Same lousy packing, no damage though, some scratches of course.
Not work first try, need to cut a thin cardboard, put inside tail cap then tighten. Bingo, green led on. :+1:
Interested
Brass battery carrier design has replaced with aluminium since MF04 model (early 2018). Not much difference in terms of performance.
I agreed, bubble wrap plus newspaper might not be sufficient. I left a feedback to Banggood few weeks ago. Hope manufacturer could come out with a solution with increasing the price.
So someone tell me, on the MF01, does this add run time, brightness, or both?
Looks like the original tube as two sets of batteries in parallel, so does this double the voltage?
Operating voltage is still the same as single carrier. [quote=scosgt] Looks like the original tube as two sets of batteries in parallel, so does this double the voltage? [/quote]
I am a newbie, so help me out here. The extension appears to load the battery carriers in series, won’t that double the voltage?
If not, what is the point of the tube? What does it do besides add 4 batteries?
Thanks
It’s not a series carrier.
It’s a parallel carrier.
It gives you 2x the battery life.
And to anybody buying the carrier, it’s actually better in terms of performance theoretically.
Not that it mattered anyway.
Where can I order one at?
Thanks
That is exactly the info I was looking for.
Can you please send me the coupon? I am interested.
Thanks
If they ever decided to change the Knurling back to the look of the MF02, MF02S, MF04, MF04S then I would like to buy a couple of them please.
Unlikely to happen.
Really awesome, the twin saved my arse on car project I needed a big light.It gave all my Astrolux lights extra points amongst the larger lights I own.
Interested. will use this with the MF01s
Can you send me a code?
Sent.
Freeme since these work with MF01S And they keep making new MF01S in colors, can you have this and DIY tailcap also same colors as MF01S?
I would buy two, purple and another
I am looking for code, thx
