:+1: :+1: :+1: OMG that’s the best reasoning I’ve seen. I remember back in the 90s when running the x86 and Pentiums that cost over $2k+, I spent more time trying to figure out DOS and Windows 3.1 crashes, bugs, hardware drivers not working, etc., than actually using my computer. Windows Xp was the first windows stable enough to use without constant fear of crashing and losing work, but it still had its fair share of problems. Apple IOS is probably the most bug free OS I’ve ever seen but it is developed by thousands of engineers and hundreds of billions of dollars, whereas Anduril is developed by a single non profit hobbyist and Emisar is likely not even a registered business operated by a single flashlight enthusiast from his home.
Flashlights are generally considered to be complete units that should never need updating. Most people do not buy a flashlight thinking they’ll need to update the drivers like you would on a PC.
A windows error on your PC is unlikely to cause physical damage to your computer or possibly start a fire. That’s not the case with the Muggle Mode bug.
The D4V2 requires special hardware and software to update the firmware and is clearly not designed to be serviced by the average consumer. Unlike a PC where you can download a patch during normal operation.
My conclusion is this bug is a product defect and it should be treated as such.
Perhaps you don’t have the bug firmware. Look at the bottom of the revised Anduril diagram. There are instructions there for doing a factory reset.which is a new feature that was just added to Anduril along with the bug fix. If your light resets to the default values, your reflash was successful and you shouldn’t have the muggle bug.
Usually, yes. The Emisars are not usual flashlights, though. Most people outside the flashlight community don't know they exist.
As it was said before these are clearly lights made for flashlight enthusiasts. If you can master the Anduril UI completely you can probably also do the firmware update IMHO.
Even inside the hobbyist community on BLF, none of us buy flashlights with the expectation that the firmware MUST be updated.
I suspect very few on this website have ever actually flashed updated firmware on any of their lights. I think flashing firmware is considered even on BLF to be an activity only for advanced flashlight modders.
Some good might come of this muggle mode bug though. As a result of the bug, more enthusiasts are likely to purchase the flashing hardware and give a shot to flashing their lights. This might open up modding to a whole new group of modders.
Only this automatic and manual memory was new to me. I am using anduril earlier than any factory flashlight. Just don’t read every update manual. But the bug still in this light and flashing is not working.
Ah I see , I’ve already seen them posts ,a. Video would be nice though.
With a quality cell like a 30Q I suppose the battery would be non deadly but I’m thinking if muggles had been running it with a fake or a cheap Chinese crapfire cell it may have exploded.
