gotta love that round die aspheric look
I got fooled by a travel clock today.
Bought it new at a local store (Hema) last week.
(Sofirn C01 is for size reference)
It runs on a single AA and has a small 3mm led that lights via a momentary switch on the back, to check the time at night.
It is pretty bright, my planned mod was to add a high value resistor in series with the led and replace the momentary switch with a slide-switch, so the clock can be lighted all night at a non-disturbing brightness. I like that much better.
I was surprised to like the tint of the led, pretty good for a cheap travel clock, so before starting the mod I checked the tint with the spectrometer.
And good it was indeed: 2300K, 96.3CRI, R9=83, duv –0.022. This is a holy grail led , where did the Hema source it?
Then I checked the spectrum
I would love to see some new leds with round die. But for now i am really happy to have my SBT-70 Aspheric on my shelf. Again thanks to DB Custom for making it possible.
Had to mill the underside of the led cover thinner to make space for the SBT-70. The cover barely touches the glass above the led. Took some time to center it but i think now it looks good.
Before the assembly every part was really good cleand and i still have a few dust spots under the lens .
I would love to add some shots from this led in moon mode. The blue shining line arround the led looks so cool. But with my phone it is not visible. Maybe i can find someone in my area to take a few nice shots.
My work light died today. So I Frankensteined something together for the time being. Aspheric quad 219b doesn’t look to bad.
Beam shots?
I haven’t been around to know it, so I ask: this is an incan, right?
I’m very interested in seeing the result as well.
Yes,mit was an oldschool mini-incan bulb. Probably cheaper than a piece of circuitry to boost the voltage of the AA-battery for use with a led.
I fixed my old bluetooth speaker…the stupid microUSB charge port broke off the mother board….so I opened it…soldered in a tp4056 module, cut end off bad USB cable and wired in…closed it up…yay…can charge the battery and listen to my audiobooks on my drive to work
That’s the only thing I have modded lately…
I guess this counts as a mod
I’m at the proof of concept stage, testing layout.
I’m building a:
- Replica prop from Pulp Fiction
- Bonfire/Fireplace emulator
- Suitcase with ~18000mAh capacity + 5V USB output
- Very big over-engineered ambient temperature measurement device
- Orange quad mule with unnecessary active cooling, just because!
It’s gonna have 9 x 18650 LG S3 2000mAh cells loaded when it’s done.
It has a 3A charge circuit, the 1A micro-usb took forever charging this many cells at once.
I’m still considering adding a second emitter choice, so it can shift from orange to perhaps a warm white.
It’s running on a Emisar D4 driver, flashed with the latest Anduril 2019-06-02 firmware. So it has all the blinkies.
The 4 leds are salvaged from a Orange Beacon light. All I can find is that they are “3W”. Have 4x XP-E2 P3 amber LEDs on order, for MOAR OUTPUT!
Still need to find something to cover the leds, to act as a diffuser. Something that can fold, or fit in the case when closed.
Looks impressive. Mind not to go through customs with that suitcase.
Haha, imagine that
“No, it’s not a bomb, it’s just a very weird flashlight”
Anyone know if it possible to buy a luxeon V 4040 gasket anywhere?
Tried M21A (stock 6A driver) with dedomed SST-40 from kaidomain. I didn’t like the result, so after beam shots I put 4040 white flat instead (and it is awesome now)
One more build post for now.
It’s C8+ and SST-20 4000K from kaidomain (fb4?). Throws almost as good as GT mini with low CRI emitter.
Led4power driver with thermal enhancement kit for Convoy S2+:
Beam shot - GT mini WW (measured lux: 38), 4040 white flat M21A (lux: 100), C8+ SST-20 (lux: 33%)
Moded a deodorant cover to make a GITD diffuser for my Wuben T70.
I applied some Montana GITD spray and a piece of GITD tape in the interior for a better fit on the bezel!
Changed the outter ring of purple peds to orange on this E07.
I fixed my sw45 triple RRT-01!
before:
replacement driver from Jetbeam
my first mod ever
woohoo!
and now I own all sorts of modding tools and supplies…
I feel like dancing!
major thanks to pinkpanda, CRX and Clemence for the inspiration,
and to moderator007, SKV89 and pol77
for all the support and encouragement to learn to roll my own…
First mod? That is worth dancing about! Great job JS. Something tells me this may just be a beginning… (modding is addicting!)
Today I modded my PulseLabz Guardian Series Signature Gaming chair.
I'm not a gamer and I'm not a small person. Actually it was more of a repair than a mod. The gas piston failed after the first week. Two weeks later I had a new piston in hand. The kind people at Pulselabz also provided some written instructions.
"The first step is to separate the piston from the tilt-lock mechanism above. To do this, first raise the chair to the highest position you can with the height adjustment. Then find a friend to help you, both with one leg pushing down on the metal base and the other leg on the ground, wiggle the chair upwards and downwards in a rhythm, with one arm holding the height adjustment lever in the open position and the other arm holding the backrest until the piston separates from the top.
The second step is to separate the piston from the metal base. As your old piston can go in the trash, the method we came with will damage it but its okay. What you can do is take off all the casters/wheels, and then find a concrete parking spot block, then holding the metal base, hit the piston really hard against the concrete parking block and it should pop out upwards
Let me know if there's anything I can help with."
I chose another route:
https://www.youtube.com/watch?v=pV-wXwoQovc
Worked great.
