FW3A mod thread. Post yours!
1270 posts / 0 new
azhu
azhu's picture
Last seen: 2 min 23 sec ago
shirnask wrote:
I swapped out the 7A’s for 351D’s (4000k) in my wife’s FW3A and she is much happier with the result. It’s very floody but she likes that.
Was it hard to do the swap? I imagine it’s just desoldering the 4 wires, remove the top and bottom boards, and just reflow?
Just wondering if there are any hidden surprises or tips I should know before I do it. Thinking about putting some 219b sw35 in mine.
Need Nichia 219b r9080 Emitters? (。◕‿◕。)
“The Light shines in the darkness, and the darkness did not comprehend it.” John 1:5
contactcr
Last seen: 28 min 41 sec ago
No need to remove the driver if that’s what you mean by bottom board.
If you have the later batch of FW3A they come with a small screw in the shelf and a divot on the underside of the MCPCB to keep it from spinning when you screw the bezel on. I would re-use this one if you are able for that reason. If you don’t want to re-use it you need to remove that screw so it sits flush.
If you have the very first batch of FW3A you can re-use the MCPCB or use an aftermarket one. After you have everything soldered back in place you might want to spin the MCPCB a quarter turn counter clockwise so when it spins while cranking the bezel it wont pull on the wires.
On mine they only used wires exactly as long as they needed to so if you use an aftermarket PCB where the wires are further out it may not reach without replacing them. YMMV.
azhu
azhu's picture
So there aren’t 2 boards where the MCPCB is? One for the main emitters and one board for the secondary LEDs? I wasn’t referring to the driver. I have the first batch of FW3A I think.
Firelight2
Firelight2's picture
Last seen: 10 min 36 sec ago
There would be.
Except that the FW3A does not have any secondary LEDs.
If you want secondary LEDs in your FW3A you have to buy a custom secondary LED board from Lexel. That custom board sits on the star just like the aux LED board on a D4v2 or E07.
contactcr
Did you buy a modded one with secondary LEDs or are you mistaken?
If the secondary LEDs are those “dragon” type they will be on the same board as the main LEDs so you would want to re-use that board and leave them on during re flow. I guess this is why you said 4 wires.
azhu
azhu's picture
There would be.
I’m so stupid… I was totally thinking about my D4v2… wanted to swap the emitters on that one.
Ignore my previous messages… haha.
contactcr
I’m interesting in how you fare doing the D4v2. It does have an aux board but it seems like to me the most tricky thing would be fitting those 4-5 wires (edit: 6!) back through the MCPCB hole after they have soaked up some solder making the wires stiff. Seems like there’s barely enough room as is.
D4v2
Firelight2
No problem. I was kinda thinking that was the case actually.
My D4v2 hasn’t arrived yet, but my understanding is it uses an Aux LED board that sits on top of the main board.
  • There are 4 thin wires connected to the aux LED board. All 4 must be desoldered.
  • Then lift off the aux LED board to get access to the star, which has the normal 2 wires.
  • Use a fine-tip soldering iron for the aux LED connections and a heavier tip for desoldering the star.
  • Before desoldering, take pictures so you know the proper pads to resolder each of those 4 wires.
If you’re having trouble threading all 6 wires through the hole in the star, do the following:
  • Solder a long narrow gauge guide wire onto the end of each of the original wires. A couple inches should be enough for each guide wire.
  • Thread the guidewires through the hole in the star.
  • Slide the star down along the guidewires until in position on the shelf. Use the guidewires to pull the original wires through the hole.
  • Desolder the guidewires.
Swapping emitters is quite doable on lights with aux LED boards, but it is a much more complex operation than doing so on a light without the aux LED board. Leave lots of time for the project and take a slow and methodical approach.
azhu
azhu's picture
  • If you’re having trouble threading all 6 wires through the hole in the star, solder a long narrow gauge guide wire onto the end of each wire. Thread that through, then desolder the guidewire.
Thanks for the tip. I’ll post pics if I decide to do this. Will probably swap the emitters on my FW3A as well so I wouldn’t be hijacking this thread… lol
trailhunter
Last seen: 1 hour 57 min ago
Hi, who is selling the glow rings?
f0xx
f0xx's picture
Last seen: 3 days 6 hours ago
Quote:
trailhunter said: Hi, who is selling the glow rings?
I think you can get them from Neal (Here), CRX (Here), or anywhere else that sells glow gaskets for 20mm Carlco triples.
Alternatively you could make one yourself using these instructions: http://budgetlightforum.com/node/62243
trailhunter
Beautifully crafted response Smile thx
f0xx
f0xx's picture
You are welcome!
trakcon
trakcon's picture
Last seen: 1 hour 20 min ago
I tried a UCL 22.61mm x 1.90mm lens on my FW3A, and was disappointed to find that it created a slight gap between the bezel and the rest of the head. With the original lens, the fit is so good that the head appears as one piece.
Maybe I’ll try the sapphire lens that Neal sells or TK’s method of polishing the coating off of the original.
dragunbayne
teacher wrote:
pennzy wrote:
fluke wrote:
pennzy wrote:
I bought these to use around the Emisar D4 switch to recess it. They fit perfectly around the chrome ring and bring the top of the switch flush with the plain of the washer. Turns out , they also look good on the FW3A . I think they will prevent accidental activation well. Sorry, no pictures. https://www.amazon.com/gp/product/B07LBQ789W/ref=ppx_yo_dt_b_asin_title_...
How did you attach them,its a great idea.
I use E6800 . In the D4V2 thread there is a picture
http://budgetlightforum.com/comment/1523998#comment-1523998
Since it seems pennzy does not do pictures… let’s see if we can’t decipher & actually see what he did with these three pictures….. All lined up in a row in one easy to locate place… Right Here in THIS Post…..Big Smile
SS Flat Washers from Amazon
E6800 Industrial Adhesive
FW3A with SS Washer attached with E6800
!{width:100%}https://i.imgur.com/rAISmKb.jpg!
To expand on this idea, for anyone that wants a magnetic tail cap, I am considering using one of these to do the same. They are basically neodymium washers. My only apprehension is the 2mm thickness, but I don’t think it will be that bad.
EDIT: Also I found a pull force calculator for ring magnets and these should hold about 4 pounds which should be sufficient for the FW3A.
djozz
djozz's picture
Last seen: 27 min 27 sec ago
Neodymium magnets are brittle, so they may not last a lifetime when mounted so exposed.
dragunbayne
I had considered that. I was hopeful since they are at the lower end of the scale for neodymium magnets for magnetism that they would be strong enough.
CRX
CRX's picture
Last seen: 10 min 27 sec ago
Just try to avoid hard impacts.
dragunbayne
I’d do my best obviously. I wish I could make a button like yours. I’m still thinking on it a bit.
I thought I might epoxy coat it to add durability.
CRX
CRX's picture
The thickness of the magnet should be fine for breakage if backed by a solid setting bond, I would probably use JB weld instead of the E6800 as that remains slightly flexible once cured?
Plus the JB weld can be moulded up the sides of the magnet and shaped with acetone before fully cured.
Chipping shouldn’t be too much of a concern but yeah a coating might help.
I have a similar setup with a small ring magnet around the tail switch on this light with no problems. Stuck on with JB weld & surrounded with a glow mix.
pennzy
pennzy's picture
Last seen: 2 hours 19 min ago
!{width:99%}https://i.imgur.com/9kkhfva.jpg!
The E6800 , when used in thin films is not flexible . It is when used in thicker applications.
This is hard to explain. In thin films is can be flexed but when gluing down a rigid washer with a thin film it will not move. Figure that one out. Big Smile If you glued 2 credit cards together, they still could bend though.
CRX
CRX's picture
Thumbs Up
dragunbayne
That looks really cool! I may do something like that. Love your lights.
mrheosuper
Last seen: 1 week 5 days ago
I reflashed FW3A, add a blue aux led, now it’s beautiful
Forgot my pen
KawiBoy1428
KawiBoy1428's picture
Last seen: 2 hours 35 min ago
Did you replace the cut + lead…
KB1428 “Live Life WOT
mrheosuper
well, of course, i dont want it to be a “hot rod”
Forgot my pen
Minocc
Minocc's picture
Last seen: 1 day 8 hours ago
So it turns out my diffusers work great at lighting up an area of the basement during a power outage due to severe weather.
teacher
teacher's picture
Last seen: 7 months 4 weeks ago
Hope you made it through the bad weather OK. Your diffusers work great even when the power is not out… I love em’!!! Beer
Minocc
Minocc's picture
Some tree damage, power is still out, another band of storm coming in a little while.
The winds took down that tree, but didn’t knock over a moped nearby.
teacher
teacher's picture
Pretty strong wind to snap that tree like it did. Shocked . Hope the weather calms & you get power restored soon.
Stay safe…. Smile
