It should be fairly easy to do that, considering that the drivers are designed specifically to run various BLF firmware.
Doesn’t Anduril have two momentary brightness levels when locked out? When I first received my FW3A, I thought one click and hold (when locked out) was moon, and two click and hold was brighter? Maybe I’m not remembering correctly, but my light only has moon when locked out. Did I inadvertently change a setting?
No, you just need to update the firmware to a version newer than the 6/2 version to have 2-stage lockout (and then program the stepped modes ramp floor to your desired 2nd stage brightness)
I’d love to get into all that stuff but I’m pretty new to all of this cool flashlight business. What seems weird is I received the light with the 2 stage lock out, played with it a bunch, but now I can only get the low moon when locked out.
Maybe my stepped ramp floor is at the same low moon as my smooth ramp floor, so when ever I double click in lockout, it gives me the 2nd stage, but that 2nd stage is set to the same level so nothing changes. Could that be it?
That could be it yes. You could of accidentally reset the stepped mode ramp floor unknowingly.
Try setting it to your desired 2nd stage lockout level
Hah! That was it! Yeah, I (or my wife) must have unwittingly entered ramp config and set the floor to 1/150. Thanks TrueRMS, I wouldn’t have thought of that without your response :innocent:
Thanks for posting. And this is a very nice manual TK!
How do I download and print it out with the formatting preserved? In Notepad, it is just one big run-on paragraph. Thanks.
Saving it in any way (save the page, rightclick on the link, etc.) will get you an html page. Trash everything except the .htm/.html file itself. Optionally rename it to .txt
Edit that file. Lop off everything outside the “<pre>” and “</pre>” tags, inclusive, and save as a .txt file.
Then print it.
Funny thing is, I never saw the LOTR movies, so had to goggle where “anduril” came from. Sounded like a medication for prostate problems or something. Wellp, now I know better…
I may try this if I have too. But doesn't a PDF version of the manual exist? Thanks.
Any chance of you returning the custom old lumens Flashlight i sent to you when you were known as cereal_killer earlier this year, or are you going to keep ignoring my pm’s and emails
I have a suggestion: while ramping up/down, if the user releases the button very close to the max-regulated blink, the flashlight should assume user is trying to stop at the blink and snap back to it.
In my personal fork I added a short delay (hold time) after the blip. Your idea sounds interesting as well, but the ramping is rather fast and thus it would cover a big range of levels.
Yes, the time delay is a good solution also.
I thought about this previously (time delay) for going above the ceiling. Right now you have the ramp ceiling and double-click to turbo. But nothing in between (going up) which can be unfortunate if you set a low ceiling.
Perhaps it would be useful to have a medium delay (idk maybe ~2s ?) to “break through” the ceiling and continue ramping above it?
Or maybe not, I am just thinking out loud.
FWIW, I was able to easily create a PDF file of the FW3A manual by (1) first installing the free version of CutePDF Writer, (2) right-clicking the manual at the above link and selecting Print, and (3) selecting CutePDF Writer as the printer. Then voila, my PDF copy was saved.
Edited: Got a free SaberCatHost file hosting account and uploaded the PDF Anduril manual for anyone that wants to download it. Here it is.
When I save it from my phone I get a picture, then just printed it from my phone.
Is Andúril (full version with all strobe modes) available as standard on any single emitter 18650/20700/21700 lights? Love the FW3A, but a light with single emitter is better for my use cases (connecting to light painting tools).
I would love to have an FW1A!
I just read these messages and didn’t know that the FW3A has had their firmwares updated. I still have the first release FW3A and tested the 2-stage lockout — it looks like mine is still the old version without the 2-stage lockout. (Tested the same button sequence on the Emisar D4v2, and noted that it had the 2-stage lockout feature).
This points to a few things: Lumintop does use new firmware on the FW3A when it’s available (unlike on the BLF Q8 and I think Sofirn Q8, even their latest batches apparently still use NarsilM v1.0, instead of NarsilM v1.2)
Is there any way to turn off temp monitoring ?
