But then we wouldn’t have had this wonderful adventure together now would we?
I tried looking for an au seller for an led but came up with nothing particularly good. I just ordered a couple more from mntnelectronics. And I asked lumintop if I could have another on an mcpcb just incase I bugger it up with the reflow…… covering all bases. Already spent silly $ why stop now…
Great! Thanks!
Did you have trouble opening the head? I haven’t tried yet…
Are 8 cells recommended or does it work the same on 4? - i’ve got a choice of 35E (actually in my GT) or 30Qs… I’m assuming 4 is enough to power a single 70.2?
The head was kinda tight, not too bad. I used a rubber strap oil filter remover tool to unscrew the head.
On 4 cell’s 30Qs are recommended due to high amp draw (for high power-on lumens) Should work fine, but lower runtimes obviously.
On 8 cells 35Es will be fine.
I removed the switch cover so I could clamp it in a vise. Pieces of wood with a depression for the switch will also work. I found that loosening the upper head from the lower head removes tension on the bezel rubber seal which makes the bezel a bit easier to unscrew.
I had to use a lot of force and slowly unscrew the pieces. They are tight.
@Jason: Thanks for the picts - i think i saw them somewhere some while ago… Damn, it does not look easy. I would have to get the rubber tools and a bigger vise… Not sure i’ll get into this mod.
How about heating the bezel wish a hair drier? It should dilate a little more then the head and become easier to unscrew? That may damage the lens though?
I clamped the flattened part with the button on it in a work-mate. Unscrewed the whole top including reflector with a simple rubber strap shown in JasonWW’s pictures. I didn’t really need the tool I think. Mine came loose easily, so I guess there is a lot of variation.
What a relief it is to have my GT70 back up and running.
I got my replacement LED’s in the mail yesterday and I’ve been hyping myself up for my first reflow attempt on an LED. I had a few practice runs- I used a hot air gun on the bottom of the MCPCB- holding it in place with some alligator clip helping hands. Holding the heat gun about 6-8 inches away seemed to heat it nice and steadily. The solder paste really worked like magic on it too. I was able to remove and replacing the dead LED on the other MCPCB with minimal fuss, using a big pair of metal tweezers. Once my hands had steadied out and I had some confidence I fired up the hot air gun again and had a go at the GT70 MCPCB.
It went surprisingly easily, the LED floats straight on to the pads and with a little pat down on top the excess solder pops out the sides. Beautiful.
I screwed the whole lot back together (with a liberal application of thermal paste under the MCPCB) and fired it up, and finally its back to it’s old self blasting away the darkness.
Thanks again to everyone here with the advice and tips, guiding me on how to get this job done properly. You guys really are top notch. Here’s to hoping all my future work on this light is making it more epic with mods not just fixing it.
Are you able to send this video to me or tag the link. I’m interested but would technically be my first mod. handy with electronics and a soldering iron though.
Thanks
