Led4power.com : LD-4 CC linear drivers, ILC-0/1 illuminated tailcaps, optics, MOSX, copper DTP MCPCBs...
I do the same as djozz only with 2 or 3 washers. If you try it with just one the edge of the dome will likely tear off at the end of the cut. As djozz mentioned the solder height is a factor if you want a close cut but probably even more important is to try to use the same type of MCPCB each time. I have a 20mm one I use that has never had solder on the LED +/- pads so the washer sits flat/the same way every time.
Actually it’s good to know others experience similar problems, I was even thinking of getting something thinner than Wilkinson razor, but the trick with double / triple washer is definitely worth trying. Many thanks.
I’m not sure everyone understood what djozz was saying. I think he’s saying he uses a thick washer to slice first, then a slightly thinner one to slice a bit more, then a thinner one again, then the thinnest one gets the last slice to be the right height.
Neven,
Do you know whats the tint bin of your 3000K Luxeon V2’s? On the datasheet there is 5A, 5B, 5C, 5D, 3U, 3L in 2700K, 3000K, 3500K.
I don't know exact tint bin, but I've never seen Lumileds LEDs available in narrow tint bin range,they are only available as 3 or 5-step MacAdam ellipse.
Thank you
Thanks for pointing it, now it’s crystal clear.
:+1: I think that language to describe technical procedures is the most challenging type, perhaps even for native speakers.
I see clearance sale in some copper mcpcb DTP, ther will be replaced or what is the reason?
They will be replaced by new design,fully gold plated this time, so price will be a little bit higher (similar to 3030 DTPs). Existing PCBs at reduced price will be available until stock is exhausted.
Hi Neven,
Will you also be making a 5050 16mm DTP MCPCB?
I don't plan to have 5050 pcbs anymore, only two popular LEDs use them these days: SST-40 and XHP50.2, and I don't stock any of those, so it doesn't make too much sense to have pcbs and no LEDs.
Luxeon V is IHMO better LED overall than SST-40 so I don't want to stock two very similar LEDs, XHP50.2 has ugly beam tint - don't want to stock those either for this reason.
It makes sense… Thanks
LD-B4-20 ETA?
Someone gets it! Only passable excuse IMO for sst40 is dedomed.
10-15days, I'm waiting for some test rig pcbs.
If anyone was interested in the L4P quad spacer for the X6 you might find this useful:
Damn it, I may just have to build one now :blush:
Question though, I haven’t been able to find the answer and haven’t built a triple yet so forgive me if this seems like a simple/noob question… I see the L4P triple spacer has a bolt and a spacer whereas others, such as kiriba-ru’s, just have the spacer. Why is that and is there a practical difference? I’ve gone through a number of X6 triple/quad build posts (including yours) but am still struggling to get my head around the role the bolt plays.
The bolt keeps the spacer from spinning when you screw the bezel and it also ensures good thermal path from spacer to body.
I measured the newer batch Luxeon V with a Vf of 3.324V @ 6A, compared to the 1st batch with a Vf of 3.484V @ 6A.
