So there aren’t 2 boards where the MCPCB is? One for the main emitters and one board for the secondary LEDs? I wasn’t referring to the driver. I have the first batch of FW3A I think.
Except that the FW3A does not have any secondary LEDs.
If you want secondary LEDs in your FW3A you have to buy a custom secondary LED board from Lexel. That custom board sits on the star just like the aux LED board on a D4v2 or E07.
Did you buy a modded one with secondary LEDs or are you mistaken?
If the secondary LEDs are those “dragon” type they will be on the same board as the main LEDs so you would want to re-use that board and leave them on during re flow. I guess this is why you said 4 wires.
I’m interesting in how you fare doing the D4v2. It does have an aux board but it seems like to me the most tricky thing would be fitting those 4-5 wires (edit: 6!) back through the MCPCB hole after they have soaked up some solder making the wires stiff. Seems like there’s barely enough room as is.
No problem. I was kinda thinking that was the case actually.
My D4v2 hasn’t arrived yet, but my understanding is it uses an Aux LED board that sits on top of the main board.
There are 4 thin wires connected to the aux LED board. All 4 must be desoldered.
Then lift off the aux LED board to get access to the star, which has the normal 2 wires.
Use a fine-tip soldering iron for the aux LED connections and a heavier tip for desoldering the star.
Before desoldering, take pictures so you know the proper pads to resolder each of those 4 wires.
If you’re having trouble threading all 6 wires through the hole in the star, do the following:
Solder a long narrow gauge guide wire onto the end of each of the original wires. A couple inches should be enough for each guide wire.
Thread the guidewires through the hole in the star.
Slide the star down along the guidewires until in position on the shelf. Use the guidewires to pull the original wires through the hole.
Desolder the guidewires.
Swapping emitters is quite doable on lights with aux LED boards, but it is a much more complex operation than doing so on a light without the aux LED board. Leave lots of time for the project and take a slow and methodical approach.
Thanks for the tip. I’ll post pics if I decide to do this. Will probably swap the emitters on my FW3A as well so I wouldn’t be hijacking this thread… lol
I tried a UCL 22.61mm x 1.90mm lens on my FW3A, and was disappointed to find that it created a slight gap between the bezel and the rest of the head. With the original lens, the fit is so good that the head appears as one piece.
Maybe I’ll try the sapphire lens that Neal sells or TK’s method of polishing the coating off of the original.
To expand on this idea, for anyone that wants a magnetic tail cap, I am considering using one of these to do the same. They are basically neodymium washers. My only apprehension is the 2mm thickness, but I don’t think it will be that bad.
EDIT: Also I found a pull force calculator for ring magnets and these should hold about 4 pounds which should be sufficient for the FW3A.
I had considered that. I was hopeful since they are at the lower end of the scale for neodymium magnets for magnetism that they would be strong enough.
The thickness of the magnet should be fine for breakage if backed by a solid setting bond, I would probably use JB weld instead of the E6800 as that remains slightly flexible once cured?
Plus the JB weld can be moulded up the sides of the magnet and shaped with acetone before fully cured.
Chipping shouldn’t be too much of a concern but yeah a coating might help.
I have a similar setup with a small ring magnet around the tail switch on this light with no problems. Stuck on with JB weld & surrounded with a glow mix.
The E6800 , when used in thin films is not flexible . It is when used in thicker applications.
This is hard to explain. In thin films is can be flexed but when gluing down a rigid washer with a thin film it will not move. Figure that one out. If you glued 2 credit cards together, they still could bend though.
