Got my Astrolux FT03 today. OMG
73 posts / 0 new
scosgt
Last seen: 10 hours 5 min ago
This light blows me away.
It is a fairly narrow beam, so that has to be kept in mind,
BUT
It totally blows away my Convoy L6 on the highest mode.
AND
The BLF Q8 on the highest mode.
In fact, high on the 03 is pretty close to those two lights on max.
On Turbo, HOLY COW!
This is amazingly bright and has an incredible throw. I have never seen anything like it! This is the 5700K version
This is some bargain for $33.00 from Banggood.
One note: After playing for a while the battery was at 3.77V (Keepower protected 5200 26650) and it would still hold turbo no problem. Did not get that hot either.
My Rofis MR-70 will no longer hold turbo when the battery gets below 3.87V.
So that means something I guess
This is the current version with the XHP-50
This has to be about the best light on planet earth for $33.00
Edited by: scosgt on 07/18/2019 - 23:00
AlexGT
AlexGT's picture
Last seen: 4 days 8 hours ago
You mean the Astrolux FT03 XHP-50?
scosgt
Yes.
I will edit that in.
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 1 hour 33 min ago
Yea its an awesome light!
This is what BLF is about cheap bright good lumens! You shouldn’t need to spend hundreds on a fancy light to get this performance.
scosgt
I am just amazed at what they were able to do. On a $33 light.Now I’m pissed I paid for an L6 and a Q8 and an SP36. This one just blows them all away.
Yea those other lights are still good they are just as bright but they will offer better run times so they have there uses. If you get into modding you can change the current on your L6 by changing the sense resistors that will give it a nice boost in output.
Fairly easy to do.
BlueSwordM
BlueSwordM's picture
Last seen: 1 week 1 day ago
The Q8 and SP36 are actually brighter, have better build quality, and especially on the Q8, much higher thermal mass and much better thermal dissipation.
scosgt
The meter may say so, my eyes disagree.
Since those are both more flood than thrower, they may indeed put out “more light”.
But in my actual testing, they don’t hold a candle to the FT03.
scosgt
But since they run off multiple batteries, you are probably quite correct about run time.
Lightbringer
Lightbringer's picture
Last seen: 3 hours 46 min ago
Whenever someone asks what’s the best light to get (or something painfully along those lines), I don’t answer, but ask, “Whaddya gonna do with it?”.
My GTmini/P30/variousC8s throw hella far, but close-in, they’re nigh useless. Each will light up a bright spot about the size of a coaster, but spill is useless. Or crank it up to get “useful spill”, but be blinded by the glaring hotspot.
Then again, my Q8 lights up an incredibly nice area at moderate distances but can’t throw all that far except by brute force.
And my Cometa on wiiiiiiiiiide flood throws a nice even blanket of light close in, and can light up a whole room wonderfully evenly, but is useless beyond a few dozen feet unless you zoom it in.
It’s just a matter of using the right tool for the job. No one light is intrinsically “better” or “worse” than other lights of similar quality. A thrower sucks close-in, and a flooder sucks farther out. Depends what you want to do with the light…
scosgt
Agreed
I have adopted the MR70 as my EDC. It can do anything I need for a light that is on my belt – stuck in a blackout or an elevator – it can provide many hours of low light or less time of enough flood light to illuminate the lobby of a commercial building.
but this FT03 is probably my new favorite light. It is fairly small and light (of course not pocket size) and throws an amazing beam. But the spill is also quite impressive, and the ramping works really well all the way down to what is essentially moonlight. So it would be great for any activity where you would actually carry a light, as opposed to just having it in your pocket or on your belt.
I do agree about a thrower being mostly useless close in, this is an outdoors light for sure.
Yokiamy
Yokiamy's picture
Last seen: 10 min 32 sec ago
You may be right there, but please do not forget some important aspects, like bluesword already mentioned
The FT03 is a nice light, but hes very little thermall mass, so it will heat up fast and thus loose lumen output.
It will drain your batteries quite fast, so again you loose lumen output
The Q8, Sp36 both give you stock more lumens, but due to the small reflectors, they beam output is way different.
The XHP70 L6 will do stock about 3800 Lm which is almost the same as the XHP50.2 in the FT03, but as said it has more thermall mass so longer time to heat up and thus longer higher runtimes.
And yes, i did a resistor mod (R120) om my L6, and you can definitely see the difference, it will boost a 500Lm or so
So please reconsider your thoughts Wink
Yokiamy
Yokiamy's picture
+1
scosgt
I know English is not your first language, so no offense taken. But no, I will not reconsider my thoughts. They are mine and I am entitled to keep them.
Yokiamy
Yokiamy's picture
Haha, ok, you got me there
mortuus
mortuus's picture
Last seen: 33 min 9 sec ago
its a good light, i have the sst40 version tho, but still its even better a thrower but the xhp50 is also a good choice if u want more lumens and less throw.
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
Starkm32
Starkm32's picture
Last seen: 1 week 2 days ago
@scosgt, how’s about lighting up your FT03 with some pics. We are in the
Dark here. Beam shots, please.
“A picture is worth….”.
It may be useful come the next blackout in the city. Party
Trail Trek
Trail Trek's picture
Love my FT03 as well, and i agree it blows away other throwers (not all obviously), but it is a very capable and fun light.
I keep mine on the windowsill and use it to look right across the grass towards a treeline, seeing all the wild rabbits scatter as i say “dam this thing throws”.
Agree with @Starkm32 please upload some beam shots.
scosgt
I would but I don’t have photobucket and it appears this site does not accept pictures direct, only links to other sites.
Trail Trek
[/quote]
I would but I don’t have photobucket and it appears this site does not accept pictures direct, only links to other sites.[/quote]
Yes it’s a nuisance not hosting images here but I’ve always found this site is handy to use.
https://imgur.com/upload
Just copy the link into the post.
It’s free and works ok for me. Others might have a much better suggestion though.
scosgt
scosgt
OK cool maybe I can do some shots tonight
scosgt
Here are a couple of beam shots, if this works:
https://imgur.com/a/yrKv93S
Eleziel
Last seen: 9 months 2 weeks ago
The Q8 is also nearly twice the weight of the FT03. that’s not a bad thing tho, it’s a plus for both lights, just different categories.
AndyMac2272
AndyMac2272's picture
Last seen: 2 weeks 4 days ago
As a fellow New Yorker and a current owner of the Q8, SP36, and future owner of the FT03, I suspect I will agree with you.
AndyMac222777
scosgt
Just buy one.
scosgt
In my other thread I had a problem with a Keepower protected battery. Fully charged and fresh off the charger, Turbo would apparently trip the protection circuit and the tail cap had to be loosened and tightened back up to use the battery. After just running it on high for a while, it returned to normal behavior, It was the battery, not the light as it worked perfectly with other batteries.
I know some guys prefer protected batteries, but this light appears to be more reliable with IMR high drain unprotected batteries. Being a true newbie, I can not explain what happened just report it.
AndyMac2272
I did. Waiting on delivery.
AndyMac222777
Eleziel
scosgt wrote:
In my other thread I had a problem with a Keepower protected battery. Fully charged and fresh off the charger, Turbo would apparently trip the protection circuit and the tail cap had to be loosened and tightened back up to use the battery. After just running it on high for a while, it returned to normal behavior, It was the battery, not the light as it worked perfectly with other batteries. I know some guys prefer protected batteries, but this light appears to be more reliable with IMR high drain unprotected batteries. Being a true newbie, I can not explain what happened just report it.
This light can easily pull 15A, there aren’t many high drain protected batteries. so it’s not really a reliability the thing but compatibility.
This light has built in protection so you don’t need a protected cell either.
scosgt
The funny thing is, I was using the same battery all day yesterday with no issues, and after letting it run on high for around 15 minutes it started acting normal again. So maybe it was hot internally from just being charged or something.
scosgt
Here is a comparison between the FT03 and the Convoy L6.
By the way, the FT03 runs a LONG time.
When I ran the above battery down, it was on high or Turbo for over two hours, the battery was still at 3.57 volts, so it had a long way to go.
https://imgur.com/a/amS8Nye
