Charging to 4.0v or 4.1v certainly helps with numbers of cycles. It might give you 1000 cycles, instead of 500. But at some point, you have to ask, “Am I really going to use this cell 1000 times?” Diminishing returns at some point. I still do it, about half the time, especially if it’s in a light that I don’t use much. Though, that’s probably exactly the wrong way around from what I should be doing.
I’m not so sure about prolonging cell life by keeping them around 50% charged. Yes, you may as well do it if you don’t plan to use the cell for a few months. But, I think it’s a bit of a myth that storing cells at 100% is extremely bad for them. Maybe true in the past, but modern cells seem to hold up well.
I have old laptop cells that are over 10 years old. Samsung 22H cells, and they were always kept fully charged. Original capacity 2200mAh. They still test at an average around 1900mAh. Not great IR, but still good enough for a few amps. I think that breaks the myth of 20% reduction in capacity every year.
The SkyRC MC300 will do all the things you mentioned, fully automated and unattended. If I want to charge a cell to 4.1V at 0.5C rate, I can push one button, come back hours later, and voila. Ditto for storage charge, balancing cells, and so much more. I think people are much more apt to take better care of their batteries if it is easy.
About input power, can we adapt to Quickcharge or power delivery type C port?, they are popular, and maximum of power delivery is 90W, more than enough for us. And using Type C port we can reverse charge our phones or tablets.
Anker atom 30w pd charger is much smaller than 12V 24W adapter.
I have always wondered why someone didn’t just turn one of these
Into one of these
Use a simpler open source UI that could be firmware upgraded thru the usb port.
The advanced user could upgrade to a downloadable Pro UI for some advanced features.
The power would have to be limited quite a bit from the hobby charger to make room for a power supply. A power to size ratio would have to be figured out. Also it be nice to have at least a 3 amp discharge with a single cell instead of the typical 500ma found in most chargers of this type.
This is a great idea Blue, I would like to see 2- 4mm banana plug ports for those batteries that are not cylinder. You could even charge your car battery with it, with the proper banana plug to alligator clip cord. The cost for adding those should be relatively low.
One way to tackle the size vs cooling problem would be to offer a bolt-on external heat-sink as an option. The firmware would default to “muggle mode” and assume no additional heatsink. This makes the base model small and cheap, increasing sales volume.
The funny thing is, I use a Nitecore i8 at home. It's extremely simple, and I often charge my eneloops in it. But it auto-detects to my liking, and while it's a bit big and expensive, it was also a gift. It also charges slowly, but I care more about battery health than charge speed. The only step up that makes sense in my head currently is to the MC3000, because for the fun don't-actually-need-them features, that's the one that ticks the most boxes.
I do have a spare single-cell USB-powered charger, it is actually a SupFire AC-16, but I've only used it once. It actually currently lives at work. I have a cool tiny charger for my 10250s from CRX and my Klarus Mini One Ti charges its own 10180 cell. I can't remember for sure, but I might also have a charger that came with one of my ThorFire lights somewhere...
You need to make sure that if a shadow moves across the solar cell and voltage drops below the minimum spec the charger recovers gracefully and continues to charge —- rather than resetting to starting from scratch again. This has been a problem and caution I’ve seen brought up repeatedly with small chargers when people tried using solar cells with them.
