✌ FREEME - ASTROLUX MF01S 15000lm Flashlight Group Buy - ENDED
I don’t think anyone minds the color change in relation to voltage, it’s just the color palette. Green kind of clashes.
Sent. [quote=rizky_p] ordered, 4000k Sand color. Thanks Freeme! can i have the code for the silicon diffuser freeme? [/quote]
According to this Chinese review, the 95cri 4000k version does only 10k lumens. That 66% of 15.3k which is what the 6500k does. Toykeepers 4000k did 13.9k so it seems a bit strange. Maybe his device used for measuring is more sensetive to blue light which makes the 4000k look worse. Dunno… I guess we’ll have to wait for more reviews to confirm this.
Was just looking at the graphs for the 5000k version on page 3. Am I reading this correctly?
Ra=89.9 at 14,298lm on high
But then falls to Ra=68.7 at 34lm on low
Look at the R9. Drops from 86 to 0. I don’t think this is normal.
Good catch. Same on the next graph, medium mode ~6000lm. R9=0 still
At the full output, 10,059 lumens, it measures CCT of 4339K and a calculated DUV of –0.0053. If that is true, this would be more like a FA1 tint bin. Super rosy and the 4300K color temp. It would be near identical to the 219B 4500K 9080!
At 23.7 lumens, it measures CCT of 4051K and a calculated DUV of 0.0012
At 4,009 lumens, it measures CCT of 4136K and a calculated DUV of –0.002
Given these values, it seems like Mateminco is really using the FA3 tint bin in this light instead of the FD2 since FD2 is below 4000K and FA3 is above 4000K. Since they are supposed to have only 1,000 of these emitters, they should only be able to make about 50 before they have to switch to the FD2 tint bin, which is also not a bad tint per my test with the FW3A.
@SKV89:
I cannot see your pics.
Not sure why. I found the pics here 【图片】回复:MT18S昨天到手的一个老的氧化外壳筒子,既然到了我就做个到【手电吧】_百度贴吧
I”m interesed MF01S + diffuser.
Clearly hotlinking images from that site isn't gelling with BLF.
I see three of these:
If you want everyone on BLF to see the images that you post, don't hotlink from that site.
I’m interesed in MF01S and diffuser. Thank you
Hotlinks should work if you look at the 50 pictures in that scrolling page, right click an image and view it full screen. Then use that url.
Can you guys see these 4 pics?
I cannot.
And I'm not using a VPN right now, so the problem is hotlinking images from that site.
Can’t see the pics either way…
Yes, they’ve obviously added some rewrite rules to the web server’s .htaccess file. Nothing you can do, other than DL the images and host them somewhere else.
Odd, it shows up for me. Oh well.
Nope, but once rehosted :
You don’t need to DL them, just copy/paste the image’s URL in imgur if you don’t use the plugin.
Good thinking, that should also help avoid losing quality in case imgur uses a compression algorithm like e.g. Facebook and other sites.
Tbh I’m pretty obsessive and I don’t normally upload an image without making at least some kind of alterations (crop, curves adjustments etc.) and then saving it as .png, so I don’t think I’ve ever uploaded straight to imgur from a URL! :slight_smile:
It’s interesting I would like to see new statistics updated. Hopefully it is possible, thank you.
