Hmm, if accurate, 5400K is much warmer than I've seen them elsewhere.
I would grab a couple if they were actually neutral. That would be awesome.
I calculated the CCT for an fcbB46 at an (0.330,0.348) average rhombus point following this equation:
Sweet these ones can be used with direct drive to easy. Thanks
Can’t access KD right now, does anybody experience simmilar problem?
The page loading time goes infinitive…
same here. started during the weekend though. Around Saturday afternoon?
Same here… My shopping cart is idling for now.
Yea same its not loading for me. On the weekend it was fine.
Right, my cart is being serviced right now. Oftenly overloaded needed some re-welding
Sorry friends
I am seeing what is problem with the server right now.
It seems the network connection has some problem.
Sorry for any inconvenience cause to you.
No problem, but hope you will manage to fix it. Good luck Mr Ban.
Thanks Ban, good luck with the site.
I got a nice surprise when the 3p emitters came very well packed with their own protective casing, very useful. I’ll shop here more frequently.
Hey, it’s never dark where they live!
This likely also explains why low-brightness moonlight modes are so rarely offered. You want a mode less bright than outdoors at night??
Back to a 500 error now, so progress!
That said - why is there an RDP port (3389) open??
Still nothing. I hope KD will be brought back soon as now my state of mind goes from ‘panic’ to ‘despair’.
Was working about an hour ago…
KD works for me, but the site loads slowly.
Yep, slowly but working…
+1
… similar to blf.
