[Review] YLP Panda 3R (Headlamp, XP-L Hi throw + XP-G3 flood, 1x18650, micro-USB charging)
18 posts / 0 new
bmengineer
bmengineer's picture
Last seen: 1 month 2 days ago
The Product
YLP sent me their newest headlamp to take a look at, the Panda 3R. This is an 18650 powered light with built in charging and two switches, but the optics are what sets it apart - the two LEDs and lenses are optimized to create two beams with different profiles, one throwy and one flood. The two beams can be used independently or together, and it's all controlled by two back lit switches on the top of the light.
Spoiler
This headlamp builds on the design of the Panda 2. YLP added better waterproofing, and differentiated the two LEDs from one another by optimizing one with a floody beam for close up work, and the other for far reaching light. The build quality also seems a bit better, if only for the aluminum gasket holding the lenses in place.
It's a good headlamp for sure. It's plenty powerful, and the UI is good - but it's not perfect. I found it gets a bit hotter than I would like on the highest mode, so I would recommend staying away from turbo modes if you're on a longer hike. It also uses an XP-G3 for the floody LED, which enthusiasts might not love, and the lowest mode is at 10 lumens.
Even with all that - it's a compelling package, and it looks pretty cool. I can see the appeal for cavers, or for consumers that have used the flood and throw beams on other headlamps and aren't willing to give the feature up.
Physical Dimensions
The light measures 83.1 mm wide, 32.1 mm from front to back, and 25.1 mm tall. The height is not including the buttons, which protrude a fair bit from the body of the light. It weighs 59 grams on its own, or 106 g with the included cell.
Here's the light lined up with my other favourite headlamps, an 18650, and a common straight bodied light. From left to right that's a Samsung 30Q, YLP Panda 2M CRI, YLP Panda 3R, Skilhunt H03 RCArmytek Elf C2, and Convoy S2+.
Build
This light is made almost completely from aluminum with a dark grey anodizing.
The front of this light is obviously the most interesting. There's an aluminum gasket holding the two lenses in place, screwed into the body. We can also see the two buttons protruding from the top of the headlamp, which makes them fairly easy to press even with gloves or cold hands. Both ends of the cell tube have similar caps with some light knurling to help with grip.
The two buttons are held in place by stainless steel rings. There are some shallow fins cut into the rear of the headlamp to help with cooling.
Not much going on underneath the light except a hot warning etched into the coating. Notable that this is one of only two labels on the light - there's no naming or branding anywhere on the body.
The other labeling is the USB symbol on the right endcap.
Removing this reveals the micro-USB port used to recharge the light.
The other end cap is used to close the cell tube. The threads are anodized, so you can prevent accidental activation by backing off the cap a quarter turn. Each cap uses different threads, so there's no risk of mixing them up. The large spring serves as the negative contact for the light.
Inside, there's another spring serving as the positive contact.
What's Included
The light comes in a snazzy black box with a magnetic closure. Inside you get:
  • The light, installed in the headband
  • 2600 mAh cell
  • Spare O-rings
  • Paperwork
One thing notably absent from this kit is the micro-USB cable needed to charge it, but I won't dock any points for that. These cables are standardized, and common enough that you're almost guaranteed to have a literal box full of them somewhere... (please tell me I'm not the only one).
Ergonomics and Retention
This is a dedicated headlamp. It comes installed in a headband, and there's really very little reason to ever remove it or use it in any other way. There is no lanyard loop, clip, or magnet included... because it's a headlamp.
The included band is good. The adjustment works well, the headlamp doesn't bounce around too much, and the silicone bits inside the webbing help it stay in place. There are no reflective markers on the included headband.
Modes and Interface
There are 5 modes, each of which can be used with either or both LEDs. YLP claims they are 10, 35, 120, and 550 lumens for either LED independently, or 20, 70, 240, and 1100 combined.
The flashlight is controlled by the grey (right) switch, and the left (black) one.
  • From off, press the grey switch to turn on in the memorized mode
  • From on, hold the grey button to cycle brightness from low to high
  • From on, press the black switch to cycle wide-throw-both LEDs
  • From on, hold the black switch for turbo throw
  • From on, double press the black switch for turbo of both LEDs
  • From off, hold the grey switch for moonlight with the memorized LEDs
  • From off, triple click the grey button for battery check (1 to 5 blinks)
Overall the UI is easy to get used to and follows all the good basics - single press for on or off and hold to change levels. I've tried a number of lights from YLP now, and not a single one has had a bad UI. That being said, a low mode below 10 lumens would be nice to have on a headlamp that might be used for extended periods, and I do prefer how the Panda 2M CRI had more configurable options available.
Overall I find it a bit difficult to navigate through the two different emitter options, but as I've said, some people look for that feature. The shortcut to full power throw is certainly handy.
Light Quality and Beam
The combination of optics and LEDs used in this headlamp is pretty unique, and certainly interesting. There's an XP-G3 behind a honeycomb optic, which gives a wide diffused beam, and an XP-L Hi behind a smooth optic, giving a very noticeably throwy beam. Both are listed at 4000K, which sounds about right - they're a nice neutral to warm color that's great for the trails.
My only complaint here is that the XP-G3 is known to have some tint shift and a not-so-great beam. The honeycomb lens it's hidden behind does a good job of hiding as much of that as possible, but I wish that LED was replaced with the LH351D that was used on the Panda 2M CRI. A Panda 3R CRI with an LH351D in place of the XP-G3 and an SST-20 in place of the XP-L Hi might be even better. People coming from less enthusiast grade lights who aren't used to high CRI likely won't notice any of these negatives, and the beam is perfectly functional.
Power and Runtime
The light is powered by a single 18650 cell, and ships with a 2600 mAh button top cell. There are springs at both ends of the tube, so flat top cells should work without any issue.
Running both LEDs at full power gives a step down after a few minutes, settling around 30%. Although the runtimes are less stable than the Panda 2M CRI, there are no steep drops or other weird behaviours. It's worth noted that, on turbo, the light got quite hot - much hotter than I'd like something strapped to my head or tossed in a bag to get. I would suggest against using turbo for too long in a single go.
YLP does not list runtimes for the light on turbo, as it's thermally controlled and will vary depending on the environment - not completely unreasonable. The dual LED runtime on high is listed as 2.5 hours. I measured 3.3 hours, which is far longer than claimed - and that's with the included and relatively low capacity cell. A 3500 mAh cell should stretch this even further.
Standby drain was measured at under 30 μA, which means if the included cell was left in the light would take almost 10 years to run dead. Self discharge of the cell will likely have more of an impact than the electronics here.
Charging
To charge the light, simply unscrew the end cap with the USB logo on it and plug in any micro-USB cable. I could see some potential for loosing this cap if you aren't careful, but I prefer this to the less than reliable rubber covers used on many other lights.
Charging looks great. It's just a bit over 1 amp, with a good CC-CV curve, and proper termination. The two tests were extremely similar, and the indicator LED changed from green to red right when the test completed.
Teardown
Teardown is a bit of an exaggeration, but I like using that scary word to remind any readers that this isn't recommended. Anything that requires tools has the possibility to void your warranty, depending on how badly you mess it up and what sort of mood your warranty provider is in - but people like to see the guts.
The two T6 screws holding the metal gasket in place come out easily enough. The gasket itself is a tight fit in the body, and takes some wiggling to work it out, but nothing challenging.
YLP did a good job making sure this unit was sealed - there's an o-ring around the metal faceplate, one on each of the optics, and another around each of the screws (not pictured). It's also nice to see two tiny, AR coated glass lenses used here to protect the soft plastic lenses from any scuffs. I'm really impressed with this design.
And here's the guts. The LEDs and driver are all on a single board, and the switches are mounted on the side of it. It's nice to see that the switches are mounted into cut outs in the aluminum, so the solder isn't the only structural support. The single board layout is probably bad news for anyone thinking of swapping emitters, but it's definitely possible for someone with the right skill set and tools. I also like to see that there's a screw clamping the board down to the heat sink, though a second screw to ensure even pressure would have been better.
Summary
Pros:
  • Flood and throw beams should appeal to customers used to store brand headlamps
  • Neutral CCT
  • Good build quality
  • Complete kit with the light, a cell, and a way to charge it
  • Charging works great, and is properly sealed away from the elements
  • Lack of a magnet will appeal to cavers and other users relying on compasses
  • Buttons work well and are easy to click, even with gloves
  • Mechanical lockout, which I find important for something likely to be tossed in a bag for a hike
Cons:
  • A lower low would be great
  • I'm not a fan of the XP-G3 used
  • Heats up more than I'd like a headlamp to
Notes and Links
This product was provided free of charge from the manufacturer. I was not paid to write this review, and have tried to be as unbiased as possible.
Manufacturer's product page, and the only place I can find to order this light at the time of writing
Find all my reviews of flashlights and more gear at www.bmengineer.com
DavidEF
DavidEF's picture
Last seen: 11 hours 39 sec ago
Nice. Thanks for the review, and especially the “teardown” part. Wink
- The YKK Philosophy
bmengineer
Thanks for reading! It looks like it wouldn’t be impossible to swap out that XP-G3 if you really wanted to, but it’s a bit above my capabilities. Nice that there’s no glue in there.
will34
will34's picture
Last seen: 2 weeks 5 days ago
Nice review…
They seem to be well engineered and not over priced, but I’m not very convinced about the XP-G3 emitter choice. And I think the thermals are a bit on the safe side, it can easily handle 600 constant lumens.
MRsDNF
MRsDNF's picture
Last seen: 1 day 7 hours ago
Nice informative review bmengineer. Thanks.
DavidEF
DavidEF's picture
Yeah, I think it would be possible. But it’s probably not something I would try unless I had a specific emitter in mind to replace it. I don’t absolutely hate XP-G3 like a lot of people seem to. I do wonder why they didn’t just use a XP-L or XP-L2 HD instead.
hank
hank's picture
Last seen: 6 hours 16 min ago
Nice review.
Here’s the manufacturer: http://www.en.yarkiyluch.ru/
bmengineer
I’ve been pestering them to release a version with an LH351D in place of the XP-G3 at least, but I don’t think it’s happening.
hank wrote:
Nice review. Here’s the manufacturer: http://www.en.yarkiyluch.ru/
The brand distinction between that site and YLP is a bit confusing. I think the site you linked is a store, and they sell these lights as well as some pretty generic stuff.
YLP is the professional line of lights made under his brand – that’s my takeaway a least.
And thanks for the compliment, glad you enjoyed it!
fnksb
fnksb's picture
Last seen: 4 days 15 hours ago
XP-G3 is bad for smooth optics or reflector, but can work very well with mat/honeycomb optics Wink
Of course, some people change LEDs to Samsung 351D and SST-20 Hi-CRI, or something else.
I also made a “warm-cold” Panda-3 with Nichia 319A 5500K + Nichia 219C 3500K. Thumbs Up
bmengineer
This optic hides the tint shift better than almost any other I’ve tried, and it’s clear YLP cares about tint more than most manufacturers, but I still can’t see why they’d choose this over the LH351D.
AEDe
AEDe's picture
Last seen: 2 hours 44 min ago
Xpg3 in panda3/3R works good with their optics.Tint is below BBL line as many people like here.
Hicri with good tint would be much better of course.
aswang
Last seen: 1 day 23 hours ago
Got my Panda 3R and have to say it is a wonderful headlamp. Except for the fact it does not have a proper moonlight I like it a lot especially the UI. The stock LEDS are quite nice and rosy especially the xpg flood. But, thanks to BLF, I could not help myself and swapped the emitters to SST-20s 3000K. LH351 3000K is probably a better idea for flood but the tint of the SST-20 is just too gorgeous in comparison. Shoebox output below:
Flood – 4,17,60, 120,420
Spot – 8, 24, 70, 140, 440
Both – 11, 42, 135, 262, 872
Lower output but 95CRI warm rosy light is a good tradeoff for me. Beam for both flood and spot is tighter but peak cd for spot is almost the same with xpl-hi. Also tried 10 and 90 degree Yajiamei beaded optics without the stent. The 10 degree fits out of the box while I had to sand the 90 degree one because the bottom part is too fat to fit the centering ring. The beam distance of the spot did not improve much but the flood beam became a real flooder but a lot of lost light (measured high to only about 300 lumens OTF). Painting the outside of the optics white might help but I stuck with the stock optics at the moment. Ordered some clear 10, 15, and 20 degrees to see if I can increase the range of the spot beam without turning it ugly.
I actually might order another one or wait for the next version to turn into a triple CCT headlamp with matching optics since I have some 2700K and 5700K 90CRI 219Cs lying around. I wonder how the combined beam would look?
bmengineer
That’s impressive. How did you swap the LEDs?
aswang
Not that difficult actually. I know Aede reflowed some LH351D on his Panda 3 so I thought it was doable. Taking out the PCB with everything on it is very easy. Just desolder the single wire and unscrew the single screw. Used a lighter to reflow carefully. Easy enough since the underside is just copper. Just make sure you don’t do it too quickly and you don’t overdo it. Usually I start at a safe distance and gradually put the flame nearer little by little every 10 seconds or so. The flame does not have to touch the board for the solder to melt. Careful also not to touch other components since they’ll probably get desoldered too.
AEDe
AEDe's picture
Actually the main difficulty is not to melt solder near buttons.
If you do that surface tension attract button pcb to main mcpcb. After that you should unsolder button pcb, install both button and main pcb in host to fix angle between them, and solder it together again. It is not deficit but many extra work.
TexasToasted
TexasToasted's picture
Last seen: 10 hours 57 min ago
Tracking shows my Panda 3R passed through New York yesterday, so I should have it in a few days.
AEDe, I’m looking at the photos form your review and it looks like you could use a few drops of epoxy to affix the switch boards to the main board so they don’t move when you heat the main board to swap LEDs.
Would that cause any issues reassembling the light?.
AEDe
AEDe's picture
TexasToasted, glue is good idea but epoxy can demage optics as I heard so be careful.
aswang
I did not run into this problem maybe because I was overly cautious with the heat while reflowing. This is good to know though since I may get another one and I’m changing leds on that one too. Thanks for sharing AEDe.
