mortuus
(mortuus)
July 23, 2019, 8:13am
30
but it doesnt hold up heat very well or ? atleast the l6 i can run turbo almost nonstop and its not that heavy when i touch the head… i think the ft03 is better have the sst40 version and u get better throw and less heat.
Heat is not the issue. The major issue would be battery drainage the FT03 would last less than half the time of the L6 or S70 at max brightness.
Is the 3v xhp50.2 a direct swap for the sst-40 version of ft03?
Yes it is. Xhp 50.2 also has same footprint as sst 40, so you can even reflow it to the existing mcpcb yourself, if you have sst 40 version
Starkm32
(Starkm32)
July 23, 2019, 1:30pm
34
Is there a stateside vendor with competively priced FT03 with XHP50.2 ?
Newbe question: is there such a thing as an XHP70, and if it does exist, what would
The difference be?
oweban
(oweban)
July 23, 2019, 12:51pm
37
I see HSP and that’s what I think sorry, getting carried away.
XHP70 and 70.2 definitely exist, and they’d physically fit in the FT03, but the issue is that I believe they’re mostly 12v. There’s apparently 6v variants, though. Compared to the 50.2, it’s the same kind of “wall-of-light” profile, just bigger.
Starkm32
(Starkm32)
July 23, 2019, 9:59pm
38
Thanks for your response!
Acronyms bring out the dyslectic in me.
oweban
(oweban)
39
No worries! I always just imagine it’s “eXtra Heavy Photons”
fluke
(fluke)
August 15, 2019, 3:38pm
40
Does the 50.2 have the same FET driver as the SST40 version?
Hey mate yea the same driver.
This XHP50.2 is a 3v variant.
I haven’t been able to find a stateside vendor for astrolux flashlights. I would like to see one.
scosgt
(scosgt)
August 28, 2019, 1:40am
43
Banggood will get it to you in around two weeks.
I prefer the earlier (less lumins) version.
It has much longer throw.
But both are well worth having.
scosgt
(scosgt)
August 31, 2019, 9:55pm
44
Does this require a 3V 50.2, or will a 6V work?
I don’t find any 3V for sale…
oweban
(oweban)
August 31, 2019, 10:57pm
47
I think I remember reading that it was the same driver as the SST40 model, so I’m guessing no (if that’s the case).
(Okay yeah I read it a few posts above oops; didn’t scroll up)
scosgt:
Thanks
I am using the 3V edition of the XHP50.2 for you the best place to buy the LED would be from mountain electronics if they have any in stock or from here.
http://kaidomain.com/Flashlight-DIY-and-Tools/LED-Emitters-or-LED-Star-on-PCB/cree-xhp-series-leds/3V-Cree-XHP50_2-K2-2A-White-6000K-LED-Emitter
The stock MCPCB in the FT03 is 28mm so the 20mm board is a bit harder to fit in place. Or you can reflow the XHP50.2 on your SST40 board.
