Customer Review for Hot recommend RD tech (ruideng) products of DPS5020, DPS5015,DPS5005, UM25C ,UM34C ,TC66C UM24C at34,DPH5005
New Share
RD AT34 USB 3.0 voltmeter ammeter multimeter
[Excellent tester, the description corresponds, the device is packed reliably, although in football play. everything works. delivery to rostov on don 14 days. the seller thanks and good luck in business! i recommend of course) ]
https://www.aliexpress.com/item/32897200670.html
NEW SHARE
RD HD35 Trigger QC2.0 QC3.0 Electronic USB Load
[excellent. super fast shipping. it works great. thank you]
https://www.aliexpress.com/item/32917594486.html
and there will be a discount next week, please wait 2 more day
new share
RD DPS5015 DC Step-down Power Supply
[Order received, everything is fine, came quickly and securely packed. The module works as expected. Excellent product, reliable supplier. Thank you.]
https://www.aliexpress.com/item/32702714880.html
new share
RD DPS5005 DC Step-down Power Supply
[Good set, a little soldering. It is a pity that there was no connector for connecting the cooler, i had to cut off the wire. Complete wires are enough to collect all together. The first inclusion was smoke test.]
dont forget this is the second day of big discount
here is the article of the big discount:
NEW SHARE
RD 100v/20A 7in1 OLED Multifunction Tester
[ It’s a good thing superski packed. For what thanks to the seller.Everything works. Error not more than 5%]
https://www.aliexpress.com/item/32788030454.html
it has 29% discount OFF now, you can have a look
view more discount in this link:
https://budgetlightforum.com/t/-/57557
NEW SHARE
RD 33v10A 7in1 OLED Multifunction Tester
[Delivery to the motherland of lenin 14 days. Packaging worthy (foam, pupyrka, scotch). Starts working from about 3,7 v. Measures, for its cost, exactly. Of the minuses: small numbers on the display. In my opinion, you can add switching screens with each parameter built-in button on the ring, but with a large font. The work of the seller and the goods was satisfied]
https://www.aliexpress.com/item/32570250500.html
NEW SHARE
RD UM25 UM25C Type-C voltmeter ammeter
[Great tester! Fast shipping. Packing is very durable. The seller is well done! I recommend.]
https://www.aliexpress.com/item/32855845265.html
RD Tech, I don’t think you need to put up reviews of your products anymore.
We already know they are very good.
thank you for your message
I am so sorry, but we post this review is for posting our review, only on this post, we did not put that at other place ,
this is a special post
NEW SHARE
RD UM34C USB 3.0 voltmeter ammeter
[The tester is good, the program on the phone is cool, underworked. Load is also good, soldering quality]
https://www.aliexpress.com/item/32880908871.html
and three peoducts are on higher discount:
product picture product name price
RD TC66/TC66C Type-C PD trigger USB-C Voltmeter ammeter
29% OFF
US $17.30 - 21.74
RD DPS5015 communication Constant Voltage current DC Step-down Power Supply
25% OFF
US $34.63 - 59.00
RD UM34 UM34C for APP USB 3.0 Type-C DC Voltmeter ammeter
29% OFF
US $14.19 - 27.51
NEW SHARE
RD AT35 5 digits USB 3.0 color LCD Voltmeter ammeter
[Delivered very quickly, packed in foam box. The devices themselves in separate plastic boxes. Both the voltmeter and the load are assembled very neatly, work perfectly. Made sure that the usb3 port of my computer does not hold the load well… Many thanks to the seller and the manufacturer! ]
https://www.aliexpress.com/item/33022448123.html
NEW SHARE
RD TC66C Type-C voltmeter ammeter
[Excellent tester. All functions in one review do not describe. I advise you to look at the reviews on youtube. The device is neatly assembled. The protective film slightly departed when i disassembled it to look-it still needs to be removed. The device came in time, the seller communicates well, gave a voltmeter. ]
https://www.aliexpress.com/item/32968303350.html
don't forget there are three peoducts are on higher discount:
time:7.21~7.27(PST)
29% OFF
US $17.30 - 21.74
25% OFF
US $34.63 - 59.00
29% OFF
US $14.19 - 27.51
NEW SHARE
RD HD25 HD35 Electronic USB Load
[The workmanship is excellent. With usb load, you can quickly and efficiently check the charger or power bank, check the maximum output current with the output voltage check and immediately determine the power source. The load also allows you to determine which fast charging standard supports the charger or power bank. You can manually switch the checked device to the desired standard of fast charging. You can also check and evaluate what current is able to miss the charging cable. The presence of 3 different connectors allow you to check the micro usb cable, USB-C, usb extension cable. Excellent tester for checking chargers, power bank and cables. Also, the HD-25 can be used in amateur radio practice as a load to check the setting of power supplies, etc. Devices in the range of output voltages 4-20v and current no more than 4a. I recommend this seller. I personally made sure that the quality of the goods, packaging and delivery are excellent. ]
I bought a few of these in the past from RD tech on AliExpress. All came and working well.
Some AliExpress sellers might not be so reliable; I had two items with issues and 1 shipped but never arrived; seller did not issue refund.
very good, friend
hope you like it and tell your more friends
NEW SHARE
RD 100v/33v10A 7in1 OLED Multifunction Tester
[to St. Petersburg. 11 days.Happy. The price, quality, functionality is 5 x 5 x 5 *. It corresponds to the description. I apologize three times for my “short” review … (tired … take a word, I took measurements = everything suits me, I agree with everyone with positive (quality) reviews, purchase and use a quality product … In my case, the errors of V. are 0.5, A-0.8 = completely satisfied. To the Seller Thank you. Good luck. I recommend.]
NEW SHARE
RD DPS5020 Constant Voltage current DC- DC Step-down communication Power Supply buck Voltage converter LCD voltmeter 50V 20A
【Order received. The seller quickly sends the goods. Quickly answers the question. The converter works. Thank you seller. I wish you success in business.】
NEW SHARE
RD UM34C Type-C DC voltmeter ammeter
[Works just as expected. If you want to know how your devices charge or why they probably don’t this is a great tool. You can also export the graphs into an Excel file. The app crashes when you do but the data are exported fine.]
