Yes, they’ve obviously added some rewrite rules to the web server’s .htaccess file. Nothing you can do, other than DL the images and host them somewhere else.
Good thinking, that should also help avoid losing quality in case imgur uses a compression algorithm like e.g. Facebook and other sites.
Tbh I’m pretty obsessive and I don’t normally upload an image without making at least some kind of alterations (crop, curves adjustments etc.) and then saving it as .png, so I don’t think I’ve ever uploaded straight to imgur from a URL!
Here’s another review. It has beamshots of the M43, nichia MF01, newer modified nichia MF01 (i think), MF01s and some throwers. For some reason it doesn’t look purple or red…it’s pink.
Here are some points:
MF01 head works on the MF01S body but not vice versa as the spring is thicker so the negative contact won’t touch… something like that anyway.
Thanks. I did when you posted them originally (Thanks for that BTW). Some of your images look promising (Dark Red), and in others you posted the Red looks Pinkish. I have messaged BG kindly asking them that if the Red is actually more of a Dark Pink to change my order to Blue.
I’m debating simply ordering a 2nd one in Blue, and then selling the Pink one if that’s what it ends up being. Trouble is, I wanted to save this money for getting a D18 rather than a second Mf01S.
