I don’t think that’s the issue. The bug could have happened with a different portion of the UI besides muggle mode and we’d have the same problem we have now.
Muggle Mode by itself is fine. The only problem is the bug.
You have reflashed many lights, but had no success here? I have no experience in mods,flashing, or soldering, yet I am told that with the proper equipment, it should be easy. I saw in your previous post that you put together your setup. I’ll bet that when Hank’s setup becomes available, you can successfully reflash this light. It’s too bad your friend may need to wait for his light.
Absolutely no shorts. Ichecked before first use multiple times. rechecked now. All wire connection goes to pins so no contact problem either. The light aux led turn red blinking when connect the pins.
This is what I used:
avrdude -c usbasp -p t1634 -u -Uflash:w:andurild4v2.hex
TK wrote this to use.
I flashed more than 200 lights.
My “friend ” messaging me every day multiple times when he can pick up his light and he wanted to came wednesday. Now I can’t tell him to wait or I can’t pay him back and we are here with a worse light than it arrived. He is not a patient guy. So I am sure if I need to wait a month again he wil messaging me every day…. That is why I usually don’t buy lights for other people. If something goes wrong I need to do warranty things or repair lights or loose money. The pin connector is OK I don’t think another one do the job. Maybe some fuse settings missing from the line. Usually flashing scripts have fuses. I don’t know why this not have.
You said it starts at Max ramp, can you ramp down? TK stated that as long as the fuse values are not changed then there is little risk to brick. Have you tried reflashing? Maybe it is set to manual memory and it was on Max ramp, did you try 5h to switch to automatic memory?
yes I can ramp down and seems other things work just it always start ramp max with short click. long click it starts moon then ramp up.
The flashing sequence not even completed once. I tried it many times and not doing the flashing sequence.
:+1: :+1: :+1: OMG that’s the best reasoning I’ve seen. I remember back in the 90s when running the x86 and Pentiums that cost over $2k+, I spent more time trying to figure out DOS and Windows 3.1 crashes, bugs, hardware drivers not working, etc., than actually using my computer. Windows Xp was the first windows stable enough to use without constant fear of crashing and losing work, but it still had its fair share of problems. Apple IOS is probably the most bug free OS I’ve ever seen but it is developed by thousands of engineers and hundreds of billions of dollars, whereas Anduril is developed by a single non profit hobbyist and Emisar is likely not even a registered business operated by a single flashlight enthusiast from his home.
Flashlights are generally considered to be complete units that should never need updating. Most people do not buy a flashlight thinking they’ll need to update the drivers like you would on a PC.
A windows error on your PC is unlikely to cause physical damage to your computer or possibly start a fire. That’s not the case with the Muggle Mode bug.
The D4V2 requires special hardware and software to update the firmware and is clearly not designed to be serviced by the average consumer. Unlike a PC where you can download a patch during normal operation.
My conclusion is this bug is a product defect and it should be treated as such.
