Hello my dear friends!
Today i present you the Acebeam TK16 in copper with OSRAM LEDs and a 16340 cell pushing out up to 1300 Lumen !
the flashlight was provided by Sven Stewitsch - please visit
https://www.stewitsch.de - home of flashlights
Specs:
Size: 23mm Head Diameter x 66.5mm Length x 22mm Tube
Weight: 75.8g w/o battery; 93.8g w/ battery
Innovative body construction is made of solid billet ultra conductive pure red copper
High CRI (CRIβ₯95) LED resembles the nature of sunlight and reveals subtle detail of an object
Long range beam distance up to 338 meters by OSRAM LED
Customized 10C discharge current IMR16340 550mAh battery (RCR123 battery)
TIR (Total Internal Reflection) optic facilitates efficient light transmission with a broad beam and a generous throw
Highly integrated tail switch switch for all easy operation
Knurling and polishing finish provide a secure grip
Multiple LED, multiple brightness and light range
Compatible Battery: 1 x IMR16340 550mAh (RCR123) battery (recommended) / 1 x CR123A battery
Strobe setting that can disorient an attacker or serve as a distress signal
Detachable Gold plated clip and compact size for easy carry
Streamlined body with slim head design
Underwater 2 meters submersible
1 meter impact resistance
Low battery voltage warning with flickering
Intelligent highly efficient circuit board design for max. performance and long run time
Intelligent temperature controlled light output for user safety
