Here in the Sunshine State we have two seasons :
Nearly unbearably hot and humid and then nearly perfect .
It's also known as an evaporative cooler.
They only work when the dewpoint is below about 55 degrees, so like chinooker says, it won't work for you.
They're great when the humidity is low.
Tip of the day: Hold ALT key and on numeric keypad type 248, gets you the degree symbol °
My numeric keypad is full of macros.
Hot and humid here.
another near perfect day in Santa Barbara. high was somewhere in the 70s, a bit of damp fog in the morning, but beautiful in the afternoon. Supposed to be 5F cooler tomorrow.
Probably only 200 miles straight line from racoon city, but a world of difference. He’s only about 75 miles from the Pacific Ocean, but about 40F away in daytime high temperature.
My readings are on the weathermap, Northern part of The Netherlands
Real-time weather data from the world’s largest community of Smart Home Weather Station.
If I could afford it, I would love to move to the California coast!
Santa Barbara is one city of many that interests me.
35c (95f), in the shade, now
As usual, warm.
104º F, real feel 110º F, (40º C, feels like 43º C),
Mostly cloudy, cloud cover 88%,
Humidity 32%, dew point 70º F
Wind: WNW at 4mph
No weather to play with a new Sofirn SP70!
Yes, the cost of living here is quite a lot higher for sure.
What is a swamp cooler?
When his swamp gets a bit too hot, it cools it down?
Tips and tricks to make living in the heat/sun better:
1. Wear white clothes.
2. Wear a cap.
3. Bring your own water bottle.
4. Drink lots of water.
5. Wear sunscreen.
6. Get yourself a portable fan.
To make inside living better:
Man, it’s hot.
It’s like Africa hot.
Tarzan couldn’t take this kind of hot.
And no, it’s not a dry heat. It’s like breathing-through-a-hot-wet-towel heat.
Highs here have been running in the mid 90’s, Lows in the mid 70’s. Humidity ranging from around 80% up to 99%.
But…. Highs for the next few days are gonna be in the low 80’s & Lows in low 70’s & high 60’s. … That suits me just fine!!
One trick I like to use when it does get hot, is to put a wet bandana around the back of my neck and draped over the top of my chest. Evaporation cooling is pretty helpful. If its super humid where you are, maybe this doesn’t work?
It’s 19*C here.
It’s gonna be 24*C tomorrow .
I’d move to Santa Cruz in a heartbeat… Central Valley is hot, but not as hot as SoCal desert.
Our Temps for the last month (green is temp, blue is humidity):
So hot here I saw a dog chasing a cat….and they were both walking
98F here in the city and the cement and buildings just absorb and radiate that heat. :(.
