13585 posts / 0 new
nobody
Last seen: 1 week 18 hours ago
Rhino666 wrote:
Hello all. I'm new to blf. I found this forum through Matt Smith's YouTube channel and his video about this flashlight. I watched his video, read a little bit on here and ordered one that day from Neal. I just got mine in the mail and I couldn't be happier. This light does everything I could want and the build quality seems great. I'll be sticking around and checking out the mod thread. Thanks for a great light.
Welcome!
I've been following this thread for about 6 or 7 months now.  But it has been going on for a long while.  I think the work and the patience of the ones involved and those of us following have been well rewarded.  It is a great light!
Rhino666
Last seen: 1 year 1 month ago
Thanks for the hearty welcome. I really don’t think I could be happier with this light. I own quite a few lights, all production models from many companies, foursevens, olight, klarus, etc. This light is small, powerful, and packed with great features. My thanks to all involved.
SKV89
Last seen: 1 hour 26 sec ago
I received the two FW3A, standard dark gray aluminum and the copper. The copper is drop dead gorgeous! The finish is very shiny, almost mirror like. It is the most beautiful copper light I’ve seen yet. Below are my test results:
Copper SST-20 4000K w/ stock Carclo and glass lens
lumens: 1,974
CCT: 3972
DUV: -0.0012
CRI: 95.2
R9: 83.8
Rf: 93
Rg: 102
Copper SST-20 4000K w/ UCL lens
lumens: 2,051
CCT: 3960
DUV: -0.0024
CRI: 95.6
R9: 86.0
Rf: 93
Rg: 103
Gray aluminum with stock non-Carclo optics (no glass lens)
lumens: 1,819
CCT: 3898K
DUV: -0.0025
CRI: 95.8
R9: 86.9
Rf: 93
Rg: 103
Gray aluminum with Carclo 10509 optics (no glass lens)
lumens: 1,767
CCT: 3982K
DUV: -0.0031
CRI: 96.2
R9: 88.6
Rf: 93
Rg: 103
Gray aluminum with Carclo 10509 optics (w/ UCL glass lens)
lumens: 1,802
CCT: 3904K
DUV: -0.0029
CRI: 96.3
R9: 87.7
Rf: 93
Rg: 103
Gray aluminum with Carclo 10509 optics (w/ UCL glass lens) at low output (first blink)
lumens: 99
CCT: 4052K
DUV: 0.0014
CRI: 96.4
R9: 93.4
Rf: 89
Rg: 98
E07 SST-20 4000K FB4 tint bin for comparison:
CCT: 3822K
DUV: 0.0028
CRI: 93.7
R9: 76.5
Rf: 93
Rg: 101
cabfrank
Last seen: 9 hours 4 min ago
The tint is really, seriously, great on my SST-20. I think all tint junkies would love it, and I do too. I’m just underwhelmed by the lumens difference vs the XPL-HI. I knew this, but tried anyway. I honestly prefer the XPLs.
SKV89
Yea the tint on this SST-20 4000k tint bin (likely FD2) is surprisingly good on higher output modes considering how this emitter (FB4 tint bin) is known for ugly green tint. On turbo, it looks as good as some of the Cree 5D and 5A tint lights I own. But the majority of the 5A/5D lights are rosier on high output and less green at low output. But given the high CRI and R9, I would choose this over 5A/5D for an EDC flooder like the FW3A.
mortuus
mortuus's picture
Last seen: 6 hours 37 min ago
so the tint on sst20 is better then nichia tint ?
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
SKV89
No. SST-20 FD2 is about 0.0028 duv at low outputs showing hints of green, whereas 219B is slightly below BBL even at low output. At high output, the 219B 4000K and 4500K ranges from -0.004 to -0.009 DUV giving it a more white/rosy appearance whereas the SST-20 FD2 is only about -0.002 to -0.003 at max on the FW3A.
KevinZA1988
KevinZA1988's picture
Last seen: 2 weeks 3 days ago
What about the Nicia 219C 4000K?
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
mortuus
mortuus's picture
ah okay, i bought the sst20 anways as i like it more the emitter then nichia, excited to get this in copper either way.
              つ ◕_◕ ༽つ
contactcr
Last seen: 2 hours 14 min ago
SKV only comparing turbo to turbo? Throw in some more regulated modes
Joshk
Joshk's picture
Last seen: 4 hours 51 min ago
SKV89, what hardware/software are you using to get that awesome data?
KevinZA1988
Give the 10507 optic a go. I was very impressed with the throw and clear spot of the 3000K SST-20’s that I swapped into my FW3A. It really makes up for the lost lumens and it doesn’t make that weird yellow spot in the middle of the beam like the XP-L HI’s do.
contactcr
I suspect not for this light but has anyone ever tried a focus a dedomed emitter better in a 10507? Like getting the optic to sit just a fraction of a mm lower
tocirahl
Last seen: 7 months 2 days ago
lumens: 1,767
lumens: 1,802
Your test seems to imply that adding a UCL glass lens increased the lumen output of the light? That doesn’t seem possible to me.
Also how’s the fit with the UCL lens? I assume you got the 22.6 × 1.9?
contactcr
Setting aside the fact he used a mode that’s FET driven (meaning that alone could cause variation) I got similar results when I did no lens vs UCL.
I suspect the integrating sphere is getting more light bounced back into the sensor when you use a glass lens vs nothing.
tocirahl
Weird. It looks like you’ve tried a bunch of lenses. Which one would you recommend?
Rhino666
Which size ucl lens fits the fw3a? I don’t have calipers to check the dimensions.
azhu
azhu's picture
Last seen: 4 hours 12 min ago
I think it’s 22.61 × 1.90 mm
Need Nichia 219b r9080 Emitters? (。◕‿◕。)
“The Light shines in the darkness, and the darkness did not comprehend it.” John 1:5
SKV89
I just realize you are talking about the nichia 219C as Lumintop desn’t offer 219B option, which is what I was comparing to. The SST-20 FD2 is definitely better than any 219C I’ve seen. The 219C is greenish just like the SST-20 FB4 tint bin. The only rosy 219C are the “E” bin ones that Clemence sold in the past but I haven’t seen one in person.
Trevit86
Last seen: 6 months 3 weeks ago
Actually the 4000k 219c that come’s with the FW3A is pretty rosy, I have both 219c and the 4000k SST-20 version.
The 219c def alot more rosey and looks to be slightly whiter, higher kelvin possibly.
But I still perfer the SST-20, cause stays cooler and throws further and also has a pretty nice tint, like some one mentioned before its almost like a slightly whiter Halogen bulb tint.
Both variations have good tints.
SKV89
I added a low output mode. MUCH more green on low output. This tint on this emitter varies more than the average emitter relative to current.
Texas_Ace lumen sphere calibrated with Maukka calibration lights for lumen measurements
Sekonic C-800-U for photometric data. There are much cheaper alternatives out there but I think those require connecting to a computer but I might be wrong.
tocirahl wrote:
lumens: 1,767
lumens: 1,802
See Contactr’s response. Also I started with fully charged batteries, after multiple tests, the voltage drops which will also affect output. Heat will also reduce output. UCL glass lens will not increase output over no lens but they are suppose to be the best lens available with the claimed 98-99% light transmission.
I found out about the UCL lens from Contactr’s post. He posted the dimensions. This dimension also fits the Wuben TO46R and TO10R. Dropped the DUV in my TO46R modded with Kaidomain SST-20 3000K by roughly 0.001 to 0.0015 in all output levels resulting in more negative DUV and nicer rosier tint.
SKV89
Did you compare the 219c and SST-20 on turbo and 219C is rosier? If so, that is absolutely amazing as I think the 219C has higher output also but lower CRI and R9 value. I wonder if you just got lucky with the tint lottery or did Lumintop source the “E” bin 219C. I haven’t heard any reports on the 219C tint in this light besides this. If they turn out nice, I might have to buy one.
contactcr
SKV89 wrote:
Gray aluminum with Carclo 10509 optics (w/ UCL glass lens) at low output (first blink) lumens: 99 CCT: 4052K DUV: -0.0014 CRI: 96.4 R9: 93.4 Rf: 89 Rg: 98
Negative Duv at 100 lumens? Either I got 2x crappy SST-20’s or the 10509 is working magic.
SKV89
oops! should be positive. fixed now.
mortuus
mortuus's picture
are all copper versions in stock at Neal ? anyone got shipping notice how long after order paid ?
              つ ◕_◕ ༽つ
Robin Dobbie
Last seen: 1 month 4 weeks ago
I got a shipping notice yesterday. After having requested an upgrade to the cree emitters, after multiple refund requests to multiple email addresses after lensgate, 3 weeks ago when refunds were being offered.
BOO5TED
BOO5TED's picture
Last seen: 7 min 59 sec ago
Haven’t received any shipping info yet. Sad
"America has three cities, New York, San Francisco and New Orleans. Everywhere else is Cleveland."- Tennessee Williams
korpzgrinda
korpzgrinda's picture
Last seen: 2 hours 53 min ago
Location: Eastern Woodlands in the Wilderness of North America
After lensgate, I decided not to go through with an SST-20 variant order I had placed, since I got a XPL HI variant from the first batch. As offered by Neal, I requested a refund and received it in full within a day. I contacted him through forum PM though, maybe that made a difference.
mortuus
mortuus's picture
okay weird, mine shipped like a day after with shipping nr, the sst20 copper version.
              つ ◕_◕ ༽つ
Robin Dobbie
After I made a comment 3 weeks ago about how I hadn’t received any communication from this guy, some wildly inappropriate responses were made. One of the guys was insinuating that because I didn’t send a PM that somehow I was doing something wrong. If a PM is the only way to get a response out of this guy, why doesn’t he say that on the website where he takes your money? Why even on THIS SITE does Neal list email addresses he has no intention of checking and responding to?
