Did anyone measured the amps draw on this XHP50.2 variant?
Interested
i think i read around somewhere 10-12Amps…
We were estimating it would need to pull 14A-16A to do a real 4300 lumen OTF. Of course, it might actually measure a bit less of both. I don’t know if anyone has measured the 50.2 lumens or amp draw yet. I don’t think I’ve seen any of those reports. Maybe the light is still too new and not many people have recieved them yet.
I got 14.8A with VTC5A for XHP50.2.
Thanks. :+1:
Interested, can I please get the coupon code?
mortuus: A_M_K:Did anyone measured the amps draw on this XHP50.2 variant?
I’m measuring around 14 Amps tailcap current on the FT03 XHP50.2 (using UT210E amp meter and a short piece of copper wire to form a loop around the tail tube).
Unfortunately I don’t have a way of measuring lumens. I have a basic lux meter which I can only measure some ceiling bounce lux measurements…
what is considered normal draw for the SST40 version? mine only draws 7.8 with 80% battery.
Sounds normal.
With a fully charged high drain battery they seem to draw about 8.5A-9.5A. It’s never exact with a FET driver.
Sounds normal.
Thanks.
Hi freeme,
I’m interested in this light. Thanks.
AirBreaker
Using the Sofirn 26650 HD battery I only get 3650 lumens at 30 seconds with the 5700K Tint
Unfortunately I don’t own anything better than a 30Q which performs roughly the same.
How do you measure it?
Purchased, thanks freeme!
Funtastic:Using the Sofirn 26650 HD battery I only get 3650 lumens at 30 seconds with the 5700K Tint
The same way you do with a TA Lumen Tube calibrated with Maukka lights. My lumen tube is within 2 lumens of both calibration lights
JasonWW: Funtastic:Using the Sofirn 26650 HD battery I only get 3650 lumens at 30 seconds with the 5700K Tint
Okay, I can’t keep track of who uses what. (unless it’s in their sig)
Did you bypass the springs? After 30 seconds thats still a good result NW tint should be a little down on output vs the cw.
What’s everyone’s opinion on using 21700’s in this light as I’ve heard they will damage the springs?
My luxmeter shows 125.000 Lux and my ceiling bounce shows 4541 Lumen for my neutral white (5700k) FT03 XHP50.2
(both may be 5 to 10 seconds after start, using a unprotected Keeppower 26650 with 5200mAh).
For my FT03 with SST40 neutral white (5700k) I got 190.000 Lux and 2306 Lumen.
Greets
Carsten
