The making of the BLF UC4 charger: the start of a new venture, INTEREST LIST, UPDATE 3(Finalized UI and starting design)
1065 posts / 0 new
BlueSwordM
BlueSwordM's picture
Last seen: 2 hours 24 min ago
@Parametrek, I will not link it yet. It’s been in translation from French to English for a while, and I’m debating whether I should release it or not.
It was more of a side-project when I was doing my main project at school(motor oil recovery methods with various solvents, distillation, electrolytic restoration, etc), so maybe I should release it one day.
One thing is for sure: I’m going to release it when I want it. Wink
BlueSwordM
To quote myself when I wasn’t as good in science English:
My current hypothesis is that the the lithium concentration inside of the LiCo2 anode is higher than usual, and leads to a phenomenon called passivation layering, along with the lower purity of the cobalt compound, caused the problems we encountered in these cells. It’s still not certain, but I could come to a conclusion in a few weeks.
Basically, this usually happens in lithium primaries due to their very high concentration of elemental lithium, forming a passvation layer as the battery isn’t used. This isn’t really bad for them, as they aren’t rechargeable, meaning it isn’t a problem. In fact, it lowers their self discharge rate significantly.
I came to that statement, because I noticed that with my Sanyo cells from that time, their self discharge rate is very low, even for a lithium ion battery. Even my best new cells didn’t have that low of a self discharge rate. So, I did some more research, and apparently, that behaviour is quite bad for lithium ion batteries on the first cycles, as by clearing that passivation layer, the internal resistance is quite high in the beginning, resulting in much more heat than usual if a battery was stored for a while. With the lower purity of the cobalt used, it resulted in an actual lower thermal runaway threshold.
That, along with charging a possibly months old pack along using the computer in a high heat environment, lead to the thermal runaways, and the massive recall.
BlueSwordM
@WalkIntoTheLight and others, why are you worrying about this project not coming into fruition?
If we only want the basic features we want, it should be fairly easy to have a charger built with these demands in mind.
It’s the more advanced features like advanced discharged capabilities using MOSFETs, USB data connectivity, microSD card compatibility, deeper slots for very large cells, etc.
WalkIntoTheLight
Last seen: 1 hour 31 min ago
It sounds like a great idea, so I’d like to see it come to fruition. I think the best way to achieve that is to make the goals reasonable. I don’t think you’re going to get an “improved SkyRC MC3000” for less than half the price of the current model. Though, I’m happy to be proved wrong. But if it takes 3 years and 10,000 posts to be proved wrong, I’m not sure that’s good either.
Anyway, I don’t mean to be down on this project of yours. I really do wish you the best of luck. I think you should have an idea in a month or two whether it’s possible or not. If there’s no progress by then, I hope you’re still interested in a scaled-down version, like a Nitecore SC4 with settable termination voltage.
Or, continue with the one with all the bells and whistles, and maybe someday it will come to fruition. As someone else said, it’s not costing us any money.
Nev
Should be good if it actually happens , as long as lumentop don’t have anything to do with it LOL
CLB
Last seen: 14 hours 14 min ago
BlueSwordM wrote:
this website:
https://secondlifestorage.com/
Thanks, that’s a very interesting site. It seems there is a forum for everything. What a world.
ToyKeeper wrote:
* With chargers, what I want is widely available
Heh, that’s fair enough. But this project is aimed at those who are not satisfied, for one reason or another, with what is available. And wouldn’t you agree that IF BLF is going to develop a charger (or anything else), it ought to be better, different, and/or cheaper than what is already available?
WalkIntoTheLight wrote:
. . . Or, increase the price.
Value is an important consideration at BLF, which is great. And I think a case could be made that an advanced charger will pay for itself over time, especially if you factor in something for peace of mind. For example, with a LiIon 18650, raising the termination current (in the constant voltage phase) from 0.1A to 0.4A (something you can’t do on any budget charger I am aware of) will reduce the stored energy in the cell by about 10%, but double the longevity of the cell in terms of charge cycles (source: HKJ, and Battery University). With NiMH cells, changing the DV peak (or plateau) so that charging termination is prompt and reliable can prevent chronic overcharging. Restoring a depleted LiIon battery safely to full capacity rescues a cell otherwise bound for the landfill. Testing the actual capacity of batteries can give you peace of mind, as well as help you avoid counterfeit cells.
Batteries are pretty cheap, but there is an environmental cost, too. My point is that there is some hidden value in the price of an advanced analysing charger. And anyone who can learn to use Anduril can learn to use one. Save money. Save the planet. Have more fun. I know I’m mostly preaching to the converted here, but let’s get behind this project!
bhstinger
Last seen: 10 hours 33 min ago
This is an important point that deserves reflection. When many of us first started we had a 1-2 cells total. Now with these amazing high power lights, we need 4-8 cells per light.
2-3 years ago I never thought I would need more than 5 cells. Now I have 52 just in one bike battery pack.
The longer we can keep them in good shape and extend their life, the better for the environment. The mining of the raw materials does a lot of damage and is not usually a consideration (ahem tesla buyers Facepalm ).
Not to sound like a complete hippy, but we should at least try to be responsible and take good care of our cells so we are not replacing them every year.
hank
hank's picture
Last seen: 12 hours 51 min ago
INPUT power —- handle variations from solar panel shading, clouds/shadows, etc.
Make this usable off the grid, after the earthquake/tsunami/meltdown etcetera.
That means not resetting or losing track of cell voltage and then overcharging a cell after a power flicker.
Ragsy
Ragsy's picture
Last seen: 3 hours 31 min ago
Great stuff!!
Hope something comes of this
Suggestions
1. Dual voltage or provide two models to choose from (110V for US & Canada and a 230/240V for AUS, UK, Asia, Africa etc)
2. I’d like a white charger with a simple black and white LCD will do if we’re picking colours
3. Maybe a naming competition later down the track
G'day mate, ow ya garn?
Yeah, nah good mate
bhstinger
Hi Hank & Ragsy. I think Blue has you covered already on spec # 7. 12V-20V compatibility and I think he means input voltage.
That will work well with a 12V solar cell input. Ac to dc wall adapter can have an input range from 120-220VAC for worldwide compatibility.
BillyBobJoe
Last seen: 7 hours 48 min ago
Relampago wrote:
I predict 5k+ pages of future posts. Call me in two years when this is ready. In for two.
Yep. Same here.
ToyKeeper
ToyKeeper's picture
Last seen: 7 hours 13 min ago
Agreed.
That’s why I generally charge cells when they get down to ~3.3V instead of waiting until ~2.8V. Also why I usually only charge them up to 4.0V or maybe 4.1V, instead of going all the way to 4.2V. And I don’t quick-charge them. And if a cell is going to be sitting unused (or only slightly used) for a while, I usually drain it to about half full first. These things all extend the cell’s life span in years.
A charger doesn’t really help much with this though… except for chargers built into lights. Those make it a lot more convenient to keep the battery at middle voltages. It’s particularly helpful for multi-cell lights, since married sets are otherwise pretty inconvenient to do partial charges on. So I’m hyped about the charger built into the BLF Lantern.
The kind of charger I’d really like to see BLF make is a circuit which could be integrated into existing lights, to give them the ability to do wireless inductive charging. It should theoretically be possible as long as the host material isn’t ferrous. They’ve been doing this in electric toothbrushes for 25 years… so it’s probably feasible in a flashlight.
WalkIntoTheLight
Charging to 4.0v or 4.1v certainly helps with numbers of cycles. It might give you 1000 cycles, instead of 500. But at some point, you have to ask, “Am I really going to use this cell 1000 times?” Diminishing returns at some point. I still do it, about half the time, especially if it’s in a light that I don’t use much. Though, that’s probably exactly the wrong way around from what I should be doing.
I’m not so sure about prolonging cell life by keeping them around 50% charged. Yes, you may as well do it if you don’t plan to use the cell for a few months. But, I think it’s a bit of a myth that storing cells at 100% is extremely bad for them. Maybe true in the past, but modern cells seem to hold up well.
I have old laptop cells that are over 10 years old. Samsung 22H cells, and they were always kept fully charged. Original capacity 2200mAh. They still test at an average around 1900mAh. Not great IR, but still good enough for a few amps. I think that breaks the myth of 20% reduction in capacity every year.
CLB
ToyKeeper wrote:
A charger doesn’t really help much with this though….
The SkyRC MC300 will do all the things you mentioned, fully automated and unattended. If I want to charge a cell to 4.1V at 0.5C rate, I can push one button, come back hours later, and voila. Ditto for storage charge, balancing cells, and so much more. I think people are much more apt to take better care of their batteries if it is easy.
BlueSwordM
So, I’m almost finished on the feature list.
If I can, I’d like to make the full featured charger available either at the end of the year, or next year.
mrheosuper
Last seen: 14 hours 50 min ago
About input power, can we adapt to Quickcharge or power delivery type C port?, they are popular, and maximum of power delivery is 90W, more than enough for us. And using Type C port we can reverse charge our phones or tablets.
Anker atom 30w pd charger is much smaller than 12V 24W adapter.
Forgot my pen
BlueSwordM
The only problem is that it would add to the cost a lot.
vaidd
Interested in this. All of those features for around $50 (or under?) would be great.
Relampago
Relampago's picture
Last seen: 1 week 3 days ago
Thumbs Up
“Electricity is really just organized lightning”
― George Carlin
moderator007
moderator007's picture
Last seen: 12 hours 22 min ago
I have always wondered why someone didn’t just turn one of these
Into one of these
Use a simpler open source UI that could be firmware upgraded thru the usb port.
The advanced user could upgrade to a downloadable Pro UI for some advanced features.
The power would have to be limited quite a bit from the hobby charger to make room for a power supply. A power to size ratio would have to be figured out. Also it be nice to have at least a 3 amp discharge with a single cell instead of the typical 500ma found in most chargers of this type.
This is a great idea Blue, I would like to see 2- 4mm banana plug ports for those batteries that are not cylinder. You could even charge your car battery with it, with the proper banana plug to alligator clip cord. The cost for adding those should be relatively low.
Joshk
Joshk's picture
Last seen: 1 hour 4 min ago
One way to tackle the size vs cooling problem would be to offer a bolt-on external heat-sink as an option. The firmware would default to “muggle mode” and assume no additional heatsink. This makes the base model small and cheap, increasing sales volume.
Agro
Agro's picture
Last seen: 33 min 4 sec ago
Maybe it could have attachment point that’s compatible with CPU heatsinks?
Relampago
Relampago's picture
Can I use my nzxt kraken with it?
― George Carlin
Joshk
Joshk's picture
Oh, nice. And a simple 12v header to power the CPU cooling fan for active cooling. This thing would be a BEAST with these features.
Joshk
Joshk's picture
BlueSwordM wrote:
7. 12V-20V input voltage compatibility.
Can we get this spec up 1 more volt to 21v? The problem with 20v is it’s a bit short of operating directly off any 5S power source.
EDIT: ***The reason this is important is to be able to recharge your flashlight batteries during a power outage.
BlueSwordM
12V-22V then.
Joshk
Joshk's picture
BlueSwordM wrote:
12V-22V then.
Excellent! Thanks.
teacher
teacher's picture
That sounds very interesting for sure.
IF this happens, can we raised the discharge rate too?? If so, that would be very appealing.
Scallywag
Scallywag's picture
Last seen: 1 day 4 hours ago
The funny thing is, I use a Nitecore i8 at home. It's extremely simple, and I often charge my eneloops in it. But it auto-detects to my liking, and while it's a bit big and expensive, it was also a gift. It also charges slowly, but I care more about battery health than charge speed. The only step up that makes sense in my head currently is to the MC3000, because for the fun don't-actually-need-them features, that's the one that ticks the most boxes.
I do have a spare single-cell USB-powered charger, it is actually a SupFire AC-16, but I've only used it once. It actually currently lives at work. I have a cool tiny charger for my 10250s from CRX and my Klarus Mini One Ti charges its own 10180 cell. I can't remember for sure, but I might also have a charger that came with one of my ThorFire lights somewhere...
EDC Rotation: ZL SC62 | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01
EagTac D25C Ti | DQG Slim AA Ti | UF-T1 by CRX | Olight S1 | Klarus Mini One Ti
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
In-progress: Supfire M6 3xXHP50.2
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
hank
hank's picture
Not for sure yet.
You need to make sure that if a shadow moves across the solar cell and voltage drops below the minimum spec the charger recovers gracefully and continues to charge —- rather than resetting to starting from scratch again. This has been a problem and caution I’ve seen brought up repeatedly with small chargers when people tried using solar cells with them.
