Your calender dates for thurs through to Sun.
Are our current daily temp’s In Celcius.
Mid winter.
We’ve never had temp’s that cold in the 47yrs I’ve been here
Mornings…*7c to 24/26c. Normally 12 to 14ish O.Night.
This “Climate changing” is certainly changing things round the world.
Weeklund.
Australia.
We limited to 5kw (household) if on grid. Unlimited if not.
I have 4.2kw.
Runs. 2 storey home plus pool pumps, Covers ALL running/service costs.
Gives us 44c per kw turned into grid after usage. (till 2028.)
Av around $650ish Per yr cash return now. Was over a grand at beginning.
(Service costs rises.)
Initial costs . Out of our pocket.
$16.4k AUD. We were worth MORE than your Dollar then.
Around $1.6 or $1.8c US to AUD.
Now. Around 65C US to $1 AUD.
Somebody likes your president.
Preferably. Have MORE panels than Inverter capacity.
Keeps system MORE efficient
during it’s cycle.
IE max inv input for longer, while sun shining. Wasting a little panel output
at times but higher returns through grid.
We Use Heater and Aircond as WANTED… not can afford.
Leave it on ALL the req’d seasons. 7/8weeks Winter temp’s.
three months plus of hot temp’s.
Paid for itself in under 7 yrs.
Oh. Evac Tubes (30) HWS there too.
Near Constant hot water when sun shines or air hot during night.
We right on the Tropic of Capricorn. (23km North of)
Most stable, constant, climatic band on the planet.
Check it.
another near perfect day in Santa Barbara. high was somewhere in the 70s, a bit of damp fog in the morning, but beautiful in the afternoon. Supposed to be 5F cooler tomorrow.
Probably only 200 miles straight line from racoon city, but a world of difference. He’s only about 75 miles from the Pacific Ocean, but about 40F away in daytime high temperature.
One trick I like to use when it does get hot, is to put a wet bandana around the back of my neck and draped over the top of my chest. Evaporation cooling is pretty helpful. If its super humid where you are, maybe this doesn’t work?
I’d move to Santa Cruz in a heartbeat… Central Valley is hot, but not as hot as SoCal desert.
Our Temps for the last month (green is temp, blue is humidity):
