I have several chargers, ranging from first few ones that I got when I joined this hobby: iCharger 106B hobby charger, the Pila IBC and the Powerex Maha C9000.
Then came the Nitecores, the Xtars and my first analyzing charger with 4 bays, the Opus BT-C3100 V2.0/2.1, 2.2.
Then the new kids on the block that can cater to long cells and high amperage/auto current charging like my Miboxer C4-12 and their other models, all the way to the C8.
I also have the SkyRC MC3000, which I regretted to this day due to its complexity to use relative to simplicity of my other analyzing charger/analyzers.
This Eizfan S4 is a breeze to use, has very clear color LCD screen that you just tap to choose what you want, whether you want to charge, choose current, discharge on the next cradle while doing other sorts of modes in a combination of different cell chemistry (lilo, lipo4, nimh), all simultaneously, just like the Opus but without the Large color LCD Touch Screen that the Opus lacks.
No more memorizing of procedures, etc. or making a list or cheat sheets like the SkyRC.
Of course its price is quite a bit on the high side at $119 (with code)…but I tell you, once you actually get to use this thing hands-on, you’ll wonder why they only came up with this design now.
It’s just like using your smart phone by tapping on the screen, but without connecting it via cumbersome Bluetooth, data cable, etc.
Love this UI, the one thing i dislike about my Nitecore SC4 and UMS4 is the 2 button approach to the UI
This is much more intuitive to me. Shame about the price but very interesting, thanks for the post and info.
At the moment, I am testing/charging one partially discharged 30Q. (Actually, my first time to fully charge a cell, so I don’t know how it terminates!)
Here are the initial photos:
Tapped the #1 bargraph, then this screen appears to choose charging rate. I tapped 2a, it’s highlighted, albeit poorly!
When “type” is tapped, screen will show the auto detection of cell chemistry, in this case the 30Q is Li-ion 3.7 ( the Li-ion 3.8 is for some special cells that terminates at 4.35v)
Thanks very much for taking the time to show this
But I was more interested in confirming that the actual battery voltage is accurate by using an accurate multimeter to see if the chargers idea of 4.2volts is really 4.2 volts.
In other words is the charger calibrated properly.
While most modern, well-designed chargers of today terminate @ 4.20v, almost all batteries, if not all, almost immediately go to their ‘natural’ resting voltage of below 4.20v anyway, for me, I have no practical purpose of checking about exact voltages to the thousandths of a volt.
I’m not sure if this post is aimed at me ,I think it may be so I’ll reply,
I’ve read HKJ’s review , he’s very good & I highly rate him,
But I’m not sure if he has time to verify each test with a multimeter because he’s very busy with the amount of stuff he tests , so I’m sure he’s talking the termination volts from the chargers display, I have bought & use charges he’s tested & ive bought because he said this or that charger terminates at 4.2v but when I’ve tested them they usually fall a bit short eg 4.16 ,4.17 etc , or maybe if he has got time to verify that it terminates at a real 4.2 then it’s possible manufacturers may cherry pick before sending to him because their credibility is on the line.
Sinical old me…
Yes I agree with you BUT I’m not talking about a cell staying at 4.2 v ,it is obviously going to settle to around 4.18 after a while , I’m actually talking about cells leaving the charger STRAIGHT after the charger says full @4.2.
If it’s actually terminating at 4.17 v verified with accurate multimeter but charger reports 4.2
Then the cell will settle at something like 4.14-4.15v ,I hope that’s made it clearer to understand.
My curves are made with a 6½ digit multimeter and I read the termination volt from them (From the curve, not from the logfile).
Termination voltage is highest voltage while current is on, as you can see on all my curves voltage drops immediately when current is turned off.
I’ve stoped using the all88 charger with lithium ion because if I check the voltage a day after charging the voltage is 4.13 –4.16 (the gyrfalcon isn’t consistent on all slots) but if I charge on mc3000 they read about 4.18 v a day or so after charge ( I set termination to 4.2v )
Hey HKJ ,Do these manufactures know you are going to publish your tests on forums
Is there a chance these are cherry picked for reviewers ?
Do you actually get mainstream production units ? I’ve noticed you sometimes don’t get the retail boxes
Maybe it’s the luck of the draw & some chargers of the same type are accurate & some not so!
Well anyway I’m very happy with my two mc3000’s ,my opus (after modifying) &my xtar vc4 they all terminate at a verified 4.2 ,the rest stay in their boxes.
