Emisar D3AA is available now
Recieved my one also today. SST20 6500K in dark grey. I luv it…
Really nice crafted. the print of D4V2 on the talicap is perfect placed…
Need to explore all features…
Great Job, Emisar and Toykeeper… :sunglasses:
+1
challenges my zebralight recommendation/purchases.
I wish it had the clip that the zebralight has. I am thinking about picking one up, but the idea of a pop on/off clip just hurts.
Most Zebralights use a friction clip too…
The smaller zebralights like the SC60 series and SC50 series all use screwed on clips. Only some of the larger ones like the SC600 series use slip on clips.
I assume he has something like an SC64w HI, which uses a screwed on clip.
Got it today.
The aux LEDs in high mode use more power than the main LEDs in moon mode. For what you described, you may as well just leave it on all night in moon mode. It would be brighter and would drain the battery less overnight.
The Zebralight SC52w-L2 and Zebralight SC62w both use a very secure screw on clip. I have my D4V2 now and really like it, but would accept a couple more mm in the tail cap for a screwed on deep carry clip.
Just found this post…what’s that noise about muggle mode?
Still didn’t get mine
There’s an unfortunate bug in first-run Emisar D4V2s sold through International Outdoors before July 19.
When put in muggle mode (6 clicks from off) and run with a partially depleted cell (about 3.8v or lower), these lights effectively enter “self destruct mode”. After approximately 15 minutes of being off they will turn on and start flashing at full power with no ramp down from the thermal sensor.
If this is an 18650 cell, the lights may overheat, which in a couple cases caused some or all of the following: (1) plastic optic melting, (2) driver wires desoldering, (3) button boot and retaining ring popping off. Probably from expansion of the aluminum head.
As a safety measure it is recommended to avoid using muggle mode if you have one of the affected lights until fixed. The fix requires a firmware update and can be done in about 1 minute without disassembling the light, but requires special hardware and software.
Many thanks Firelight2.
Detailed and self explanatory info:)
Mine is post July 19 order so i’m ok.
Just to confirm, every light ordered through International Outdoors after July 19 is safe? I’m literally about to pay for my order, and just want to double check.
Straight from the Intl-Outdoor website:
Thanks Kazibole…
Reading comprehension was never one of my strong suites :person_facepalming:
What’s up with hank and not responding to emails or sending orders in a timely manner?
He posted earlier that he is focused on getting the programming kits ready.
That may have been over in Toykeeper’s review thread.
Just joined this thread so don’t hate me (much) if this question was asked somewhere like 30 pages before…
Is 219C 5000K option 90CRI like solo emitters on Hanks site or it’s something else?
The 219C 5000K option is listed on Intl-Outdoor as 83 CRI.
I’m not sure if any other 219C versions are available. Regardless, it has a nice tint but also more heat and lower output.
anyone tried flashing their d4v2? Anyone seen or know why I get this error? A fellow BLF’s was helping out but thought I’d post here for increased d4v2 owner visibility.
CHECK CONNECTIVITY
FIRMWARE UPDATE
yay! i finally found the problem. I’ll post it in the d4v2 firmware update thread.
