✌ FREEME - ASTROLUX MF01S 15000lm Flashlight Group Buy - ENDED
@SKV89:
I cannot see your pics.
Not sure why. I found the pics here 【图片】回复:MT18S昨天到手的一个老的氧化外壳筒子,既然到了我就做个到【手电吧】_百度贴吧
I”m interesed MF01S + diffuser.
Clearly hotlinking images from that site isn't gelling with BLF.
I see three of these:
If you want everyone on BLF to see the images that you post, don't hotlink from that site.
I’m interesed in MF01S and diffuser. Thank you
Hotlinks should work if you look at the 50 pictures in that scrolling page, right click an image and view it full screen. Then use that url.
Can you guys see these 4 pics?
I cannot.
And I'm not using a VPN right now, so the problem is hotlinking images from that site.
Can’t see the pics either way…
Yes, they’ve obviously added some rewrite rules to the web server’s .htaccess file. Nothing you can do, other than DL the images and host them somewhere else.
Odd, it shows up for me. Oh well.
Nope, but once rehosted :
You don’t need to DL them, just copy/paste the image’s URL in imgur if you don’t use the plugin.
Good thinking, that should also help avoid losing quality in case imgur uses a compression algorithm like e.g. Facebook and other sites.
Tbh I’m pretty obsessive and I don’t normally upload an image without making at least some kind of alterations (crop, curves adjustments etc.) and then saving it as .png, so I don’t think I’ve ever uploaded straight to imgur from a URL! :slight_smile:
It’s interesting I would like to see new statistics updated. Hopefully it is possible, thank you.
Yea very strange because my image links show up fine for me too. But I can’t see yours.
Interested in one light and diffuser! Thank you!
Here’s another review. It has beamshots of the M43, nichia MF01, newer modified nichia MF01 (i think), MF01s and some throwers. For some reason it doesn’t look purple or red…it’s pink.
Here are some points:
MF01 head works on the MF01S body but not vice versa as the spring is thicker so the negative contact won’t touch… something like that anyway.
Quite a bit more throw…we knew that anyway
Ceiling Bounce
Nichia MF01…….34
6500K MF01S……85
Ordered 4000k silver color. Would like to have code for diffuser. Thanks Freeme.
Forwarded. [quote=vik267777] Ordered 4000k silver color. Would like to have code for diffuser. Thanks Freeme. [/quote]
Thanks for your support!
Interested in one light and a diffuser.
Thanks!
