Yes, they’ve obviously added some rewrite rules to the web server’s .htaccess file. Nothing you can do, other than DL the images and host them somewhere else.
Good thinking, that should also help avoid losing quality in case imgur uses a compression algorithm like e.g. Facebook and other sites.
Tbh I’m pretty obsessive and I don’t normally upload an image without making at least some kind of alterations (crop, curves adjustments etc.) and then saving it as .png, so I don’t think I’ve ever uploaded straight to imgur from a URL!
Here’s another review. It has beamshots of the M43, nichia MF01, newer modified nichia MF01 (i think), MF01s and some throwers. For some reason it doesn’t look purple or red…it’s pink.
Here are some points:
MF01 head works on the MF01S body but not vice versa as the spring is thicker so the negative contact won’t touch… something like that anyway.
