of the cobalt used, it resulted in an actual lower thermal runaway threshold.
That, along with charging a possibly months old pack along using the computer in a high heat environment, lead to the thermal runaways, and the massive recall.
@WalkIntoTheLight and others, why are you worrying about this project not coming into fruition?
If we only want the basic features we want, it should be fairly easy to have a charger built with these demands in mind.
It’s the more advanced features like advanced discharged capabilities using MOSFETs, USB data connectivity, microSD card compatibility, deeper slots for very large cells, etc.
It sounds like a great idea, so I’d like to see it come to fruition. I think the best way to achieve that is to make the goals reasonable. I don’t think you’re going to get an “improved SkyRC MC3000” for less than half the price of the current model. Though, I’m happy to be proved wrong. But if it takes 3 years and 10,000 posts to be proved wrong, I’m not sure that’s good either.
Anyway, I don’t mean to be down on this project of yours. I really do wish you the best of luck. I think you should have an idea in a month or two whether it’s possible or not. If there’s no progress by then, I hope you’re still interested in a scaled-down version, like a Nitecore SC4 with settable termination voltage.
Or, continue with the one with all the bells and whistles, and maybe someday it will come to fruition. As someone else said, it’s not costing us any money.
Should be good if it actually happens , as long as lumentop don’t have anything to do with it
Thanks, that’s a very interesting site. It seems there is a forum for everything. What a world.
Heh, that’s fair enough. But this project is aimed at those who are not satisfied, for one reason or another, with what is available. And wouldn’t you agree that IF BLF is going to develop a charger (or anything else), it ought to be better, different, and/or cheaper than what is already available?
Value is an important consideration at BLF, which is great. And I think a case could be made that an advanced charger will pay for itself over time, especially if you factor in something for peace of mind. For example, with a LiIon 18650, raising the termination current (in the constant voltage phase) from 0.1A to 0.4A (something you can’t do on any budget charger I am aware of) will reduce the stored energy in the cell by about 10%, but double the longevity of the cell in terms of charge cycles (source: HKJ, and Battery University). With NiMH cells, changing the DV peak (or plateau) so that charging termination is prompt and reliable can prevent chronic overcharging. Restoring a depleted LiIon battery safely to full capacity rescues a cell otherwise bound for the landfill. Testing the actual capacity of batteries can give you peace of mind, as well as help you avoid counterfeit cells.
Batteries are pretty cheap, but there is an environmental cost, too. My point is that there is some hidden value in the price of an advanced analysing charger. And anyone who can learn to use Anduril can learn to use one. Save money. Save the planet. Have more fun. I know I’m mostly preaching to the converted here, but let’s get behind this project!
This is an important point that deserves reflection. When many of us first started we had a 1-2 cells total. Now with these amazing high power lights, we need 4-8 cells per light.
2-3 years ago I never thought I would need more than 5 cells. Now I have 52 just in one bike battery pack.
The longer we can keep them in good shape and extend their life, the better for the environment. The mining of the raw materials does a lot of damage and is not usually a consideration (ahem tesla buyers :person_facepalming: ).
Not to sound like a complete hippy, but we should at least try to be responsible and take good care of our cells so we are not replacing them every year.
INPUT power —- handle variations from solar panel shading, clouds/shadows, etc.
Make this usable off the grid, after the earthquake/tsunami/meltdown etcetera.
That means not resetting or losing track of cell voltage and then overcharging a cell after a power flicker.
Great stuff!!
Hope something comes of this
Suggestions
2. I’d like a white charger with a simple black and white LCD will do if we’re picking colours
3. Maybe a naming competition later down the track
