Just checked the datasheet, all XP-L HIs 3500K and below are 80 CRI minimum. This isn’t true for the HD and certainly isn’t a hard and fast rule for other Cree emitters.
It was not my choice.
The company who did the shipping in Germany was somewhat unable to deliver to my original address.
They could not handle a company line.
I did not choose the type of shipping, it was the default for Germany.
All shipments where sent domestically and not international.
I didn’t do anything special. Opened it up, tossed a GA inside, and play with it every now and again. It did see some pocket time on Sunday, but only a couple hours. Other than that it’s been sitting on my desk bezel down when I’m not using it.
I have seen a number of Cree datasheets over time, in which all emitters at 3000K were 80 CRI minimum, and wrongfully concluded that it was true for all Cree emitters, sorry about that. At least it is true for the XP-L Hi, which is used in the FW3A.
Has anyone else put the UCL lens on an SST-20? Do you have before and after shots? Still waiting on mine, so I am stuck living vicariously through those of you who have received theirs.
For those with the FW3A and it’s “heavy” switch action, and awaiting or has the FW3C with its “light” switch action, consider swapping the switches. I found that the heavy switch goes well with the heavy light, and vice versa… There’s just something it does to my mind. When I pick up the heavy light, I appreciate the heavy switch action,and also vice versa.
I didnt do anything scientific but I was pretty sure when I pulled both switches they were identical and the difference was actually how the tail opening was milled and the sizing of the nub was slightly trimmed. So if you moved the rubber gasket and nub that would make sense but if you only moved the metal tail it doesn’t make sense to me.
