[♛ FreemeGB] ASTROLUX FT03 XHP50.2 (3V) 4300lm 735m 26650/ 21700/ 18650 Flashlight - SHIPPED!
I got 14.8A with VTC5A for XHP50.2.
Thanks. :+1:
Interested, can I please get the coupon code?
I’m measuring around 14 Amps tailcap current on the FT03 XHP50.2 (using UT210E amp meter and a short piece of copper wire to form a loop around the tail tube).
Unfortunately I don’t have a way of measuring lumens. I have a basic lux meter which I can only measure some ceiling bounce lux measurements…
what is considered normal draw for the SST40 version? mine only draws 7.8 with 80% battery.
Sounds normal.
With a fully charged high drain battery they seem to draw about 8.5A-9.5A. It’s never exact with a FET driver.
Thanks.
Hi freeme,
I’m interested in this light. Thanks.
AirBreaker
Using the Sofirn 26650 HD battery I only get 3650 lumens at 30 seconds with the 5700K Tint
Unfortunately I don’t own anything better than a 30Q which performs roughly the same.
How do you measure it?
Purchased, thanks freeme!
The same way you do with a TA Lumen Tube calibrated with Maukka lights. My lumen tube is within 2 lumens of both calibration lights
Okay, I can’t keep track of who uses what. (unless it’s in their sig)
Did you bypass the springs? After 30 seconds thats still a good result NW tint should be a little down on output vs the cw.
What’s everyone’s opinion on using 21700’s in this light as I’ve heard they will damage the springs?
My luxmeter shows 125.000 Lux and my ceiling bounce shows 4541 Lumen for my neutral white (5700k) FT03 XHP50.2
(both may be 5 to 10 seconds after start, using a unprotected Keeppower 26650 with 5200mAh).
For my FT03 with SST40 neutral white (5700k) I got 190.000 Lux and 2306 Lumen.
Greets
Carsten
125kcd is 707 meters
190kcd is 871 meters
Both numbers are a little on the low side because the KP5200 is a pretty weak battery (high capacity plus old chemistry). It’s a safe battery, though. Performance is still good.
Your lumen numbers are too high. You might want to adjust your numbers down by around 25–30. That should put you in the right ballpark. Ceiling bounce can vary a lot as far as measuring lumens.
Interested, can I please have the coupon code. Thank you!
No bypass. I think I’ll leave as is for this light as it still can last around 5 min Turbo. I’m pretty happy with it.
Made a small montage comparing the FT03 SST-40 and the XHP-50.2 beamshots from the video posted by d_t_a credit goes to him for the video
XHP-50.2 on the left SST-40 on the right
BTW… TinyPic is shutting down! :open_mouth:
