The BLF GT70 "Giggle Monster" is here! 7,500lumens, 1,500m throw! Group buy Closed!
Great! Thanks!
Did you have trouble opening the head? I haven’t tried yet…
Are 8 cells recommended or does it work the same on 4? - i’ve got a choice of 35E (actually in my GT) or 30Qs… I’m assuming 4 is enough to power a single 70.2?
I’ve done it a few times , maybe it’s because I live in the uk ?
The head was kinda tight, not too bad. I used a rubber strap oil filter remover tool to unscrew the head.
On 4 cell’s 30Qs are recommended due to high amp draw (for high power-on lumens) Should work fine, but lower runtimes obviously.
On 8 cells 35Es will be fine.
I quickly tried to unscrew my GT bezel to no avail… I’ll have to try harder. Is it the right part to disassemble?
Are there any how-to video or thread somewhere that explains the GT70 conversion kit mod?
Yes, try to unscrew the bezel, sometimes the head will give before the bezel but that works fine as well,
VOB made a video showing how to do the conversion. It is simpler with the kit then his video but it still shows the steps.
Here are some pictures I took.
I removed the switch cover so I could clamp it in a vise. Pieces of wood with a depression for the switch will also work. I found that loosening the upper head from the lower head removes tension on the bezel rubber seal which makes the bezel a bit easier to unscrew.
I had to use a lot of force and slowly unscrew the pieces. They are tight.
@Jason: Thanks for the picts - i think i saw them somewhere some while ago… Damn, it does not look easy. I would have to get the rubber tools and a bigger vise… Not sure i’ll get into this mod.
How about heating the bezel wish a hair drier? It should dilate a little more then the head and become easier to unscrew? That may damage the lens though?
A lot of the resistance is due to the rubber oring.
The lens is glass so heat will not effect it.
I don’t know if heating the bezel will help or not.
I clamped the flattened part with the button on it in a work-mate. Unscrewed the whole top including reflector with a simple rubber strap shown in JasonWW’s pictures. I didn’t really need the tool I think. Mine came loose easily, so I guess there is a lot of variation.
What a relief it is to have my GT70 back up and running.
I got my replacement LED’s in the mail yesterday and I’ve been hyping myself up for my first reflow attempt on an LED. I had a few practice runs- I used a hot air gun on the bottom of the MCPCB- holding it in place with some alligator clip helping hands. Holding the heat gun about 6-8 inches away seemed to heat it nice and steadily. The solder paste really worked like magic on it too. I was able to remove and replacing the dead LED on the other MCPCB with minimal fuss, using a big pair of metal tweezers. Once my hands had steadied out and I had some confidence I fired up the hot air gun again and had a go at the GT70 MCPCB.
It went surprisingly easily, the LED floats straight on to the pads and with a little pat down on top the excess solder pops out the sides. Beautiful.
I screwed the whole lot back together (with a liberal application of thermal paste under the MCPCB) and fired it up, and finally its back to it’s old self blasting away the darkness.
Thanks again to everyone here with the advice and tips, guiding me on how to get this job done properly. You guys really are top notch. Here’s to hoping all my future work on this light is making it more epic with mods not just fixing it.
Cheers!
Nice! :+1:
Are you able to send this video to me or tag the link. I’m interested but would technically be my first mod. handy with electronics and a soldering iron though.
Thanks
I think this is it: https://www.youtube.com/watch?v=cVKoVZkkCtk
OMG TA what a monster is this, nice you got it going, awesome, congrats!
Yeah, the GT70 turned out pretty good. Have a look at the GT4 for an even more impressive version that is sadly not released yet.
How risky is dedoming? Would you recommend it? How likely is a sbt.90 conversion kit? Should I wait?
It has risks, particularly if you have not done it before. I tell people to be prepared to replace the LED before de-doming.
De-doming gives a good gain in throw but the tint suffers for sure. Personally I don’t do it to my personal lights.
Does it have the same effect on the neutral white tint led? Sbt.90?? Lol
Yes, the effects are basically the same on all of them. The CW is the least noticeable as a rule.
does lumintop have any plans sell this with the sst40 emitter ?
